first time running upwelling test case
Hi everyone. I am new to ROMS. I compiled ROMS (Checked out revision 963)with ./build.bash and the "romsG" executable and "build_romsG" folder was made without any error(on Fedora 25, using gfortran, netcdf 4 and mpich libs). but at the first runnig of upwelling test case by the command: ./oceanG < roms_upwelling.in, i get errors as below:
[ghasedak@nobody upwelling]$ ./romsG < roms_upwelling.in
Saturday - April 27, 2019 - 7:38:12 PM
INP_PAR - Unable to open ROMS/TOMS input script file.
In distributed-memory applications, the input
script file is processed in parallel. The Unix
routine GETARG is used to get script file name.
For example, in MPI applications make sure that
command line is something like:
mpirun -np 4 romsM roms.in
and not
mpirun -np 4 romsM < roms.in
Found Error: 02 Line: 111 Source: ROMS/Drivers/nl_ocean.h
memory.f90:58: runtime error: load of null pointer of type 'integer(kind=4)'
ASAN:DEADLYSIGNAL
==13659==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000000 (pc 0x000000408581 bp 0x7fff7bf78ad0 sp 0x7fff7bf78390 T0)
#0 0x408580 in memory_ /home/ghasedak/Projects/upwelling/Build_romsG/memory.f90:58
#1 0x406286 in __ocean_control_mod_MOD_roms_finalize /home/ghasedak/Projects/upwelling/Build_romsG/ocean_control.f90:255
#2 0x404b1b in ocean /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:115
#3 0x404bce in main /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:50
#4 0x7f7d5c2ce430 in __libc_start_main (/lib64/libc.so.6+0x20430)
#5 0x4040e9 in _start (/home/ghasedak/Projects/upwelling/romsG+0x4040e9)
AddressSanitizer can not provide additional info.
SUMMARY: AddressSanitizer: SEGV /home/ghasedak/Projects/upwelling/Build_romsG/memory.f90:58 in memory_
==13659==ABORTING
______________________________________________________________
! as the error "Found Error: 02 Line: 111 Source: ROMS/Drivers/nl_ocean.h" i think the main error is about "inp_par.f90" but i dont know how change or fix this file. also some other files that mentioned in error lines are attached. Can you kindly help what went wrong
and not
ASAN:DEADLYSIGNAL
==13659==ABORTING
ocean_control.f90
- (9.06 KiB) Downloaded 970 times
master.f90
- (5.43 KiB) Downloaded 882 times
memory.f90
- (8.24 KiB) Downloaded 790 times
upwelling.h
- (1.71 KiB) Downloaded 790 times
roms_upwelling.in
- (131.95 KiB) Downloaded 704 times
inp_par.f90
- (34.15 KiB) Downloaded 867 times
varinfo.dat
- (150.34 KiB) Downloaded 654 times
Re: first time running upwelling test case
ROMS told you the problem:
You need to try "./romsG roms_upwelling.in" or perhaps:
and not
mpirun -np 4 ./romsG roms_upwelling.in
thanks Kate.
i use "./romsG roms_upwelling.in" and now i get this:
[ghasedak@nobody upwelling]$ ./romsG roms_upwelling.in
Sunday - April 28, 2019 - 1:30:38 PM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -
MPI Communicator : 1140850688 PET size = 1
Input Script : roms_upwelling.in
SVN Revision : 963M
Local Root : /home/ghasedak/src
Header Dir : /home/ghasedak/Projects/upwelling
Header file : upwelling.h
Analytical Dir: /home/ghasedak/Projects/upwelling
Resolution, Grid 01: 41x80x16, Parallel Nodes: 1, Tiling: 1x1
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
T Dout(M2rate) Write out 2D momentum acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentum acceleration.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
Tile partition information for Grid 01: 41x80x16 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 41 1 80 52480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 41.50 0.50 80.50 RHO-points
0 1.00 41.00 0.50 80.50 U-points
0 0.50 41.50 1.00 80.00 V-points
HaloSizeI(1) = 162
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 4080
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_GRID Analytical grid set-up
ANA_INITIAL Analytical initial conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
AVERAGES Writing out time-averaged nonlinear model fields
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine
SALINITY Using salinity
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
TS_U3HADVECTION Third-order upstream horizontal advection of tracers
TS_C4VADVECTION Fourth-order centered vertical advection of tracers
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_LDRAG Linear bottom stress
Process Information:
Node # 0 (pid= 18367) is active.
