Issue of exceptionally low velocity
neelbasak08
Location: Thapar Institute of Engineering and Technology, Patiala, PN, India
#1 Unread post by neelbasak08 »
Hello people!
I am facing an issue of exceptionally lower velocity than expected values in one of my simulation results. The expected velocities in my simulation should somewhere be in the range of 0.5 to 1 m/s for the timestamp but my outcomes of each individual momentum field variable at a given timestamp and vertical level are always in the order of ( 10^-3, 10^-4) when I try to visualise it in a pcolour MATLAB plot. I am not sure what is happening there. I tried to modify my quadratic bottom roughness coefficient by reducing it but that didn't help my cause as velocities tend to remain in the same order. This is a problem I am facing quite often. I am pretty sure I am doing something horribly wrong.
What might be the underlying reasons for this anomaly? I am using an external grid, tidal and wind forcing and my initial file is ana_initial. Rest all is pretty much standard ROMS provided dependencies.
My header file looks like this :
#define UV_VIS4
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define BULK_FLUXES
#define BODYFORCE
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_INITIAL
#define ANA_SSFLUX
#define ANA_DRAG
#define SSH_TIDES
#define UV_TIDES
#undef RAMP_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
And my parameters in the .in executable look something like this:
Resolution, Grid 01: 98x48x15, Parallel Threads: 1, Tiling: 1x1
6000 ntimes Number of timesteps for 3-D equations.
30.000 dt Timestep size (s) for 3-D equations.
360 nRST Number of timesteps between the writing of data
into restart fields.
360 ninfo Number of timesteps between print of information
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
0.0000E+00 nl_visc4 NLM Horizontal, biharmonic mixing coefficient
(m4/s) for momentum.
1.0000E+00 Akv_bak Background vertical mixing coefficient (m2/s)
2.6500E-04 rdrg Linear bottom drag coefficient (m/s).
2.0000E-03 Zob Bottom roughness (m).
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
12 levsfrc Deepest level to apply surface stress as a
bodyforce.
1 levbfrc Shallowest level to apply bottom stress as a
bodyforce.
8.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E+00 theta_b S-coordinate bottom control parameter.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
2922.000 dstart Time-stamp assigned to model initialization (days).
2922.000 tide_start Reference time origin for tidal forcing (days).
20000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
5.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
for 3D momentum.
5.000 T0 Background potential temperature (C) constant.
1028.000 R0 Background density (kg/m3) used in linear Equation
of State.
1.0000E-04 Tcoef Thermal expansion coefficient (1/Celsius).
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idPair) Write out surface air pressure.
T Hout(idTair) Write out surface air temperature.
T Hout(idUair) Write out surface U-wind component.
T Hout(idVair) Write out surface V-wind component.
Are there any possible modifications that I could try in my .in file executable so as to improve my u,v,w momentum values? Or it's a fundamental error in my grid file and forcing files?
Kind regards
-Neel
Re: Issue of exceptionally low velocity
How large are your wind stresses?
#3 Unread post by wilkin »
You have defined ANA_SMFLUX but also BULK_FLUXES. So I'm not sure what you actually got. Think more carefully about your setup.
neelbasak08
#4 Unread post by neelbasak08 »
Thanks kate!
I should say viewing my wind forcing file in MATLAB I could see my Vwind component is -7.81 to 5.92 and my Uwind component is -3.69 to 13.08
Wrote Uwind into record: , Min=-3.69736e+00 Max= 1.30849e+01
Wrote Vwind into record: , Min=-7.82741e+00 Max= 5.92142e+00
Wrote Pair into record: , Min= 1.00357e+03 Max= 1.01645e+03
Wrote Tair into record: , Min= 1.86757e+01 Max= 3.32195e+01
Wrote Qair into record: , Min= 4.70148e+01 Max= 9.98834e+01
Wrote swrad into record: , Min= 1.00000e-15 Max= 1.01897e+03
Wrote lwrad into record: , Min=-1.05019e+02 Max= 1.30638e+00
Wrote lwrad_down into record: , Min= 3.52393e+02 Max= 4.52409e+02
Wrote rain into record: , Min= 0.00000e+00 Max= 4.00162e-03
Thanks Mr. Wilkin!
If I don't define ANA_SMFLUX along with bulkfluxes then how will I write sustr and svstr fields into my output file? The wind forcing file doesn't include sustr and Svstr variables. Does having ANA_SMFLUX along with BULK_FLUXES make ROMS ignore the data in the external input wind file and take the defaults from ROMS source directory?
Would switching off ANA_SMFLUX in the header file and sustr and svstr in the .in executable mean that ROMS would no more calculate the wind stresses?
Kind regards
-Neel
#5 Unread post by wilkin »
The output of stresses does not require ANA_SMFLUX. ROMS can determine stresses analytically, from the bulk flux formulae, or from model coupling. Whatever it does, output is controlled by the relevant Hout option in roms.in.
The log file tells you what ROMS actually did. So read that closely. Look for the reported values of Uwind and Vwind that are read from the forcing files. If they are not read, then ROMS is probably using the analytical stresses.
Taking a quick look at the code I think BULK_FLUXES takes precedence over ANA_SMFLUX, so you should see the winds being read.
neelbasak08
#6 Unread post by neelbasak08 »
Well, Thanks, Mr Wilkin!
As in my log file, I can see that wind data has been read from my input forcing file itself.
