Problem with tidal forcing
Markberg
Location: East China Sea Bureau, Ministry of Natural Resourc
#1 Unread post by Markberg »
Hello everyone
Everything is Ok, but i found ROMS failed to read minimum tidal current, ellipse minor axis
  GET_2DFLD   - maximum tidal current, ellipse major axis
                   (Grid = 01, Min =  0.00000000E+00 Max =  1.92168231E+01)
    GET_2DFLD   - minimum tidal current, ellipse minor axis
                   (Grid = 01, Min =             NaN Max =             NaN)
I dont know why this happened. I checked the value of tidal current
tidal current value
tidal current value
It do has value.
But l really don't know why ROMS can't read it.
yellowsea_forcing.nc
(11.32 MiB) Downloaded 784 times
Markberg
Re: Problem with tidal forcing
#2 Unread post by Markberg »
#define WET_DRY
#define SPLINES_VDIFF
#define SPLINES_VVISC
/*OPTIONS associated with momentum equations*/
 /*OPTIONS for horizontal mixing of momentum*/
 /*OPTIONS for horizontal mixing of tracers*/
#define MIX_GEO_TS
 /*OPTIONS associated with tracers equations*/
#undef QCORRECTION
#undef SCORRECTION
/*Pressure gradient algorithm OPTIONS*/
/*Model configuration OPTIONS*/
/*Sediment transport model OPTIONS*/
#undef SEDIMENT
#ifdef SEDIMENT
#undef ANA_SEDIMENT
#define SUSPLOAD
#define SED_MORPH
#undef BEDLOAD_MPM
#undef BEDLOAD_SOULSBY
#define ANA_SPFLUX
#define ANA_BPFLUX
#undef MIXED_BED
/*bottom boundary layer closure,define only one of the following*/
#undef UV_LOGDRAG
#define  UV_QDRAG
#undef MB_BBL
#undef SG_BBL
/*OPTIONS for analytical fields configuration aka climate foring FOR TIDE*/
/*OPTIONS for analytical fields configuration aka climate foring FOR WIND FIELD HAVE*/
#define BULK_FLUXES
#define ATM_PRESS
#define EMINUSP
#define SOLAR_SOURCE
#define LONGWAVE_OUT
 /*Vertical turbulent mixing*/
#define MY25_MIXING
#undef GLS_MIXING
#if defined MY25_MIXING
#  define RI_SPLINES
#  define KANTHA_CLAYSON
#  define N2S2_HORAVG
#  define CRAIG_BANNER
#  define CHARNOK
 /*TIDE*/
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
 /*Lateral boundary conditional*/
#define RADIATION_2D
 /*OUTPUT*/
#define PERFECT_RESTART
#define RST_SINGLE
#define DIAGNOSTICS_UV
#define DIAGNOSTICS_TS
#3 Unread post by wilkin »
It did read them. It's just telling you that somewhere in the file you have NaN values. They aren't on the boundary though otherwise ROMS would not have run.
