Hi everyone,
I have a problem when I run the COAWST model with WRF+ROMS+SWAN coupling option.
The PRINT01-001 file displayed that:
&COMPUTE STAT 20161016.000000
COMPUTE NONSTAT 20161016.000000 30 MIN 20161018.000000
** Warning : Quadruplets will be updated per iteration
** Warning : instead of per sweep. This will increase
** Warning : amount of internal memory with a factor 2
** Error : It is not recommended to use quadruplets
** Error : in combination with zero wind conditions.
** No start of computation because of error level: 2
I haven't seen any problem in the coawst.out file. I have attached these files in this post.
Please help me to address it.
Many thanks,
-Manh,
Error to run coupling WRF+ROMS+SWAN
PRINT01-001.txt
- (7.58 KiB) Downloaded 528 times
coawst.out.txt
- (20.02 KiB) Downloaded 522 times
Re: Error to run coupling WRF+ROMS+SWAN
this is an error from SWAN. it is saying
"Error : It is not recommended to use quadruplets
Error : in combination with zero wind conditions."
Also looks like you turned off the winds:
!&& KEYWORD TO CREATE WIND GRID &&
!INPGRID WIND REGULAR -105 10 0 220 160 0.25 0.25 &
! NONSTATIONARY 20121028.000000 6 HR 20121031.000000
!&READINP WIND 1 'Projects/Sarika4/swan_GFS_Oct2012.dat' 4 0 FREE
So you cant run SWAN with 0 winds and quadruplets on.
Hi John,
I see the information in the COAWST manual like that:
So, can I do to run with my case?
Thank you very much!
-Manh
In my case, I ran SWAN with WRF, so I do not need the winds data, right?If not coupled to wrf, you need to download wind data from somewhere and create an ascii wind forcing file. See the SWAN manual as to the format.
-Manh
try this
&READINP WIND 1 'Projects/Sandy/swan_GFS_Oct2012.dat' 4 0 FREE
this sets the INPGRID for WIND, so then SWAN knows that it will get wind on a grid.
Then comment the line to READ the wind, like above. then swan will use the winds from wrf, not from a file.
Hi John,
This is my swan's namelist file:
Has it been set-up right? The detail is included in my attachment.
Many thanks,
-Manh
This is my Bound_spec_command file:&& KEYWORDS TO CREATE AND READ COMPUTATIONAL GRID &&
CGRID CURVILINEAR 299 219 EXC 9.999000e+003 9.999000e+003 CIRCLE 36 0.04 1.0 24
READGRID COORDINATES 1 'Projects/Sarika/swan_coord.grd' 4 0 0 FREE
&& KEYWORDS TO CREATE AND READ BATHYMETRY GRID &&
INPGRID BOTTOM CURVILINEAR 0 0 299 219 EXC 9.999000e+003
READINP BOTTOM 1 'Projects/Sarika/swan_bathy.bot' 4 0 FREE
&& KEYWORD TO CREATE CURRENT GRID &&
INPGRID CURRENT CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
NONSTATIONARY 20161016.000000 2 DAY 20161018.000000
&& KEYWORD TO CREATE WATER LEVEL GRID &&
INPGRID WLEV CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
&& KEYWORD TO CREATE BOTTOM FRIC GRID &&
INPGRID FRIC CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
INPGRID WIND REGULAR 0 0 299 219 0.25 0.25 &
NONSTATIONARY 20161016.000000 6 HR 20161018.000000
!&READINP WIND 1 'Projects/Sarika_new/swan_GFS_Oct2012.dat' 4 0 FREE
& Boundary files ****************************************
BOUND SHAPESPEC JONSWAP MEAN DSPR DEGREES
BOUNDSPEC SEGMENT IJ 0 0 0 219 CONSTANT PAR 0.1 20.0 0.0 15
BOUNDSPEC SEGMENT IJ 0 0 299 0 CONSTANT PAR 0.1 20.0 0.0 15
BOUNDSPEC SEGMENT IJ 299 0 299 219 CONSTANT PAR 0.1 20.0 0.0 15
BOUNDSPEC SEGMENT IJ 0 219 299 219 CONSTANT PAR 0.1 20.0 0.0 15
Many thanks,
-Manh
swan_sarika.in.txt
- (4.03 KiB) Downloaded 517 times
SWAN uses the symbol & for a comment line, not !
Does this work:
This is getting more into COAWST issues not roms.
so if you are still having troubles then post on the coawst github
https://github.com/jcwarner-usgs/COAWST
The Sandy case should run as distributed.
Does this work:
