Hi ROMS users
I have two questions.
1.If I define BULK_FLUXES and provide u and v winds, do I need to provide sustr and svstr i.e. surface U and V momentum stress values?
2. If I am not to define BULK_FULXES, QCORRECTION and SRELAXATION, will it work if I don't provide any SST and SSS data in forcing file?
Thanks in advance.
Shrikant
bulk forcing
Re: bulk forcing
1. If you define BULK_FLUXES, you don't have to provide the stresses.
2. If you don't define QCORRECTION, SCORRECTION or SRELAXATION, you don't have to provide SST or SSS.
Re: bulk forcing
Thank you very much Kate.
Re: bulk forcing
I have a question that when I should define the option 'SOLAR_SOURCE' if I use the BULK_FLUXES?kate wrote:1. If you define BULK_FLUXES, you don't have to provide the stresses.
Re: bulk forcing
The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
Re: bulk forcing
Thanks , I have understood it.kate wrote:The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
Re: bulk forcing
Dear KATE:kate wrote:The option is used in pre_step3d and it brings solar radiation down into the water column as heat instead of leaving it all at the surface.
What documents(or modules) are related to solar radiation? What are their meanings and functions?
Thank you!
Re: bulk forcing
I don't understand your question - and likely don't know the answer anyway.
