Hi everyone ! Recently I got a problem with my ROMS-only model.The temperature in bottom layer was below -10 deg C and this abnormal temp happened only in the slope region. If I change my CPP define TS_C4HADVCTION into TS_U3HADVTION this problem just disappear but other problems appear.Could you please give me some help about how to solve this abnormal temp problem while using TS_C$HADVECTION CPP define ? Thank you so much!
Below is my CPP define
/*Physics options*/
Hello! If the area is very shallow the problem can be the heat flux, you can try use the forcing and Qcorrection instead of Bulk Fluxes. I had a very similar problem in a shallow domain, the temperature was very high or very low.
Thank you for your help ! I check the bathymetry where this problem happen. Below is a temperature slice along 25.7N near Taiwan island.. The depth of low temperature region is below 1600 meters , I don't think this is too shallow.
gresendiz wrote: Tue Nov 05, 2019 5:31 am
