Moderators: arango , robertson
shrikantmp
Posts: 27 Joined: Mon Jan 27, 2014 9:50 pm
#1
Unread post
by shrikantmp » Tue Sep 15, 2015 7:11 pm
Hi ROMS users
I have two questions.
1.If I define BULK_FLUXES and provide u and v winds, do I need to provide sustr and svstr i.e. surface U and V momentum stress values?
2. If I am not to define BULK_FULXES, QCORRECTION and SRELAXATION, will it work if I don't provide any SST and SSS data in forcing file?
Thanks in advance.
Shrikant
Posts: 4092 Joined: Wed Jul 02, 2003 5:29 pm
Unread post
by kate » Tue Sep 15, 2015 7:24 pm
1. If you define BULK_FLUXES, you don't have to provide the stresses.
2. If you don't define QCORRECTION, SCORRECTION or SRELAXATION, you don't have to provide SST or SSS.
lindandan
Posts: 17 Joined: Tue Nov 03, 2015 12:52 am
#4
Unread post
by lindandan » Wed Jun 22, 2016 9:37 am
kate wrote: 1. If you define BULK_FLUXES, you don't have to provide the stresses.
I have a question that when I should define the option 'SOLAR_SOURCE' if I use the BULK_FLUXES?
Unread post
by kate » Thu Jun 23, 2016 12:53 am
The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
lindandan
#6
Unread post
by lindandan » Wed Jun 29, 2016 11:27 am
kate wrote: The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
Thanks , I have understood it.
lyy
Posts: 1 Joined: Fri Nov 27, 2015 5:53 pm
#7
Unread post
by lyy » Wed Jul 13, 2016 2:41 am
Dear KATE:
What documents(or modules) are related to solar radiation? What are their meanings and functions?
Thank you!
Unread post
by kate » Wed Jul 13, 2016 3:37 am
I don't understand your question - and likely don't know the answer anyway.
