inconsistent explicit time-step splitting in two-way nesting
xupeng66
#1 Unread post by xupeng66 »
Here is follow-up on a problem I posted previously. I did a two-way nested simulation of the outward propagation of surface gravity waves from the a collapsed sea-surface mound (see attached animation). The horizontal resolutions of the small domain is 5 times that of the large domain. There is no forcing other than the surface mound in the initial conditions. The seafloor is flat and has a depth of 100 m.
In my previous post, I mentioned an issue of emergency bailout when using MPI. I took the advice from the developer and changed the grid size of the two nested domains so that the numbers of grid points on each side are uneven. This had first appeared to solve the problem as the MPI run finished without bailout. However, it seemed that I celebrated too soon because the same bailout issue occurred when I tried a different number of processors. I then did a debug run and the following is the diagnostics, which report 'illegal model configuration' and ' CHECKDEFS - explicit time-step splitting is inconsistent'.
Another issue I noticed is that, although there is no stratification in temperature, which is set to 2 degree C in initial conditions for both grids, anomalies appear to show up in the small domain as can be seen in the second animation, which shows the temperature anomaly (absolute minus 2 degree) at 20 m over the small, fine-resolution domain. Those numerical anomalies in temperature show up in both serial and MPI runs and reducing the time step used for the small domain does not seem to help.
I think those temperature anomalies are probably caused by the error in model configuration, but I have no idea how to further diagnose the problem. Could anyone give some advice?
Thanks in advance!
 Model Input Parameters:  ROMS/TOMS version 3.9
                          Sunday - June 21, 2020 - 12:13:26 PM
 A Gaussian Mound Collapsing and Generating Surface Gravity Waves
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /vortexfs1/apps/intel/compilers_and_libraries_2018.2.199/linux/bin/intel64/ifort
 Compiler flags   : -fp-model precise -heap-arrays -g -check all -check bounds -traceback -check uninit -warn interfaces,nouncalled -gen-interfaces
 GIT Root URL     :
 GIT Revision     :
 SVN Root URL     : https://www.myroms.org/svn/src/trunk
 SVN Revision     : 1014
 Local Root       : /vortexfs1/scratch/gxu/ROMS_test/Source
 Header Dir       : /vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include
 Header file      : gauss_mound.h
 Analytical Dir   : /vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include
 Resolution, Grid 01: 128x140x10,  Parallel Threads: 1,  Tiling: 1x1
        160  ntimes            Number of timesteps for 3-D equations.
     90.000  dt                Timestep size (s) for 3-D equations.
         30  ndtfast           Number of timesteps for 2-D equations between
          0  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
          5  nHIS              Number of timesteps between the writing fields
                                 into history file.
          0  nQCK              Number of timesteps between the writing fields
                                 into quicksave file.
 3.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 5.0000E+02  obcfac            Factor between passive and active
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
               Output Restart File:  roms_rst.nc
               Output History File:  gauss_mound_his_coarse.nc
                   Input Grid File:  ./input/gauss_mound_grid_uniform_coarse2.nc
    Nesting grid connectivity File:  ./input/gauss_mound_ngc_refine2.nc
      Input Nonlinear Initial File:  ./input/gauss_mound_ini_coarse2.nc
  ROMS I/O variables Metadata File:  ./include/varinfo.dat
 Resolution, Grid 02: 110x160x10,  Parallel Threads: 1,  Tiling: 1x1
 Physical Parameters, Grid: 02
       1600  ntimes            Number of timesteps for 3-D equations.
      9.000  dt                Timestep size (s) for 3-D equations.
                                 to standard output.
         50  nHIS              Number of timesteps between the writing fields
                                 into history file.