ANA_GRID - x-location of PSI-points: x_psi
(Grid = 01, Min = 0.00000000E+00 Max = 4.00000000E+04)
ANA_GRID - y-location of PSI-points: y_psi
(Grid = 01, Min = 0.00000000E+00 Max = 8.00000000E+04)
ANA_GRID - x-location of RHO-points: x_rho
(Grid = 01, Min = 5.00000000E+02 Max = 4.05000000E+04)
ANA_GRID - y-location of RHO-points: y_rho
(Grid = 01, Min = -5.00000000E+02 Max = 8.05000000E+04)
ANA_GRID - x-location of U-points: x_u
ANA_GRID - y-location of U-points: y_u
ANA_GRID - x-location of V-points: x_v
ANA_GRID - y-location of V-points: y_v
ANA_GRID - reciprocal XI-grid spacing: pm
(Grid = 01, Min = 1.00000000E-03 Max = 1.00000000E-03)
ANA_GRID - reciprocal ETA-grid spacing: pn
ANA_GRID - angle between XI-axis and EAST: angler
ANA_GRID - Coriolis parameter at RHO-points: f
(Grid = 01, Min = -8.26000000E-05 Max = -8.26000000E-05)
ANA_GRID - bathymetry at RHO-points: h
(Grid = 01, Min = 2.52004887E+01 Max = 1.50000000E+02)
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
(Grid = 01, Min = 1.45204834E+01 Max = 2.19365219E+01)
ANA_INITIAL - salinity: salt
(Grid = 01, Min = 3.50000000E+01 Max = 3.50000000E+01)
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial domain volumes: TotVolume = 3.8843755884E+11 m3
MinCellVol = 8.4521383562E+05 m3
MaxCellVol = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000001440)
0 0001-01-01 00:00:00.00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
(00,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: roms_his.nc
ASAN:DEADLYSIGNAL
==18367==ERROR: AddressSanitizer: SEGV on unknown address 0x00000000000b (pc 0x7fde4f65ebe1 bp 0x000000000000 sp 0x7ffe80ad5c60 T0)
#0 0x7fde4f65ebe0 in __netcdf_MOD_nf90_create /home/ghasedak/Downloads/netcdf-fortran-4.4.4/fortran/netcdf4_file.f90:111
#1 0x1f23f39 in __mod_netcdf_MOD_netcdf_create /home/ghasedak/Projects/upwelling/Build_romsG/mod_netcdf.f90:6479
#2 0x18f9860 in def_his_ /home/ghasedak/Projects/upwelling/Build_romsG/def_his.f90:69
#3 0x7e4059 in output_ /home/ghasedak/Projects/upwelling/Build_romsG/output.f90:112
#4 0x70a84d in main3d_ /home/ghasedak/Projects/upwelling/Build_romsG/main3d.f90:231
#5 0x406b5c in __ocean_control_mod_MOD_roms_run /home/ghasedak/Projects/upwelling/Build_romsG/ocean_control.f90:181
#6 0x404b16 in ocean /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:108
#7 0x404bce in main /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:50
#8 0x7fde4d05b430 in __libc_start_main (/lib64/libc.so.6+0x20430)
#9 0x4040e9 in _start (/home/ghasedak/Projects/upwelling/romsG+0x4040e9)
SUMMARY: AddressSanitizer: SEGV /home/ghasedak/Downloads/netcdf-fortran-4.4.4/fortran/netcdf4_file.f90:111 in __netcdf_MOD_nf90_create
==18367==ABORTING
________________________________________________________________________
SVN Revision : 963M
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 41 1 80 52480
HaloSizeI(1) = 162
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 4080
ASAN:DEADLYSIGNAL
==18367==ABORTING
It failed in the call to DEF_HIS. Are you trying to write to somewhere where you don't have permissions? Do you have a local computer support staff to ask for help?
Does this line have "CALL netcdf_create"?
Has your netcdf library been tested in any way so that you know it works?
