bulk forcing
shrikantmp
bulk forcing
#1 Unread post by shrikantmp »
Hi ROMS users
I have two questions.
1.If I define BULK_FLUXES and provide u and v winds, do I need to provide sustr and svstr i.e. surface U and V momentum stress values?
2. If I am not to define BULK_FULXES, QCORRECTION and SRELAXATION, will it work if I don't provide any SST and SSS data in forcing file?
Thanks in advance.
Shrikant :roll:
Re: bulk forcing
1. If you define BULK_FLUXES, you don't have to provide the stresses.
2. If you don't define QCORRECTION, SCORRECTION or SRELAXATION, you don't have to provide SST or SSS.
shrikantmp
Re: bulk forcing
#3 Unread post by shrikantmp »
Thank you very much Kate.
lindandan
Re: bulk forcing
#4 Unread post by lindandan »
kate wrote:1. If you define BULK_FLUXES, you don't have to provide the stresses.
I have a question that when I should define the option 'SOLAR_SOURCE' if I use the BULK_FLUXES?
Re: bulk forcing
#5 Unread post by kate »
The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
lindandan
Re: bulk forcing
#6 Unread post by lindandan »
kate wrote:The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
Thanks , I have understood it.
lyy
Re: bulk forcing
#7 Unread post by lyy »
Dear KATE:
What documents(or modules) are related to solar radiation? What are their meanings and functions?
Thank you!
Re: bulk forcing
#8 Unread post by kate »
I don't understand your question - and likely don't know the answer anyway.