               Output History File:  gauss_mound_his_fine.nc
                   Input Grid File:  ./input/gauss_mound_grid_uniform_fine2.nc
      Input Nonlinear Initial File:  ./input/gauss_mound_ini_fine2.nc
 Tile partition information for Grid 01:  128x140  tiling: 1x1
        0        1      128        1      140    17920
 Tile partition information for Grid 02:  110x160  tiling: 1x1
        0        1      110        1      160    17600
   (interior points only)
        0     0.50   129.50     0.50   141.50  RHO-points
        0     0.00   129.00     0.50   141.50    U-points
        0     0.50   129.50     0.00   141.00    V-points
 Tile minimum and maximum fractional coordinates for Grid 02:
        0    -2.50   112.50    -2.50   162.50  RHO-points
        0    -3.00   112.00    -2.50   162.50    U-points
        0    -2.50   112.50    -3.00   162.00    V-points
 zeta                     1   Chapman Imp  Chapman Imp  Chapman Imp  Chapman Imp
                          2   Nested       Nested       Nested       Nested
 ubar                     1   Shchepetkin  Shchepetkin  Shchepetkin  Shchepetkin
 vbar                     1   Shchepetkin  Shchepetkin  Shchepetkin  Shchepetkin
 GAUSSIAN_MOUND          A Gaussian Mound Collapsing and Generating Surface Gravity Waves
 ANA_BTFLUX              Analytical kinematic bottom temperature flux
 ANA_FSOBC               Analytical free-surface boundary conditions
 ANA_M2OBC               Analytical 2D momentum boundary conditions
 ANA_SMFLUX              Analytical kinematic surface momentum flux
 ANA_STFLUX              Analytical kinematic surface temperature flux
 ASSUMED_SHAPE           Using assumed-shape arrays
 DJ_GRADPS               Parabolic Splines density Jacobian (Shchepetkin, 2002)
 DOUBLE_PRECISION        Double precision arithmetic numerical kernel.
 NESTING                 Nesting grids: Composite and Refinement
 NONLINEAR               Nonlinear Model
 !ONE_WAY                Two-way nesting in refinement grids
 PROFILE                 Time profiling activated
 RADIATION_2D            Use tangential phase speed in radiation conditions
 !RST_SINGLE             Double precision fields in restart NetCDF file
 UV_ADV                  Advection of momentum
 UV_COR                  Coriolis term
 UV_QDRAG                Quadratic bottom stress
 CHECKDEFS - explicit time-step splitting is  inconsistent.
             Change parameter NDTFAST to unity.
 Found Error: 05   Line: 1210     Source: ROMS/Utility/inp_par.F
 Found Error: 05   Line: 112      Source: ROMS/Drivers/nl_ocean.h
 Dynamic and Automatic memory (MB) usage for Grid 01:  128x140  tiling: 1x1
     tile          Dynamic        Automatic            USAGE
        0             3.87             6.03             9.90
      SUM             3.87             6.03             9.90
 Dynamic and Automatic memory (MB) usage for Grid 02:  110x160  tiling: 1x1
        0             0.57             5.94             6.50
      SUM             0.57             5.94             6.50
    TOTAL             4.43            11.97            16.41
 ROMS/TOMS - Output NetCDF summary for Grid 02:
 Found Error: 05   Line: 334      Source: ROMS/Utility/close_io.F
 ROMS/TOMS - Configuration error ..... exit_flag:   5
Re: inconsistent explicit time-step splitting in two-way nesting
Well, the error is telling your problem, if you think carefully about it. I assume that you previously defined SOLVE3D. Now, it is undefined, and you are solving the shallow-water equations of ROMS where you must have NDTFAST =1 for all nested grids, and you have NDTFAST = 30 :!: If you don't understand that, you need to read the literature about what the explicit time-step splitting solution of the shallow-water equations means and why. By the way, if SOLVE3D is undefined, there are NOT tracers in the ROMS governing equations. So, I don't know how you can plot the temperature from such a solution! It is impossible for the distributed version of ROMS to write out the temperature in a shallow-water configuration that only runs the step2d kernel. When in doubt, check the *.f90 files in the Build_roms subdirectory. Those files only include the code compiled according to your CPP options.
xupeng66
#3 Unread post by xupeng66 »
Thanks again for your feedback, Arango. Those animations were generated from a serial run that finished without apparent blow up. The error message was actually from a debug run, which I now realize was in barotropic mode by default. So I now see that the error message is not related to the numerical anomalies in temperature.
On the other hand, when I run the same simulation using MPI with only one processor, the run quickly blew up within the first few time steps as indicated in the on-screen output below. When I use more than more processor, the blow up still happened but later. I think those numerical anomalies in temperature from the serial run are likely related to the cause of the blow up when using MPI.
Maybe this is a telltale sign that the two-way nested grids were not set up properly?