- neelbasak08
- Location: Thapar Institute of Engineering and Technology, Patiala, PN, India
Hello!
I am facing some similar sort of issues while trying to run my model in a parallel mode. I am attaching the complete output of the Linux terminal. The following is a part of the output in the terminal :
Any leads as to how to solve these issues?
Kind regards
-Neel
I was able to sort out the tiling issue as it was very clearly mentioned in the error what is to be done but I was unable to sort out the other errors in the latter part of log file.SINGAPORE ISLAND MODEL
Compiler flags : -frepack-arrays -g -O0 -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -fopenmp -static-libgcc -
SVN Revision : 1061
Local Root : /home/lkannappan/roms
Header Dir : /home/lkannappan/roms/project/singapore
Header file : singapore.h
Analytical Dir : /home/lkannappan/roms/project/singapore
Resolution, Grid 01: 298x148x15, Parallel Threads: 16, Tiling: 8x1
ROMS/TOMS: Wrong choice of grid 01 partition or number of parallel threads.
NtileI*NtileJ must be a positive multiple of the number of threads.
Change number of threads (environment variable) or
Found Error: 06 Line: 191 Source: ROMS/Utility/inp_par.F
Found Error: 06 Line: 115 Source: ROMS/Drivers/nl_ocean.h, ROMS_initialize
At line 127 of file memory.f90
Fortran runtime error: Index '15' of dimension 1 of array 'dsize' outside of expected range (7:0)
Error termination. Backtrace:
inp_par.f90:93: runtime error: load of null pointer of type 'struct t_adv'
ASAN:DEADLYSIGNAL
==21230==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7fc8104a6e91 bp 0x7fffcde09ae0 sp 0x7fffcde05d40 T0)
==21230==The signal is caused by a READ memory access.
==21230==Hint: address points to the zero page.
ASAN:DEADLYSIGNAL
==21231==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7ffa284a6e91 bp 0x7fffc626eed0 sp 0x7fffc626b130 T0)
==21231==The signal is caused by a READ memory access.
==21231==Hint: address points to the zero page.
Kind regards
-Neel
roms error.txt
- (13.74 KiB) Downloaded 610 times
In order have any idea what is going on we would need to see the error after you fixed your tiling error.
- neelbasak08
Thanks Mr. Robertson,
The tiling error was removed as stated by me earlier but the error in the latter sections of the previous log still persists:
Here is my updated error loginp_par.f90:93: runtime error: load of null pointer of type 'struct t_adv'
ASAN:DEADLYSIGNAL
==21348==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f92c78a6e91 bp 0x7fffc2f867b0 sp 0x7fffc2f82a10 T0)
==21348==The signal is caused by a READ memory access.
==21348==Hint: address points to the zero page.
#0 0x7f92c78a6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f92c6910a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f92c690d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f92c690da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f92c1901bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f92c690d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
SUMMARY: AddressSanitizer: SEGV /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93 in __inp_par_mod_MOD_inp_par
==21348==ABORTING
ASAN:DEADLYSIGNAL
==21349==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f008eca6e91 bp 0x7ffff734c500 sp 0x7ffff7348760 T0)
==21349==The signal is caused by a READ memory access.
==21349==Hint: address points to the zero page.
#0 0x7f008eca6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f008dd10a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f008dd0d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f008dd0da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f0088d01bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f008dd0d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
==21349==ABORTING
ASAN:DEADLYSIGNAL
==21350==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f7d71ea6e91 bp 0x7fffcc7a0cb0 sp 0x7fffcc79cf10 T0)
==21350==The signal is caused by a READ memory access.
==21350==Hint: address points to the zero page.
#0 0x7f7d71ea6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f7d70f10a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f7d70f0d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f7d70f0da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f7d6bf01bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f7d70f0d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
roms error.txt
- updated log from terminal
- (28.92 KiB) Downloaded 737 times
Is it possible that you are trying to run an OpenMP (shared memory) ROMS executable using an 'mpirun' command? You have -fopenmp in your list of flags but the multiple occurrences of:
suggest MPI is being used with a non-MPI compiled executable.--------------------------------------------------------------------------------
Monday - May 3, 2021 - 10:50:38 PM
