Opened 9 years ago
Closed 9 years ago
#698 closed defect (Fixed)
Corrected bug def_mod.F and def_var.F
Component: | Nonlinear | Version: | 3.7 |
Description ¶
Corrected parallel warnings in the definition attributes for obs_provenance in def_mod.F. Also, added _FillValue to several variables so when netcdf_get_fval is used in the 4D-Var data assimilation algorithms the _FillValue entries are replaced with zero. This is a safeguard against spatial and temporal outliers in the input observation in the dual formulation algorithms.
Corrected the placement of the END IF in def_var.F:
IF (OutThread) THEN ... END IF
Change History (1)
comment:1 by , 9 years ago
Resolution: | → Fixed |
Status: | new → closed |
Type: | bug → defect |
Note:
See TracTickets
for help on using tickets.