Tuesday - June 23, 2020 - 12:59:28 PM
Compiler command : /vortexfs1/apps/openmpi-3.0.1-intel/bin/mpif90
Compiler flags : -fp-model precise -heap-arrays -ip -O3 -traceback -check uninit
MPI Communicator : 0 PET size = 1
Input Script : include/roms_gauss_mound.in
GIT Root URL :
GIT Revision :
SVN Revision : 1014
Resolution, Grid 01: 128x140x10, Parallel Nodes: 1, Tiling: 1x1
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
Resolution, Grid 02: 110x160x10, Parallel Nodes: 1, Tiling: 1x1
to standard output.
into history file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
Tile partition information for Grid 01: 128x140x10 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 128 1 140 179200
Tile partition information for Grid 02: 110x160x10 tiling: 1x1
0 1 110 1 160 176000
tile Xmin Xmax Ymin Ymax grid
0 0.50 128.50 0.50 140.50 RHO-points
0 1.00 128.00 0.50 140.50 U-points
0 0.50 128.50 1.00 140.00 V-points
0 0.50 110.50 0.50 160.50 RHO-points
0 1.00 110.00 0.50 160.50 U-points
0 0.50 110.50 1.00 160.00 V-points
HaloSizeI(1) = 417
HaloSizeJ(1) = 453
TileSide(1) = 145
TileSize(1) = 19285
HaloSizeI(2) = 375
HaloSizeJ(2) = 525
TileSide(2) = 169
TileSize(2) = 20111
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
2 e.F:mp_bcas
salt 1 Upstream3 Centered4
2 ti
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
u 1 Radiation Radiation Radiation Radiation
v 1 Radiation Radiation Radiation Radiation
temp 1 Radiation Radiation Radiation Radiation
salt 1 Gradient Gradient Gradient Gradient
ANA_M3OBC Analytical 3D momentum boundary conditions
ANA_TOBC Analytical tracers boundary conditions
ANA_VMIX Analytical vertical mixing coefficients
!ASSEMBLE_ALL... Using mpi_isend/mpi_recv in mp_assemble routine
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
MPI MPI distributed-memory configuration
!NONLIN_EOS Linear Equation of State for seawater
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine
Process Information:
Node # 0 (pid= 150568) is active.
GET_GRID - angle between XI-axis and EAST: angler
(Grid = 01, File: ./input/gauss_mound_grid_uniform_coarse2.nc)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 2.50000000E-04 Max = 2.50000000E-04)
GET_GRID - reciprocal ETA-grid spacing: pn
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 1.04909955E-04 Max = 1.04909955E-04)
GET_GRID - bathymetry at RHO-points: h
(Min = 1.00000000E+02 Max = 1.00000000E+02)
GET_GRID - x-location of RHO-points: x-rho
(Min = -2.00000000E+03 Max = 5.14000000E+05)
GET_GRID - y-location of RHO-points: y_rho
(Min = -2.00000000E+03 Max = 5.62000000E+05)
GET_GRID - x-location of PSI-points: x_psi
(Min = 0.00000000E+00 Max = 5.12000000E+05)
GET_GRID - y-location of PSI-points: y-psi
(Min = 0.00000000E+00 Max = 5.60000000E+05)
GET_GRID - x-location of U-points: x_u
GET_GRID - y-location of U-points: y_u
GET_GRID - x-location of V-points: x_v
GET_GRID - y-location of V-points: y_v
(Grid = 02, File: ./input/gauss_mound_grid_uniform_fine2.nc)
(Min = 1.25000000E-03 Max = 1.25000000E-03)
(Min = 1.19600000E+05 Max = 2.08400000E+05)
(Min = 1.31600000E+05 Max = 2.60400000E+05)
(Min = 1.20000000E+05 Max = 2.08000000E+05)
(Min = 1.32000000E+05 Max = 2.60000000E+05)
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0050000 -2.400 -1.313 -2.400 -2.400
8 -0.2000000 -0.0204535 -5.636 -2.756 -5.636 -5.636
7 -0.3000000 -0.0477616 -9.821 -4.347 -9.821 -9.821
6 -0.4000000 -0.0894007 -15.152 -6.118 -15.152 -15.152
5 -0.5000000 -0.1491465 -21.932 -8.114 -21.932 -21.932
4 -0.6000000 -0.2324164 -30.593 -10.405 -30.593 -30.593
3 -0.7000000 -0.3467612 -41.741 -13.085 -41.741 -41.741
2 -0.8000000 -0.5025493 -56.204 -16.282 -56.204 -56.204
1 -0.9000000 -0.7139071 -75.113 -20.174 -75.113 -75.113
0 -1.0000000 -1.0000000 -100.000 -25.000 -100.000 -100.000
Vertical S-coordinate System, Grid 02:
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Time Splitting Weights for Grid 02: ndtfast = 30 nfast = 42
Minimum X-grid spacing, DXmin = 4.00000000E+00 km
Maximum X-grid spacing, DXmax = 4.00000000E+00 km
Minimum Y-grid spacing, DYmin = 4.00000000E+00 km
Maximum Y-grid spacing, DYmax = 4.00000000E+00 km
Minimum Z-grid spacing, DZmin = 2.40000180E+00 m
Maximum Z-grid spacing, DZmax = 2.48874290E+01 m
Minimum barotropic Courant Number = 3.32208519E-02
Maximum barotropic Courant Number = 3.32208519E-02
Maximum Coriolis Courant Number = 9.44189596E-03
Metrics information for Grid 02:
Minimum X-grid spacing, DXmin = 8.00000000E-01 km
Maximum X-grid spacing, DXmax = 8.00000000E-01 km
Minimum Y-grid spacing, DYmin = 8.00000000E-01 km
Maximum Y-grid spacing, DYmax = 8.00000000E-01 km
Minimum barotropic Courant Number = 1.66104259E-02
Maximum barotropic Courant Number = 1.66104259E-02
Maximum Coriolis Courant Number = 9.44189596E-04
Refined Nested Grid(s) Information:
Refined Donor Refined Timestep Refined
Grid Grid Scale Ratio Timesteps
02 01 05 10.00000 10
WARNING: Usually the number of Refined Timesteps must be the same
as the Refined Scale for numerical stability.
