Opened 9 years ago
Closed 9 years ago
Last modified 9 years ago
#699 closed upgrade (Done)
NEED_VERSION needs to be extended for version 4.2
Reported by: m.hadfield Owned by: arango
Keywords: Cc:
In makefile at line 31 the NEED_VERSION variable is defined to admit versions from 3.80 through 4.1. Gnu make 4.2 has now been sighted in the wild and should be added.
Change History (3)
comment:1 by arango, 9 years ago
Description: modified (diff)
Resolution: Done
Status: newclosed
Good to know, thank you Mark!
comment:2 by m.hadfield, 9 years ago
And now Cygwin has upgraded make to 4.2.1!
I can see why this check was introduced, and why the limitations of make require the permitted versions to be hard-coded, but the updates are getting a bit tedious so perhaps it's time to drop it.
How about have make print a message like the following on every invocation:
"The ROMS makefile requires Gnu make with a version number > 3.80"
comment:3 by arango, 9 years ago
Yes, I changed to test to be instead:
ifneq (3.80,$(firstword $(sort $(MAKE_VERSION) 3.80)))
 $(error This makefile requires GNU make version 3.80 or higher. \
                Your current version is: $(MAKE_VERSION))
endif
Please update your code.
