upwelling: - Configuration error ..... exit_flag: 5
lairuixun
#1 Unread post by lairuixun »
Hi,all. I am new to ROMS. I have successfully built the roms with gfortran and mpich under ubuntu.
For the case, I didn't modify the roms_upwelling.in.
However, when I run the case of upwelling, the error goes.
I searched the similar errors on the web and tried to fix it, but finally failed.
Can you help me? thanks.
$mpirun -np 9 ./romsM roms_upwelling.in
 Model Input Parameters:  ROMS/TOMS version 3.8
                          Saturday - August 3, 2019 - 10:15:27 PM
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /usr/local/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -
 MPI Communicator : 1140850688  PET size = 9
 Input Script     : roms_upwelling.in
 SVN Root URL     : https://www.myroms.org/svn/src/trunk
 SVN Revision     :
 Local Root       : /home/lairuixun/ROMS0803/trunk
 Header Dir       : /home/lairuixun/ROMS0803/test/upwelling
 Header file      : upwelling.h
 Analytical Dir   : /home/lairuixun/ROMS0803/test/upwelling
 Resolution, Grid 01: 41x80x16,  Parallel Nodes: 9,  Tiling: 3x3
        288  ntimes            Number of timesteps for 3-D equations.
    300.000  dt                Timestep size (s) for 3-D equations.
         30  ndtfast           Number of timesteps for 2-D equations between
         72  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
         72  nHIS              Number of timesteps between the writing fields
                                 into history file.
          0  nQCK              Number of timesteps between the writing fields
                                 into quicksave file.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 3.0000E-03  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 3.0000E+00  theta_s           S-coordinate surface control parameter.
 0.0000E+00  theta_b           S-coordinate bottom  control parameter.
     25.000  Tcline            S-coordinate surface/bottom layer width (m) used
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
     14.000  T0                Background potential temperature (C) constant.
     35.000  S0                Background salinity (PSU) constant.
   1027.000  R0                Background density (kg/m3) used in linear Equation
                                 of State.
 1.7000E-04  Tcoef             Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef             Saline contraction coefficient (1/PSU).
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idOvel)      Write out omega vertical velocity.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Hout(idDano)      Write out density anomaly.
               Output Restart File:  roms_rst.nc
               Output History File:  roms_his.nc
 Tile partition information for Grid 01:  41x80x16  tiling: 3x3
        0        1       14        1       27     6048
        1       15       28        1       27     6048
        2       29       41        1       27     5616
        3        1       14       28       54     6048
        4       15       28       28       54     6048
        5       29       41       28       54     5616
        6        1       14       55       80     5824
        7       15       28       55       80     5824
        8       29       41       55       80     5408
   (interior points only)
        0     0.50    14.50     0.50    27.50  RHO-points
        1    14.50    28.50     0.50    27.50  RHO-points
        2    28.50    41.50     0.50    27.50  RHO-points
        3     0.50    14.50    27.50    54.50  RHO-points
        4    14.50    28.50    27.50    54.50  RHO-points
        5    28.50    41.50    27.50    54.50  RHO-points
        6     0.50    14.50    54.50    80.50  RHO-points
        7    14.50    28.50    54.50    80.50  RHO-points
        8    28.50    41.50    54.50    80.50  RHO-points
        0     1.00    14.50     0.50    27.50    U-points
        1    14.50    28.50     0.50    27.50    U-points
        2    28.50    41.00     0.50    27.50    U-points
        3     1.00    14.50    27.50    54.50    U-points
        4    14.50    28.50    27.50    54.50    U-points
        5    28.50    41.00    27.50    54.50    U-points
        6     1.00    14.50    54.50    80.50    U-points
        7    14.50    28.50    54.50    80.50    U-points
        8    28.50    41.00    54.50    80.50    U-points
        0     0.50    14.50     1.00    27.50    V-points
        1    14.50    28.50     1.00    27.50    V-points
        2    28.50    41.50     1.00    27.50    V-points
        3     0.50    14.50    27.50    54.50    V-points
        4    14.50    28.50    27.50    54.50    V-points
        5    28.50    41.50    27.50    54.50    V-points
        6     0.50    14.50    54.50    80.00    V-points
        7    14.50    28.50    54.50    80.00    V-points
        8    28.50    41.50    54.50    80.00    V-points
               HaloSizeI(1) =      81
               HaloSizeJ(1) =     117
                TileSide(1) =      33
                TileSize(1) =     693
 zeta                     1   Periodic     Closed       Periodic     Closed
 ubar                     1   Periodic     Closed       Periodic     Closed
 vbar                     1   Periodic     Closed       Periodic     Closed
 u                        1   Periodic     Closed       Periodic     Closed
 v                        1   Periodic     Closed       Periodic     Closed
 temp                     1   Periodic     Closed       Periodic     Closed
 salt                     1   Periodic     Closed       Periodic     Closed
 UPWELLING               Wind-Driven Upwelling/Downwelling over a Periodic Channel
 ANA_BSFLUX              Analytical kinematic bottom salinity flux
 ANA_BTFLUX              Analytical kinematic bottom temperature flux
 ANA_GRID                Analytical grid set-up
 ANA_INITIAL             Analytical initial conditions
 ANA_SMFLUX              Analytical kinematic surface momentum flux
 ANA_SSFLUX              Analytical kinematic surface salinity flux
 ANA_STFLUX              Analytical kinematic surface temperature flux
 ANA_VMIX                Analytical vertical mixing coefficients
 ASSUMED_SHAPE           Using assumed-shape arrays
 !BOUNDARY_ALLGATHER     Using mpi_allreduce in mp_boundary routine
 !COLLECT_ALL...         Using mpi_isend/mpi_recv in mp_collect routine
 DJ_GRADPS               Parabolic Splines density Jacobian (Shchepetkin, 2002)
 DOUBLE_PRECISION        Double precision arithmetic numerical kernel.
