plotting package installation
- Location: INSTITUTY OF OCEANOLOGY,CHINESE ACADEMY OF SCIENCE
hello everyone
i have a trouble when i install plotting package. when i issue the make command, there comes an error as follows
could anyone help me!
ThX
ThX
- 1.PNG (10.66 KiB) Viewed 10046 times
Re: plotting package installation
I think, your problem is due to NetCDF package,
you have to ask the admin where is NetCDF lives
and load it before the plotting package installation
Thank you for your reply, but i don't understand your meaningnmhuan61 wrote:I think, your problem is due to NetCDF package,
- Location: Institute of Oceanology,Chinese Academy of Sciences
You get this problem if you only install the netcdf c library. Please check the following post for more information:
viewtopic.php?f=31&t=2715
no,i have installed gfortran too
linzhenhua wrote:You get this problem if you only install the netcdf c library. Please check the following post for more information:
Please note that gfortran is a fortran compiler, what you may need is netcdf fortran library.
i use the gfortran compiler, the makefile and CYGWIN-gfortran.mk are as follows. what's wrong with it.
- 2.PNG (29.52 KiB) Viewed 10009 times
CYGWIN-gfortran.mk
- (5.53 KiB) Downloaded 677 times
But i can compile the upwelling test successfullinzhenhua wrote:Please note that gfortran is a fortran compiler, what you may need is netcdf fortran library.
thank you for your help!! the question has been solved!linzhenhua wrote:Please note that gfortran is a fortran compiler, what you may need is netcdf fortran library.
