I am running the tides only model and keeping constant temp. But I have got the surface temperature as follow. I also found the temperature of all boundaries in the bottom layers are not constant. What's the reason for this?
Please find the attachment for my model's configure.
how to keep constant temp when running tide only modal?
Re: how to keep constant temp when running tide only modal?
Though I have not defined TS_FIXED, I have set the initial conditions, OBC to T0(ng), and set the surface and bottom fluxes to 0, by ana_initial, ana_tobc.h, ana_stflux.h and ana_btflux.h.
So I really can not understand why the temperature can be changed still during the LOOP?
You don't need to define TS_FIXED for tide-only modeling. Just constant tempe/salt as you specified.
It looks to me that your problem may be something to do with open boundaries.
What's your cppdefs and ocean.in?
Also, why did you edit ana_tobc.h? I don't think I did that for tide-only modeling.
DJ@TAMU
DJ@TAMU
For a really simple tides-only problem you can turn off SOLVE3D. Then you won't have any temperature to be evolving. The one thing you would have to change in ocean.in is to set DT to your fast DT and NDTFAST to 1.
My cppdefs are including but not limited as follow,d.kobashi wrote:You don't need to define TS_FIXED for tide-only modeling. Just constant tempe/salt as you specified.
DJ@TAMU
UV_* ANA_BSFLUX ANA_BTFLUX VISC_GRID MIX_S_UV ANA_FSOBC ANA_M2OBC ANA_M3OBC ANA_TOBC ANA_INITIAL ANA_STFLUX ANA_SMFLUX, RADIATION_2D SPLINES SOLVE3D CURVGRID MASKING DJ_GRADPS.
For other cppdefs, you can check the attached file "batch-41443.out", as follow,
xcn069
Monday - February 9, 2015 - 4:17:44 PM
The new SCS Operational Forecasting System, 1/30 degree resolution
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /export/home/zhuxm/mpich-3.1/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free -free
Input Script :
SVN Revision : exported
Local Root : /mnt/swgfs/zhuxm/roms/ROMS_trunk_20141023
Header Dir : /export/home/zhuxm/swgfs/roms/ofs_scs
Header file : scs.h
Analytical Dir: /export/home/zhuxm/swgfs/roms/ofs_scs
Resolution, Grid 01: 0985x0793x030, Parallel Nodes: 128, Tiling: 016x008
10000000 ntimes Number of timesteps for 3-D equations.
90.000 dt Timestep size (s) for 3-D equations.
480 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
40 nHIS Number of timesteps between the writing fields
into history file.
172800 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
0 nAVG Number of timesteps between the writing of
172800 ndefAVG Number of timesteps between creation of new
time-averaged file.
1.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
T LuvSponge Turning ON sponge on horizontal momentum.
1.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
1.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
3.0000E-03 rdrg Linear bottom drag coefficient (m/s).
1.0000E-03 Zob Bottom roughness (m).
30.000 Tcline S-coordinate surface/bottom layer width (m) used
1027.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
20000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.6000E+02 Tnudg(01) Nudging/relaxation time scale (days)
3.6000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.6000E+02 Znudg Nudging/relaxation time scale (days)
3.6000E+02 M2nudg Nudging/relaxation time scale (days)
3.6000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
T VolCons(1) NLM western edge boundary volume conservation.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
T VolCons(4) NLM northern edge boundary volume conservation.
of State.
Output Restart File: scs_rst.nc
Prefix for History Files: scs_his0
Prefix for Averages Files: scs_avg
Input Grid File: scs_grd.nc
Input Forcing File 01: scs_tide_20000101.nc
Tile partition information for Grid 01: 0985x0793x0030 tiling: 016x008
tile Istr Iend Jstr Jend Npts
(interior points only)
tile Xmin Xmax Ymin Ymax grid
RHO-points
U-points
V-points
HaloSizeI(1) = 148
HaloSizeJ(1) = 224
TileSide(1) = 106
TileSize(1) = 7208
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
SCS The new SCS Operational Forecasting System, 1/30 degree resolution
ANA_M3OBC Analytical 3D momentum boundary conditions.
ANA_TOBC Analytical tracers boundary conditions.
INLINE_2DIO Processing 3D IO level by level to reduce memory needs.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RAMP_TIDES Ramping tidal forcing for one day.
