Hi , I am currently new to ROMS, compile is successful, but I got the error messgae when trying to run the default upwelling case,
I used the following command :
mpirun -np 4 romsM ./External/roms_upwelling.in > & log &
the error message is follows:
Does anybody has same problems before? any suggestion might help, Thanks in advance.
upwelling case READ_PHYPAR - Variable index not yet loaded, idStr
Re: upwelling case READ_PHYPAR - Variable index not yet loaded, idStr
You need to use a varinfo.dat file which is consistent with your ROMS version. idStr is in some varinfo.dat files:
'strain' ! Output
'strain'
'second-1' ! [1/s]
'strain, scalar, series'
'ocean_time'
'idStr'
'p3dvar'
1.0d0
