Error to run coupling WRF+ROMS+SWAN
agpc
#1 Unread post by agpc »
Hi everyone,
I have a problem when I run the COAWST model with WRF+ROMS+SWAN coupling option.
The PRINT01-001 file displayed that:
&COMPUTE STAT 20161016.000000
COMPUTE NONSTAT 20161016.000000 30 MIN 20161018.000000
** Warning : Quadruplets will be updated per iteration
** Warning : instead of per sweep. This will increase
** Warning : amount of internal memory with a factor 2
** Error : It is not recommended to use quadruplets
** Error : in combination with zero wind conditions.
** No start of computation because of error level: 2
I haven't seen any problem in the coawst.out file. I have attached these files in this post.
Please help me to address it.
Many thanks,
-Manh,
PRINT01-001.txt
(7.58 KiB) Downloaded 658 times
coawst.out.txt
(20.02 KiB) Downloaded 648 times
Re: Error to run coupling WRF+ROMS+SWAN
this is an error from SWAN. it is saying
"Error : It is not recommended to use quadruplets
Error : in combination with zero wind conditions."
Also looks like you turned off the winds:
!&& KEYWORD TO CREATE WIND GRID &&
!INPGRID WIND REGULAR -105 10 0 220 160 0.25 0.25 &
! NONSTATIONARY 20121028.000000 6 HR 20121031.000000
!&READINP WIND 1 'Projects/Sarika4/swan_GFS_Oct2012.dat' 4 0 FREE
So you cant run SWAN with 0 winds and quadruplets on.
agpc
#3 Unread post by agpc »
Hi John,
I see the information in the COAWST manual like that:
If not coupled to wrf, you need to download wind data from somewhere and create an ascii wind forcing file. See the SWAN manual as to the format.
In my case, I ran SWAN with WRF, so I do not need the winds data, right?
So, can I do to run with my case?
Thank you very much!
-Manh
#4 Unread post by jcwarner »
try this
&READINP WIND 1 'Projects/Sandy/swan_GFS_Oct2012.dat' 4 0 FREE
this sets the INPGRID for WIND, so then SWAN knows that it will get wind on a grid.
Then comment the line to READ the wind, like above. then swan will use the winds from wrf, not from a file.
agpc
#5 Unread post by agpc »
Hi John,
This is my swan's namelist file:
&& KEYWORDS TO CREATE AND READ COMPUTATIONAL GRID &&
CGRID CURVILINEAR 299 219 EXC 9.999000e+003 9.999000e+003 CIRCLE 36 0.04 1.0 24
READGRID COORDINATES 1 'Projects/Sarika/swan_coord.grd' 4 0 0 FREE
&& KEYWORDS TO CREATE AND READ BATHYMETRY GRID &&
INPGRID BOTTOM CURVILINEAR 0 0 299 219 EXC 9.999000e+003
READINP BOTTOM 1 'Projects/Sarika/swan_bathy.bot' 4 0 FREE
&& KEYWORD TO CREATE CURRENT GRID &&
INPGRID CURRENT CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
NONSTATIONARY 20161016.000000 2 DAY 20161018.000000
&& KEYWORD TO CREATE WATER LEVEL GRID &&
INPGRID WLEV CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
&& KEYWORD TO CREATE BOTTOM FRIC GRID &&
INPGRID FRIC CURVILINEAR 0 0 299 219 EXC 9.999000e+003 &
INPGRID WIND REGULAR 0 0 299 219 0.25 0.25 &
NONSTATIONARY 20161016.000000 6 HR 20161018.000000
!&READINP WIND 1 'Projects/Sarika_new/swan_GFS_Oct2012.dat' 4 0 FREE
This is my Bound_spec_command file:
& Boundary files  ****************************************
BOUND SHAPESPEC JONSWAP MEAN DSPR DEGREES
BOUNDSPEC SEGMENT IJ    0    0    0   219 CONSTANT PAR  0.1  20.0    0.0  15
BOUNDSPEC SEGMENT IJ    0    0  299     0 CONSTANT PAR  0.1  20.0    0.0  15
BOUNDSPEC SEGMENT IJ  299    0  299   219 CONSTANT PAR  0.1  20.0    0.0  15
BOUNDSPEC SEGMENT IJ    0  219  299   219 CONSTANT PAR  0.1  20.0    0.0  15
Has it been set-up right? The detail is included in my attachment.
Many thanks,
-Manh
swan_sarika.in.txt
(4.03 KiB) Downloaded 642 times
#6 Unread post by jcwarner »
SWAN uses the symbol & for a comment line, not !
Does this work:
This is getting more into COAWST issues not roms.
so if you are still having troubles then post on the coawst github
https://github.com/jcwarner-usgs/COAWST
The Sandy case should run as distributed.
