plotting package installation
haohaoai65
Location: INSTITUTY OF OCEANOLOGY,CHINESE ACADEMY OF SCIENCE
#1 Unread post by haohaoai65 »
hello everyone
i have a trouble when i install plotting package. when i issue the make command, there comes an error as follows
could anyone help me!
ThX
nmhuan61
Re: plotting package installation
#2 Unread post by nmhuan61 »
I think, your problem is due to NetCDF package,
you have to ask the admin where is NetCDF lives
and load it before the plotting package installation
haohaoai65
#3 Unread post by haohaoai65 »
nmhuan61 wrote:I think, your problem is due to NetCDF package,
Thank you for your reply, but i don't understand your meaning
linzhenhua
#4 Unread post by linzhenhua »
You get this problem if you only install the netcdf c library. Please check the following post for more information:
viewtopic.php?f=31&t=2715
haohaoai65
#5 Unread post by haohaoai65 »
no,i have installed gfortran too
linzhenhua wrote:You get this problem if you only install the netcdf c library. Please check the following post for more information:
linzhenhua
#6 Unread post by linzhenhua »
Please note that gfortran is a fortran compiler, what you may need is netcdf fortran library.
haohaoai65
#7 Unread post by haohaoai65 »
i use the gfortran compiler, the makefile and CYGWIN-gfortran.mk are as follows. what's wrong with it.
CYGWIN-gfortran.mk
(5.53 KiB) Downloaded 677 times
haohaoai65
#8 Unread post by haohaoai65 »
linzhenhua wrote:Please note that gfortran is a fortran compiler, what you may need is netcdf fortran library.
But i can compile the upwelling test successful
haohaoai65
#9 Unread post by haohaoai65 »
thank you for your help!! the question has been solved!