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000001728)
GET_2DFLD - surface u-wind component, 2008-04-01 01:00:00.00
(Grid=01, Rec=2, Index=2, File: frc_MYAPPLICATION_ERA5_bulkflux_lombok_v3_grd_test_2008200804.nc)
(Tmin= 3013.0000 Tmax= 3042.9583) t = 3013.0417
(Min = 1.40022359E+00 Max = 5.95902807E+00) regrid = T
GET_2DFLD - surface v-wind component, 2008-04-01 01:00:00.00
(Min = -9.45137250E-01 Max = 2.37342291E+00) regrid = T
GET_2DFLD - surface air pressure, 2008-04-01 01:00:00.00
(Min = 1.01079358E+03 Max = 1.01316286E+03) regrid = T
etc......
That brings me back to my initial question, the wind input should be standard as it is from the ERA5 dataset, that shouldn't be the reason for my abnormal observation of velocities from the expected ones.
I see in my log:
(Grid = 01, Min = 5.00000000E+00 Max = 5.00000000E+00)
GET_NGFLD - tidal period
(Grid = 01, Min = 2.19720214E+04 Max = 2.38071314E+06)
(Grid = 01, Min = 0.00000000E+00 Max = 6.75112534E-01)
(Grid = 01, Min = 0.00000000E+00 Max = 6.25560811E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.14146610E+00)
etc.............
I am not sure whether ROMS is reading the tidal data from my input tidal file. It should be reading it as I've defined SSH_TIDES and UV_TIDES in my header and input the tpxo NetCDF file in the TIDENAME== field as well in my .in executable file. Is defining ANA_INITIAL, ANA_M2OBC and ANA_FSOBC causing it? Or is it some other reason that is causing these low velocities?
Kind regards
-Neel
error.txt
(102.4 KiB) Downloaded 960 times
neelbasak08
#7 Unread post by neelbasak08 »
Thanks Mr. Wilkin!
As per your suggestion, I remove ANA_SMFLUX from my header file and removed ANA_FSOBC and ANA_M2OBC as well. Just defined bulkflux and other previous headers.
I see an improvement in my velocity profile where its order changed from a factor of 10^(-4) to 10^(-3), but it's still not in the desired order of 10^(-1) to 10^(0). Is there anything more that I might be doing wrong?
I see the following section in my terminal log:
(Grid = 01, Min = 0.00000000E+00 Max = 6.28317974E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 2.37040469E-01)
(Grid = 01, Min = -1.00770225E-03 Max = 5.12410660E-02)
I am not sure where ROMS is getting my tidal data from my input tidal file. If that's the case, then why is it not fetching data from my tidal forcing, I can see it has read it
Output Restart File: Lombok_roms_rst.nc
Output History File: Lombok_roms_his.nc
Input Grid File: /home/sbasak08/roms/Projects/Lombok_Straits/lombok_v3_grd_test.nc
Tidal Forcing File: lombok_v3_grd_test01Jan2020_v5.nc
Input Forcing File 01: lombok_v3_grd_test01Jan2020_v5.nc
Input Forcing File 02: frc_MYAPPLICATION_ERA5_bulkflux_lombok_v3_grd_test_2008202001.nc
ROMS I/O variables Metadata File: External/varinfo.dat
As to Kate's question on how my wind stresses look like, it shows something like the following at my final timestamp:
GET_2DFLD - surface u-wind component, 2020-01-01 23:00:00.00
(Grid=01, Rec=24, Index=2, File: frc_MYAPPLICATION_ERA5_bulkflux_lombok_v3_grd_test_2008202001.nc)
(Tmin= 3013.0000 Tmax= 3042.9583) t = 3013.9583
(Min = -3.03207905E-02 Max = 3.75902466E+00) regrid = T
GET_2DFLD - surface v-wind component, 2020-01-01 23:00:00.00
(Min = -8.90646992E-01 Max = 1.98579395E+00) regrid = T
What could I be doing wrong, that my velocities in the output file are such extremely low? Is there any way to fix these issues?
Kind regards
-Neel
without ana_smflux_error.txt
log file
(102.26 KiB) Downloaded 935 times
#8 Unread post by wilkin »
Your log file shows all open boundaries are "Closed". You need Chapman and Flather conditions for the tides to be active. Set the appropriate LBC options in roms.in
neelbasak08
#9 Unread post by neelbasak08 »
Thanks Mr. Wilkin!
I had intentionally changed all my LBCs to Closed from Chapman and Flather because I had removed ANA_FSOBC and ANA_M2OBC from my header file and keeping the Cha and Fla would prompt ROMS to ask for rooms bry.nc file, which I am not using.
Anyways, working again on your suggestion, adding ANA_FSOBC and ANA_M2OBC and changing 3Dmomentum, mixing and free surface to Cha and 2D momentum to FLA, my iteration stops without throwing any sort of error:
GET_2DFLD - surface air temperature, 2020-01-01 01:00:00.00
(Tmin= 3013.0000 Tmax= 3042.9583) t = 3287.0417
(Min = 2.11882052E+01 Max = 2.62729494E+01) regrid = T
GET_2DFLD - surface air relative humidity, 2020-01-01 01:00:00.00
(Min = 8.23352521E-01 Max = 9.56464556E-01) regrid = T
GET_2DFLD - rain fall rate, 2020-01-01 01:00:00.00
(Min = 2.27629357E-05 Max = 2.83370387E-03) regrid = T
0 2020-01-01 00:00:00.00 -0.000000E+00 -6.569793E+04 -6.569793E+04 -2.031882E+11
(00,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: Lombok_roms_his.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 1
sbasak08@DESKTOP-UOIVLQT:~/roms/Projects/Lombok_Straits$
I've been using the same grid, same tidal forcing and same wind file as I used earlier. And I never faced this kind of issue in them. The simulation worked fine. Here it just stops while performing the first time step iteration.
Kind regards
-Neel
lombok.h
header file
(1.04 KiB) Downloaded 693 times
log_file.txt
(29.4 KiB) Downloaded 670 times
