Hello
I run roms 2.2.
The model is working with passive tracer dye_01 initiated in the ini NetCDF file. But I want the dye to be put into the model with a river.
TS_MPDATA, TS_DIF2, TS_PSOURCE and UV_PSOURCE is defined inn cppdefs.h.
I added this to varinfo.dat
'river_dye_' ! Input
'river runoff dye concentration'
'kilogram meter-3' ! [kg/m3]
'river_dye, scalar, series'
'river_time'
'idRtrc(inert)'
'nulvar'
1.0d0
And I made a river forcing file with river_dye_01 with concentration=1 in the top layer. The model run without any problem, but no dye concentration was added to dye_01 in the history file.
The river_flag is set to 3 in the river forcing file.
Andre Staalstrom
Point sources of passive tracer
I've never used 2.2. But for the latest version of ROMS we can get using svn, there are more than one place we need to change to add point source for a passive tracer.
Some changes in Nonlinear/get_idata.F is required to turn on SOURCES(ng)%Lsrc and SOURCES(ng)%Ltracer for the added passive tracer. in Modules/mod_ncparam.F, you need to add a case for the index variable name you added in varinfo.dat. There might be more than these. I did it more than a year ago. These are what I can think of now.
Re: Point sources of passive tracer
I already use passive tracers in the initial condition successfully but now I want the dye to be put into the model with a river. Before starting modifying roms code I would ask to Andre Staalstrom if he finally have done it well and if I need to know more than what is written in this topic.
Thank you in advance,
Gianni.
Gianni.
