Abnormal low temperature in bottom layer
zhiguoMEI
Location: State KeyLaboratoryofMarine Environmental Science,
#1 Unread post by zhiguoMEI »
Hi everyone ! Recently I got a problem with my ROMS-only model.The temperature in bottom layer was below -10 deg C and this abnormal temp happened only in the slope region. If I change my CPP define TS_C4HADVCTION into TS_U3HADVTION this problem just disappear but other problems appear.Could you please give me some help about how to solve this abnormal temp problem while using TS_C$HADVECTION CPP define ? Thank you so much!
Below is my CPP define
/*Physics options*/
#define VISC_GRID
#define DIFF_GRID
#define MIX_GEO_TS
/*Sediment*/
/*Numeric options*/
#define SPHERICAL
#define SPLINES_VVISC
#define SPLINES_VDIFF
#define TS_U3HADVECTION
#undef TS_C4HADVECTION
#undef TS_MPDATA
#undef WET_DRY
#undef TS_U3ADV_SPLIT
#define UV_U3ADV_SPLIT
/*bottom*/
/*Output*/
#define PERFECT_RESTART
#define RST_SINGLE
/*Surface and bottom boundary options*/
#define BULK_FLUXES
#ifdef BULK_FLUXES
# define SOLAR_SOURCE
# define LONGWAVE_OUT
# define EMINUSP
# define WIND_MINUS_CURRENT
#else
# define ANA_SMFLUX
# define ANA_STFLUX
# define ANA_SRFLUX
#undef ANA_SSFLUX
#define ANA_SPFLUX
#define ANA_BPFLUX
# undef LIMIT_VDIFF
# undef LIMIT_VVISC
/* Vertical subgridscale turbulence closure */
# define GLS_MIXING
# define RI_SPLINES
# undef CRAIG_BANNER
# undef CHARNOK
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_BKPP
# define LMD_SKPP
# undef LMD_NONLOCAL
Here is model result :Image
gresendiz
Re: Abnormal low temperature in bottome layer
#2 Unread post by gresendiz »
Hello! If the area is very shallow the problem can be the heat flux, you can try use the forcing and Qcorrection instead of Bulk Fluxes. I had a very similar problem in a shallow domain, the temperature was very high or very low.
Gabriela :)
CICESE
PhD student
zhiguoMEI
#3 Unread post by zhiguoMEI »
Thank you for your help ! I check the bathymetry where this problem happen. Below is a temperature slice along 25.7N near Taiwan island.Image. The depth of low temperature region is below 1600 meters , I don't think this is too shallow.
zhiguoMEI
#4 Unread post by zhiguoMEI »
gresendiz wrote: Tue Nov 05, 2019 5:31 am Hello! If the area is very shallow the problem can be the heat flux, you can try use the forcing and Qcorrection instead of Bulk Fluxes. I had a very similar problem in a shallow domain, the temperature was very high or very low.