TIDES_ASTRO Compute astronomical (long-period tide) corrections.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0002307 -0.143 -0.503 -1.676 -2.372
28 -0.0666667 -0.0009291 -0.286 -1.014 -4.742 -7.537
27 -0.1000000 -0.0021144 -0.430 -1.532 -9.256 -15.608
26 -0.1333333 -0.0038189 -0.574 -2.057 -15.313 -26.779
25 -0.1666667 -0.0060892 -0.719 -2.591 -23.052 -41.328
24 -0.2000000 -0.0089871 -0.864 -3.135 -32.657 -59.624
23 -0.2333333 -0.0125913 -1.009 -3.689 -44.362 -82.137
22 -0.2666667 -0.0169996 -1.155 -4.255 -58.457 -109.450
21 -0.3000000 -0.0223307 -1.302 -4.835 -75.296 -142.273
20 -0.3333333 -0.0287278 -1.449 -5.431 -95.303 -181.459
19 -0.3666667 -0.0363614 -1.597 -6.045 -118.986 -228.028
18 -0.4000000 -0.0454338 -1.747 -6.682 -146.947 -283.187
17 -0.4333333 -0.0561830 -1.897 -7.343 -179.892 -348.356
16 -0.4666667 -0.0688882 -2.049 -8.033 -218.652 -425.203
15 -0.5000000 -0.0838752 -2.203 -8.758 -264.196 -515.673
14 -0.5333333 -0.1015226 -2.358 -9.523 -317.648 -622.026
13 -0.5666667 -0.1222681 -2.516 -10.334 -380.310 -746.874
12 -0.6000000 -0.1466152 -2.676 -11.199 -453.679 -893.225
11 -0.6333333 -0.1751391 -2.839 -12.127 -539.465 -1064.512
10 -0.6666667 -0.2084930 -3.006 -13.127 -639.610 -1264.635
9 -0.7000000 -0.2474113 -3.177 -14.211 -756.296 -1497.978
8 -0.7333333 -0.2927113 -3.352 -15.391 -891.953 -1769.421
7 -0.7666667 -0.3452901 -3.532 -16.679 -1049.250 -2084.319
6 -0.8000000 -0.4061157 -3.719 -18.092 -1231.062 -2448.452
5 -0.8333333 -0.4762095 -3.912 -19.643 -1440.427 -2867.917
4 -0.8666667 -0.5566161 -4.112 -21.349 -1680.449 -3348.952
3 -0.9000000 -0.6483588 -4.320 -23.225 -1954.172 -3897.665
2 -0.9333333 -0.7523753 -4.537 -25.286 -2264.382 -4519.654
1 -0.9666667 -0.8694298 -4.764 -27.541 -2613.351 -5219.481
0 -1.0000000 -1.0000000 -5.000 -30.000 -3002.500 -6000.000
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 3.23632803E+00 km
Maximum X-grid spacing, DXmax = 9.17057348E+00 km
Minimum Y-grid spacing, DYmin = 3.59466836E+00 km
Maximum Y-grid spacing, DYmax = 8.96506546E+00 km
Minimum Z-grid spacing, DZmin = 1.43021931E-01 m
Maximum Z-grid spacing, DZmax = 7.80518607E+02 m
Minimum barotropic Courant Number = 3.73923787E-03
Maximum barotropic Courant Number = 2.81036039E-01
Maximum Coriolis Courant Number = 6.21345144E-03
Horizontal mixing scaled by grid size, GRDMAX = 9.05374848E+00 km
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 9.67262421E+04)
(Min = 2.52492159E-05 Max = 1.81496844E+01)
(Min = 7.93344988E-06 Max = 6.28318465E+00)
(Min = 3.70293851E-07 Max = 6.28318519E+00)
(Min = 1.48087661E-06 Max = 6.28318352E+00)
(Min = 1.46277260E-06 Max = 3.88200810E+00)
(Min = -4.84188479E-01 Max = 4.11129338E-01)
Maximum grid stiffness ratios: rx0 = 4.152431E-01 (Beckmann and Haidvogel)
rx1 = 8.935458E+00 (Haney)
Initial basin volumes: TotVolume = 3.7659566873E+16 m3
MinVolume = 1.7915665593E+06 m3
MaxVolume = 5.3941176727E+10 m3
Max/Min = 3.0108385561E+04
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 10000000)
0 0 00:00:00 0.000000E+00 2.142222E+04 2.142222E+04 3.772388E+16
DEF_HIS - creating history file, Grid 01: scs_his0_0001.nc
1 0 00:01:30 1.658685E-30 2.142222E+04 2.142222E+04 3.772388E+16
(666,679,01) 1.379357E-16 1.050798E-16 0.000000E+00 1.323787E-14
Thanks for your suggestions.
ana_tobc.h
- (11.45 KiB) Downloaded 603 times
I just want to run 3D model, not 2D, though I know 2D is enough for tide only case.kate wrote:For a really simple tides-only problem you can turn off SOLVE3D. Then you won't have any temperature to be evolving. The one thing you would have to change in ocean.in is to set DT to your fast DT and NDTFAST to 1.
Thanks. Any other suggestions still?
