For the case, I didn't modify the roms_upwelling.in.
However, when I run the case of upwelling, the error goes.
I searched the similar errors on the web and tried to fix it, but finally failed.
Can you help me? thanks.
$mpirun -np 9 ./romsM roms_upwelling.in
Model Input Parameters: ROMS/TOMS version 3.8
Saturday - August 3, 2019 - 10:15:27 PM
Wind-Driven Upwelling/Downwelling over a Periodic Channel
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -
MPI Communicator : 1140850688 PET size = 9
Input Script : roms_upwelling.in
SVN Revision :
Local Root : /home/lairuixun/ROMS0803/trunk
Header Dir : /home/lairuixun/ROMS0803/test/upwelling
Header file : upwelling.h
Analytical Dir : /home/lairuixun/ROMS0803/test/upwelling
Resolution, Grid 01: 41x80x16, Parallel Nodes: 9, Tiling: 3x3
288 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
72 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
for tracer 02: salt
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Tile partition information for Grid 01: 41x80x16 tiling: 3x3
tile Istr Iend Jstr Jend Npts
0 1 14 1 27 6048
1 15 28 1 27 6048
2 29 41 1 27 5616
3 1 14 28 54 6048
4 15 28 28 54 6048
5 29 41 28 54 5616
6 1 14 55 80 5824
7 15 28 55 80 5824
8 29 41 55 80 5408
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 14.50 0.50 27.50 RHO-points
1 14.50 28.50 0.50 27.50 RHO-points
2 28.50 41.50 0.50 27.50 RHO-points
3 0.50 14.50 27.50 54.50 RHO-points
4 14.50 28.50 27.50 54.50 RHO-points
5 28.50 41.50 27.50 54.50 RHO-points
6 0.50 14.50 54.50 80.50 RHO-points
7 14.50 28.50 54.50 80.50 RHO-points
8 28.50 41.50 54.50 80.50 RHO-points
0 1.00 14.50 0.50 27.50 U-points
1 14.50 28.50 0.50 27.50 U-points
2 28.50 41.00 0.50 27.50 U-points
3 1.00 14.50 27.50 54.50 U-points
4 14.50 28.50 27.50 54.50 U-points
5 28.50 41.00 27.50 54.50 U-points
6 1.00 14.50 54.50 80.50 U-points
7 14.50 28.50 54.50 80.50 U-points
8 28.50 41.00 54.50 80.50 U-points
0 0.50 14.50 1.00 27.50 V-points
1 14.50 28.50 1.00 27.50 V-points
2 28.50 41.50 1.00 27.50 V-points
3 0.50 14.50 27.50 54.50 V-points
4 14.50 28.50 27.50 54.50 V-points
5 28.50 41.50 27.50 54.50 V-points
6 0.50 14.50 54.50 80.00 V-points
7 14.50 28.50 54.50 80.00 V-points
8 28.50 41.50 54.50 80.00 V-points
HaloSizeI(1) = 81
HaloSizeJ(1) = 117
TileSide(1) = 33
TileSize(1) = 693
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
UPWELLING Wind-Driven Upwelling/Downwelling over a Periodic Channel
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ANA_GRID Analytical grid set-up
ANA_INITIAL Analytical initial conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
ASSUMED_SHAPE Using assumed-shape arrays
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
POWER_LAW Power-law shape time-averaging barotropic filter
PROFILE Time profiling activated
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine
!RST_SINGLE Double precision fields in restart NetCDF file
SALINITY Using salinity
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers
TS_C4VADVECTION Fourth-order centered vertical advection of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_U3HADVECTION Third-order upstream horizontal advection of 3D momentum
UV_C4VADVECTION Fourth-order centered vertical advection of momentum
VAR_RHO_2D Variable density barotropic mode
CHECKDEFS - no bottom stress formulation is selected.
Found Error: 05 Line: 1128 Source: ROMS/Utility/inp_par.F
Found Error: 05 Line: 111 Source: ROMS/Drivers/nl_ocean.h
Elapsed CPU time (seconds):
Dynamic and Automatic memory (MB) usage for Grid 01: 41x80x16 tiling: 3x3
tile Dynamic Automatic USAGE MPI-Buffers
0 0.96 0.96 1.92 0.00
1 0.96 0.96 1.92 0.00
2 0.96 0.96 1.92 0.00
3 0.96 0.96 1.92 0.00
4 0.96 0.96 1.92 0.00
5 0.96 0.96 1.92 0.00
6 0.96 0.96 1.92 0.00
7 0.96 0.96 1.92 0.00
8 0.96 0.96 1.92 0.00
TOTAL 8.65 8.63 17.28 0.00
Found Error: 05 Line: 350 Source: ROMS/Utility/close_io.F
