Moderators: arango , robertson
Markberg
Posts: 5 Joined: Thu Jan 04, 2024 3:34 am
Location: East China Sea Bureau, Ministry of Natural Resourc
#1
Unread post
by Markberg » Sun Feb 04, 2024 7:25 am
Hello everyone
Everything is Ok, but i found ROMS failed to read minimum tidal current, ellipse minor axis
(Grid = 01, Min = 0.00000000E+00 Max = 1.92168231E+01)
(Grid = 01, Min = NaN Max = NaN)
I dont know why this happened. I checked the value of tidal current
tidal current value
It do has value.
But l really don't know why ROMS can't read it.
yellowsea_forcing.nc
(11.32 MiB) Downloaded 160 times
Markberg
#2
Unread post
by Markberg » Sun Feb 04, 2024 8:19 am
#define WET_DRY
#define SPLINES_VDIFF
#define SPLINES_VVISC
/*OPTIONS associated with momentum equations*/
/*OPTIONS for horizontal mixing of momentum*/
/*OPTIONS for horizontal mixing of tracers*/
#define MIX_GEO_TS
/*OPTIONS associated with tracers equations*/
#undef QCORRECTION
#undef SCORRECTION
/*Pressure gradient algorithm OPTIONS*/
/*Model configuration OPTIONS*/
/*Sediment transport model OPTIONS*/
#undef SEDIMENT
#ifdef SEDIMENT
#undef ANA_SEDIMENT
#define SUSPLOAD
#define SED_MORPH
#undef BEDLOAD_MPM
#undef BEDLOAD_SOULSBY
#define ANA_SPFLUX
#define ANA_BPFLUX
#undef MIXED_BED
/*bottom boundary layer closure,define only one of the following*/
#undef UV_LOGDRAG
#undef MB_BBL
#undef SG_BBL
/*OPTIONS for analytical fields configuration aka climate foring FOR TIDE*/
/*OPTIONS for analytical fields configuration aka climate foring FOR WIND FIELD HAVE*/
#define BULK_FLUXES
#define ATM_PRESS
#define EMINUSP
#define SOLAR_SOURCE
#define LONGWAVE_OUT
/*Vertical turbulent mixing*/
#define MY25_MIXING
#undef GLS_MIXING
#if defined MY25_MIXING
# define RI_SPLINES
# define CRAIG_BANNER
# define CHARNOK
/*TIDE*/
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
/*Lateral boundary conditional*/
#define RADIATION_2D
/*OUTPUT*/
#define PERFECT_RESTART
#define RST_SINGLE
#define DIAGNOSTICS_UV
#define DIAGNOSTICS_TS
Posts: 922 Joined: Mon Apr 28, 2003 5:44 pm
Unread post
by wilkin » Sun Feb 04, 2024 1:13 pm
It did read them. It's just telling you that somewhere in the file you have NaN values. They aren't on the boundary though otherwise ROMS would not have run.
71 Dudley Rd, New Brunswick, NJ 08901-8521, USA. ph: 609-630-0559
jwilkin@rutgers.edu