 MPI                     MPI distributed-memory configuration
 NONLINEAR               Nonlinear Model
 !NONLIN_EOS             Linear Equation of State for seawater
 POWER_LAW               Power-law shape time-averaging barotropic filter
 PROFILE                 Time profiling activated
 REDUCE_ALLGATHER        Using mpi_allgather in mp_reduce routine
 !RST_SINGLE             Double precision fields in restart NetCDF file
 SALINITY                Using salinity
 SOLVE3D                 Solving 3D Primitive Equations
 SPLINES_VDIFF           Parabolic Spline Reconstruction for Vertical Diffusion
 SPLINES_VVISC           Parabolic Spline Reconstruction for Vertical Viscosity
 TS_C4HADVECTION         Fourth-order centered horizontal advection of tracers
 TS_C4VADVECTION         Fourth-order centered vertical advection of tracers
 UV_ADV                  Advection of momentum
 UV_COR                  Coriolis term
 UV_U3HADVECTION         Third-order upstream horizontal advection of 3D momentum
 UV_C4VADVECTION         Fourth-order centered vertical advection of momentum
 VAR_RHO_2D              Variable density barotropic mode
 CHECKDEFS - no bottom stress formulation is selected.
 Found Error: 05   Line: 1128     Source: ROMS/Utility/inp_par.F
 Found Error: 05   Line: 111      Source: ROMS/Drivers/nl_ocean.h
 Dynamic and Automatic memory (MB) usage for Grid 01:  41x80x16  tiling: 3x3
     tile          Dynamic        Automatic            USAGE      MPI-Buffers
        0             0.96             0.96             1.92             0.00
        1             0.96             0.96             1.92             0.00
        2             0.96             0.96             1.92             0.00
        3             0.96             0.96             1.92             0.00
        4             0.96             0.96             1.92             0.00
        5             0.96             0.96             1.92             0.00
        6             0.96             0.96             1.92             0.00
        7             0.96             0.96             1.92             0.00
        8             0.96             0.96             1.92             0.00
    TOTAL             8.65             8.63            17.28             0.00
 Found Error: 05   Line: 350      Source: ROMS/Utility/close_io.F
 ROMS/TOMS - Configuration error ..... exit_flag:   5
Linux-gfortran.mk
(10.92 KiB) Downloaded 476 times
build_roms.bash
(10.82 KiB) Downloaded 484 times
Re: upwelling: - Configuration error ..... exit_flag: 5
Here is the real error message:
The upwelling case should have one selected in the roms_upwelling.in file.
lairuixun
#3 Unread post by lairuixun »
Thanks,kate.
I searched other messages and finally add '#define UV_LDRAG' in upwelling.h.
After rebuild, it is work now.
#4 Unread post by arango »
The default upwelling example in ROMS test repository has UV_QDRAG activated in the build script. If you notice, there are various options in build_roms.sh:
# can be used to write time-averaged fields. Notice that you can have as
# many definitions as you want by appending values.
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DAVERAGES"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DDIAGNOSTICS_TS"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DDIAGNOSTICS_UV"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DSTATIONS"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DFLOATS"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DFLOAT_OYSTER"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DFLOAT_VWALK"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DDEBUGGING"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DOUT_DOUBLE"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DPOSITIVE_ZERO"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_VIS2"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_VIS4"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DMIX_S_UV"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DMIX_GEO_UV"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DTS_DIF2"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DMIX_S_TS"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DMIX_GEO_TS"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_LOGDRAG"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_LDRAG"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_QDRAG"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DUV_DRAG_GRID"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DANA_DRAG"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DTS_U3HADVECTION"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DTS_C4VADVECTION"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DTS_MPDATA"
 setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DBIO_FENNEL"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DECOSIM"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DNEMURO"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DNPZD_FRANKS"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DNPZD_IRON"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DNPZD_POWELL"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DGLS_MIXING"
#setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DMY25_MIXING"
The strategy here is to play with several options in the build script and not modifying header file upwelling.h. Of course, you need to have some knowledge of ROMS and be able to read the standard file and assimilate what in ROMS is telling you. It needs a scheme for bottom friction! and you commented it out UV_QDRAG for some reason.
:idea: It is that simple, and you need to pay attention to what you are modifying.
