Moderators: arango , robertson
sougata24
Posts: 8 Joined: Fri Dec 08, 2023 4:10 pm
#1
Unread post
by sougata24 » Fri Mar 22, 2024 9:57 am
I am facing the below mentioned error, when I am running ROMS -
PART OF THE LOG :
Analytical header files used:
ROMS/Functionals/ana_btflux.h
REASON: MaxSpeed = 2.0E+01
I have tried decreasing DT to 30 , but the same error is persistent. Any guess what could be causing this error.
Thanks!
AS_upwelling.log
(67.2 KiB) Downloaded 919 times
susonic
Posts: 171 Joined: Tue Aug 21, 2007 5:44 pm
Unread post
by susonic » Sat Mar 23, 2024 9:48 pm
hello
1. The bathymetry was not smoothed. The value of rx0, rx1 are too high.
2. Please check out the unit of the Sea level pressure.
3. Please check out the humidity(specific, or relative) unit and match the unit in varinfo.dat
-JH
Joonho Lee
sougata24
#3
Unread post
by sougata24 » Fri Apr 12, 2024 8:47 am
This time I used 2021 data and tried to run ROMS with the suggested changes. But after running a bit longer than before (~ 1 hr 20 seconds) it is still blowing up.
Not sure what's the problem.
AS-upwelling.log
(153.1 KiB) Downloaded 769 times
susonic
Unread post
by susonic » Fri Apr 12, 2024 9:13 am
Please check out your lateral boundary conditions.
I saw many 0 value at eastern and western boundaries.
Also, when it blows up, could you plot horizontal u, v, temp, salt and upload here?
It might not the major cause but I doubt about your unit at the humidity. Are you sure that it is relative humidity?
-JH
Joonho Lee
sougata24
susonic
Unread post
by susonic » Sun Apr 21, 2024 12:55 pm
Seems like your initial condition does not match with the boundary condition.
Could you plot your initial condition(u,v, temp, salt) here?
Joonho Lee
