Roms blowing up due to MaxSpeed = 2.0E+01
sougata24
#1 Unread post by sougata24 »
I am facing the below mentioned error, when I am running ROMS -
PART OF THE LOG :
Analytical header files used:
     ROMS/Functionals/ana_btflux.h
 REASON: MaxSpeed =  2.0E+01
I have tried decreasing DT to 30 , but the same error is persistent. Any guess what could be causing this error.
Thanks!
AS_upwelling.log
(67.2 KiB) Downloaded 919 times
susonic
Re: Roms blowing up due to MaxSpeed = 2.0E+01
#2 Unread post by susonic »
hello
1. The bathymetry was not smoothed. The value of rx0, rx1 are too high.
2. Please check out the unit of the Sea level pressure.
3. Please check out the humidity(specific, or relative) unit and match the unit in varinfo.dat
-JH
Joonho Lee
sougata24
#3 Unread post by sougata24 »
This time I used 2021 data and tried to run ROMS with the suggested changes. But after running a bit longer than before (~ 1 hr 20 seconds) it is still blowing up.
Not sure what's the problem.
AS-upwelling.log
(153.1 KiB) Downloaded 769 times
susonic
#4 Unread post by susonic »
Please check out your lateral boundary conditions.
I saw many 0 value at eastern and western boundaries.
Also, when it blows up, could you plot horizontal u, v, temp, salt and upload here?
It might not the major cause but I doubt about your unit at the humidity. Are you sure that it is relative humidity?
-JH
Joonho Lee
sougata24
#5 Unread post by sougata24 »
Hi, thanks for the reply.
I have specific humidity from ERA5, which is in kg/kg. For which I think I have to give scale as 1000d0 in my varinfo.yml ?
Well the simulation is definitely wrong and it seems like something is happening at the western side.
susonic
#6 Unread post by susonic »
Seems like your initial condition does not match with the boundary condition.
Could you plot your initial condition(u,v, temp, salt) here?
Joonho Lee
