My ROMS version is 4.0, which is the newest one. The assimilation process runs pretty well. However, it says that "unable to open existing file". I have checked the directory. The netcdf filename is "YS_adj_outer2", which isn't the "YS_adj_outer2_001".
My question is whether there is some errors in the source code. How to change the wrong filename to correct one.
<<<< Conjugate Gradient Algorithm >>>>
(002,000): PRECOND - Ritz preconditioning: convert gradient to y-space
(002,000): PRECOND - Reading Lanczos eigenpairs from: ./YS_adj_outer2_001.nc
Found Error: 02 Line: 8280 Source: ROMS/Modules/mod_netcdf.F, netcdf_open
call from: ROMS/Utility/cgradient.F, precond
No such file or directory
Found Error: 03 Line: 2805 Source: ROMS/Modules/mod_netcdf.F, netcdf_get_fvar_2d
Found Error: 03 Line: 6626 Source: ROMS/Utility/cgradient.F, precond
Found Error: 03 Line: 766 Source: ROMS/Utility/cgradient.F, cgradient_tile
Found Error: 03 Line: 1452 Source: ROMS/Drivers/i4dvar.F, increment
Found Error: 03 Line: 288 Source: ROMS/Drivers/i4dvar_roms.h, ROMS_run