NLM: GET_STATE - Reading state initial conditions, 0001-01-01 00:00:00.00
(Grid 01, t = 0.0000, File: gauss_mound_ini_coarse2.nc, Rec=0001, Index=1)
- free-surface
(Min = 4.87527721-159 Max = 1.96039735E+00)
- u-momentum component
- v-momentum component
- potential temperature
(Min = 2.00000000E+00 Max = 2.00000000E+00)
- salinity
(Min = 3.50000000E+01 Max = 3.50000000E+01)
(Grid 02, t = 0.0000, File: gauss_mound_ini_fine2.nc, Rec=0001, Index=1)
- free-surface
(Min = 8.70062615E-44 Max = 2.93293903E-03)
- salinity
Maximum grid stiffness ratios: rx0 = 0.000000E+00 (Beckmann and Haidvogel)
rx1 = 0.000000E+00 (Haney)
Initial domain volumes: TotVolume = 2.8672000000E+13 m3
MinCellVol = 3.8400028818E+07 m3
MaxCellVol = 3.9819886406E+08 m3
Max/Min = 1.0369754303E+01
Basin information for Grid 02:
Initial domain volumes: TotVolume = 1.1264000000E+12 m3
MinCellVol = 1.5360011527E+06 m3
MaxCellVol = 1.5927954562E+07 m3
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000000160)
NL ROMS/TOMS: started time-stepping: (Grid: 02 TimeSteps: 000000000001 - 000000001600)
TIME-STEP YYYY-MM-DD hh:mm:ss.ss KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME Grid
0 0001-01-01 00:00:00.00 0.000000E+00 4.974433E+02 4.974433E+02 2.867451E+13 01
DEF_HIS - creating history file, Grid 01: gauss_mound_his_coarse.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001 01
0 0001-01-01 00:00:00.00 0.000000E+00 4.973989E+02 4.973989E+02 1.126400E+12 02
DEF_HIS - creating history file, Grid 02: gauss_mound_his_fine.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001 02
1 0001-01-01 00:00:09.00 7.689182E-12 -4.449529+163 -4.449529+163 1.126400E+12 02
(110,160,03) 1.612830E-06 5.197268E-07 0.000000E+00 1.726743E-04
Found Error: 01 Line: 299 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 300 Source: ROMS/Drivers/nl_ocean.h
Node # 0 CPU: 0.414
Total: 0.414
Allocation and array initialization .............. 0.055 (13.4125 %)
Ocean state initialization ....................... 0.048 (11.6433 %)
Reading of input data ............................ 0.000 ( 0.0015 %)
Processing of input data ......................... 0.000 ( 0.0239 %)
Computation of vertical boundary conditions ...... 0.000 ( 0.0184 %)
Computation of global information integrals ...... 0.002 ( 0.4755 %)
Writing of output data ........................... 0.016 ( 3.9795 %)
Model 2D kernel .................................. 0.094 (22.7359 %)
2D/3D coupling, vertical metrics ................. 0.003 ( 0.6921 %)
Omega vertical velocity .......................... 0.002 ( 0.5872 %)
Equation of state for seawater ................... 0.002 ( 0.5974 %)
3D equations right-side terms .................... 0.005 ( 1.2068 %)
3D equations predictor step ...................... 0.008 ( 2.0261 %)
Pressure gradient ................................ 0.003 ( 0.7622 %)
Corrector time-step for 3D momentum .............. 0.005 ( 1.1918 %)
Corrector time-step for tracers .................. 0.006 ( 1.3855 %)
Nesting algorithm ................................ 0.005 ( 1.1976 %)
Reading model state vector ....................... 0.010 ( 2.3803 %)
Total: 0.266 64.3177
Message Passage: 2D halo exchanges ............... 0.000 ( 0.1025 %)
Message Passage: 3D halo exchanges ............... 0.000 ( 0.0082 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0031 %)
Message Passage: data broadcast .................. 0.000 ( 0.0677 %)
Message Passage: data reduction .................. 0.000 ( 0.0118 %)
Message Passage: data gathering .................. 0.005 ( 1.1981 %)
Message Passage: data scattering.................. 0.004 ( 0.8882 %)
Message Passage: nesting point data gathering .... 0.005 ( 1.2956 %)
