Add the path of a new Fortran90 file
Minjie_Xu
#1 Unread post by Minjie_Xu »
I want to add a new mod.F90 to the ROMS. Which file do I need to add the path of this mod.F90 to?
If I change the suffix .F90 to .F, the program can be compiled successfully
Re: Add the path of a new Fortran90 file
The makefile has rules for going from .F files to .f90 files to compile them into .o files. You would have to add rules for .F90 files if you refuse to rename your file.
Minjie_Xu
#3 Unread post by Minjie_Xu »
Thanks for your help!
What rules do I need to add to makefile? Is it added in lines 181-195?
Minjie_Xu
#4 Unread post by Minjie_Xu »
kate wrote: Wed Jul 01, 2020 5:01 am The makefile has rules for going from .F files to .f90 files to compile them into .o files. You would have to add rules for .F90 files if you refuse to rename your file.
#5 Unread post by kate »
I don't think so. It instead uses:
define compile-rules
  $(foreach f, $(local_src),       \
    $(call one-compile-rule,$(call source-to-object,$f), \
    $(call f90-source,$f),$f))
endef
and friends. The compile-rules function is called in the Module.mk files.
#6 Unread post by kate »
If I were to overhaul this now, I would check to see if the compilers now in use can all invoke the C-preprocessor automatically for .F90 files. If so, take out the cpp step and the cpp_clean step and just have compile-time errors point to the line number of the .F90 file. I did once meet a compiler that would not invoke cpp correctly and that's why things are the way they are in the build system - but that was a long time ago.
