Fiting Coordinate system
fdaryabor
#1 Unread post by fdaryabor »
Hi
I want Run model for South China Sea with Lonmin=98, Latmin=0 and Lonmax=125, Latmax=30.
I tried find optimum values, dl,theta_s, theta_b, hc and N for my domain but I can't find
optimum values.
Everybody could help me thank so much.
Best Regards
F.Daryabor
Re: Fiting Coordinate system
I think people haven't answered because we don't know what you are asking. Some of this stuff is trial and error - what have you tried and what didn't work for you?
fdaryabor
Re: BLOWUP
#3 Unread post by fdaryabor »
Hi Kate
Thank so much, I face with following error. Please you guide me for resolve it.
Best Regards
F.Daryabor
ABNORMAL JOB END
USER TERMINATED
VMAX = 0.630E+39 IMAX,JMAX = 187 78
IINT,IEXT = 28 1
MAIN - number of records written into history file(s): 1
number of records written into restart file(s): 0
number of records written into averages file(s): 0
MAIN: Abnormal termination: BLOWUP
Is this happening on the first timestep? Then I suggest trying out a debugger. We use totalview here, though the license is not free. Can you try a shorter timestep? Can you ask it to plot the fields before the trouble causes the job to crash so that you can see what is going on? I'm afraid there are no magic bullets - those of us with somewhat reasonable results have had to work through many crashes to get here (at least I know I have).
fdaryabor
vertical profile
#5 Unread post by fdaryabor »
Hikate
I attached temperature vertical profile yield of Roms output near coasts I'm looking for near coast looks should be wrong, because depth is inversely proportional to temperature. Could you please tell me why are wrong?
Best Regards
F.Daryabor
Temperature vertical profile1.png (4.28 KiB) Viewed 7259 times
Temperature vertical profile.png (4.99 KiB) Viewed 7262 times
#6 Unread post by kate »
Are these your initial conditions or some later state? Have you looked at your initial conditions? Where did they come from? You say this is temperature but the numbers and the shape remind me of density. What does the density look like? Is it the unstable bit in the middle that concerns you or the entire structure?
fdaryabor
#7 Unread post by fdaryabor »
Hi Kate
I attach for you 'romstools_param.m' file, this is alone the file for edit by user, you will see that I must edit only grid parameters for building the grid, surface forcing parameters for getting the wind and other surface fluxes and getting the initial and the lateral boundary conditions. According to those I define conditions for my region (South China Sea)in Roms Agrif version. In Roms Agrif version exist Roms_Agrif directory that is actually include main files (fortran file '.F')for set model initial conditions and solve the dynamic equations, user linked to those only vi CPP key 'cppdefs.h'. Could you please guide me.
Best Regards
F.Daryabor
Preprocessing_tools_2007_03_28.tar.gz
(44.5 KiB) Downloaded 439 times
Roms_Agrif_17_01_2006.tar.gz
(605.69 KiB) Downloaded 440 times
romstools_param.m
(12.11 KiB) Downloaded 454 times
#8 Unread post by kate »
I've said it before - I can answer some basic ROMS questions, but if you need help with specific tools that aren't part of the toolset I use, you have to find an expert in them elsewhere. Does ROMS_AGRIF have its own forum?