Message Passage: synchronization barrier ......... 0.000 ( 0.0017 %)
Total: 0.015 3.5770
Nonlinear model elapsed CPU time profile, Grid: 02
Allocation and array initialization .............. 0.055 (13.4130 %)
Ocean state initialization ....................... 0.047 (11.4141 %)
Reading of input data ............................ 0.000 ( 0.0012 %)
Processing of input data ......................... 0.000 ( 0.0406 %)
Computation of vertical boundary conditions ...... 0.000 ( 0.0172 %)
Computation of global information integrals ...... 0.004 ( 0.9984 %)
Writing of output data ........................... 0.016 ( 3.9164 %)
Model 2D kernel .................................. 0.093 (22.4635 %)
2D/3D coupling, vertical metrics ................. 0.004 ( 0.9399 %)
Omega vertical velocity .......................... 0.003 ( 0.6740 %)
Equation of state for seawater ................... 0.004 ( 0.9639 %)
3D equations right-side terms .................... 0.005 ( 1.2682 %)
3D equations predictor step ...................... 0.006 ( 1.5126 %)
Pressure gradient ................................ 0.003 ( 0.7603 %)
Corrector time-step for 3D momentum .............. 0.005 ( 1.1875 %)
Corrector time-step for tracers .................. 0.003 ( 0.7303 %)
Nesting algorithm ................................ 0.002 ( 0.3740 %)
Reading model state vector ....................... 0.009 ( 2.1064 %)
Total: 0.260 62.7816
Nonlinear model message Passage profile, Grid: 02
Message Passage: 2D halo exchanges ............... 0.000 ( 0.0962 %)
Message Passage: 3D halo exchanges ............... 0.000 ( 0.0080 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0027 %)
Message Passage: data broadcast .................. 0.000 ( 0.0631 %)
Message Passage: data reduction .................. 0.000 ( 0.0044 %)
Message Passage: data gathering .................. 0.005 ( 1.2257 %)
Message Passage: data scattering.................. 0.003 ( 0.7685 %)
Message Passage: nesting point data gathering .... 0.002 ( 0.4144 %)
Total: 0.011 2.5829
Unique code regions profiled ..................... 0.526 127.0993 %
Residual, non-profiled code ...................... -0.112 -27.0993 %
All percentages are with respect to total time = 0.414
Dynamic and Automatic memory (MB) usage for Grid 01: 128x140x10 tiling: 1x1
tile Dynamic Automatic USAGE MPI-Buffers
0 65.28 12.27 77.56 1.70
SUM 65.28 12.27 77.56 1.70
Dynamic and Automatic memory (MB) usage for Grid 02: 110x160x10 tiling: 1x1
0 67.56 12.08 79.63 1.77
SUM 67.56 12.08 79.63 1.77
TOTAL 132.84 24.35 157.19 3.47
Analytical header files used:
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_btflux.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_fsobc.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_m2obc.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_m3obc.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_smflux.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_stflux.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_tobc.h
/vortexfs1/scratch/gxu/ROMS_test/gauss_mound_nest/include/ana_vmix.h
Found Error: 01 Line: 334 Source: ROMS/Utility/close_io.F
xupeng66
#4 Unread post by xupeng66 »
I think I have found the cause of problems. It turns out that I forgot to specify the horizontal and vertical advection schemes for temperature for the fine grid. I feel frustrated that it took me so long to spot such a simple mistake in the model setup. The roms.in file I used for the nested simulation was converted from the one I used for single-grid simulations. I thought I made all the changes needed but apparently I had missed something very important. This is good learning experience for me, though.
Cheers!
