An error about filename in I4DVAR
smartboy
#1 Unread post by smartboy »
I'm running the I4DVAR for my real application. There is an error which is related to the netcdf filename. I'm comfused about this.
My ROMS version is 4.0, which is the newest one. The assimilation process runs pretty well. However, it says that "unable to open existing file". I have checked the directory. The netcdf filename is "YS_adj_outer2", which isn't the "YS_adj_outer2_001".
My question is whether there is some errors in the source code. How to change the wrong filename to correct one.
 <<<< Conjugate Gradient Algorithm >>>>
 (002,000): PRECOND - Ritz preconditioning: convert gradient to y-space
 (002,000): PRECOND - Reading Lanczos eigenpairs from:   ./YS_adj_outer2_001.nc
 Found Error: 02   Line: 8280     Source: ROMS/Modules/mod_netcdf.F, netcdf_open
               call from:  ROMS/Utility/cgradient.F, precond
               No such file or directory
 Found Error: 03   Line: 2805     Source: ROMS/Modules/mod_netcdf.F, netcdf_get_fvar_2d
 Found Error: 03   Line: 6626     Source: ROMS/Utility/cgradient.F, precond
 Found Error: 03   Line: 766      Source: ROMS/Utility/cgradient.F, cgradient_tile
 Found Error: 03   Line: 1452     Source: ROMS/Drivers/i4dvar.F, increment
 Found Error: 03   Line: 288      Source: ROMS/Drivers/i4dvar_roms.h, ROMS_run
