I/O error
19zsheng
I/O error
#1 Unread post by 19zsheng »
hello
I had met an error, the error is as follows.
Tuesday - January 26, 2021 - 5:02:23 PM
TWS MODEL
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /opt/mpich/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script :
SVN Revision :
Local Root : /home/19zsheng/sz_roms
Header Dir : /home/19zsheng/sz_roms
Header file : tws.h
Analytical Dir: /home/19zsheng/sz_roms/User/Functionals
Resolution, Grid 01: 0418x0382x025, Parallel Nodes: 32, Tiling: 004x008
14400 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
14400 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1440 nHIS Number of timesteps between the writing fields
into history file.
0 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
1440 nAVG Number of timesteps between the writing of
1.2000E+02 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
5.0000E+02 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
5.0000E-05 Akt_bak(01) Background vertical mixing coefficient (m2/s)
5.0000E-05 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
2.0000E-04 Akv_bak Background vertical mixing coefficient (m2/s)
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1 lmd_Jwt Jerlov water type.
43130.000 dstart Time-stamp assigned to model initialization (days).
19000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
T LuvSrc Turning ON momentum point Sources/Sinks.
T LtracerSrc(01) Turning ON point Sources/Sinks on tracer 01: temp
T LtracerSrc(02) Turning ON point Sources/Sinks on tracer 02: salt
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Aout(idDano) Write out averaged density anomaly.
T Aout(idVvis) Write out averaged vertical viscosity: AKv.
T Aout(idSdif) Write out averaged vertical diffusion: AKt(isalt).
T Aout(id3dRV) Write out averaged 3D relative vorticity.
Output Restart File: ../res1/ocean_rst.nc
Output History File: ../res1/ocean_his.nc
Output Averages File: ../res1/ocean_avg.nc
Input Grid File: Data/ROMS/Initial/sz_grid.nc
Input Nonlinear Initial File: Data/ROMS/Initial/sz_ini_ECCO_Y2018M2.nc
READ_PHYPAR - could not find input file: |0~|ZCd/+.Dd/+/Dd/+ |G}ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ERROR: I/O related problem.
I can't solve this mistake. I wish someone could help me.
Thank you!
tws.in
(119.63 KiB) Downloaded 766 times
tws.h
(1.89 KiB) Downloaded 780 times
robertson
Re: I/O error
#2 Unread post by robertson »
When I open your .in and .h files my editor says they are "dos" format. However, from your log output it does not look like you are running on a windows system. Did you, by chance, edit these files in Windows? If your system has 'dos2unix' run that on any files you edited in Windows. If not you can try the following on all the relevant files:
perl -pi -e 's/\r\n/\n/g' <filename>
Note that both those commands are only to be run on text files not binary (NetCDF) files.
If that's not the issue then is it possible that some of your input NetCDF files have non-ASCII characters in the filename?
19zsheng
Re: I/O error
#3 Unread post by 19zsheng »
First of all, thank you!
Strangely enough, when I was running on the South Sea server it was normal to copy to my own server and this error appeared. why?
robertson
Re: I/O error
#4 Unread post by robertson »
Maybe something was corrupted during transfer? What command(s) did you use to transfer to your own server? What operating system is "South Sea" and what operating system is your "own server"?
19zsheng
Re: I/O error
#5 Unread post by 19zsheng »
Thanks again for your help.
When I set the parameters in the .in file as shown in the image below, my problem is solved, but I don't know why?
