first time running upwelling test case
Ghasedak
#1 Unread post by Ghasedak »
Hi everyone. I am new to ROMS. I compiled ROMS (Checked out revision 963)with ./build.bash and the "romsG" executable and "build_romsG" folder was made without any error(on Fedora 25, using gfortran, netcdf 4 and mpich libs). but at the first runnig of upwelling test case by the command: ./oceanG < roms_upwelling.in, i get errors as below:
[ghasedak@nobody upwelling]$ ./romsG < roms_upwelling.in
Saturday - April 27, 2019 - 7:38:12 PM
INP_PAR - Unable to open ROMS/TOMS input script file.
In distributed-memory applications, the input
script file is processed in parallel. The Unix
routine GETARG is used to get script file name.
For example, in MPI applications make sure that
command line is something like:
mpirun -np 4 romsM roms.in
and not
mpirun -np 4 romsM < roms.in
Found Error: 02 Line: 111 Source: ROMS/Drivers/nl_ocean.h
Elapsed CPU time (seconds):
memory.f90:58: runtime error: load of null pointer of type 'integer(kind=4)'
ASAN:DEADLYSIGNAL
==13659==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000000 (pc 0x000000408581 bp 0x7fff7bf78ad0 sp 0x7fff7bf78390 T0)
#0 0x408580 in memory_ /home/ghasedak/Projects/upwelling/Build_romsG/memory.f90:58
#1 0x406286 in __ocean_control_mod_MOD_roms_finalize /home/ghasedak/Projects/upwelling/Build_romsG/ocean_control.f90:255
#2 0x404b1b in ocean /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:115
#3 0x404bce in main /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:50
#4 0x7f7d5c2ce430 in __libc_start_main (/lib64/libc.so.6+0x20430)
#5 0x4040e9 in _start (/home/ghasedak/Projects/upwelling/romsG+0x4040e9)
AddressSanitizer can not provide additional info.
SUMMARY: AddressSanitizer: SEGV /home/ghasedak/Projects/upwelling/Build_romsG/memory.f90:58 in memory_
==13659==ABORTING
______________________________________________________________
! as the error "Found Error: 02 Line: 111 Source: ROMS/Drivers/nl_ocean.h" i think the main error is about "inp_par.f90" but i dont know how change or fix this file. also some other files that mentioned in error lines are attached. Can you kindly help what went wrong
ocean_control.f90
(9.06 KiB) Downloaded 1103 times
master.f90
(5.43 KiB) Downloaded 1018 times
memory.f90
(8.24 KiB) Downloaded 922 times
upwelling.h
(1.71 KiB) Downloaded 927 times
roms_upwelling.in
(131.95 KiB) Downloaded 840 times
inp_par.f90
(34.15 KiB) Downloaded 1001 times
varinfo.dat
(150.34 KiB) Downloaded 786 times
Re: first time running upwelling test case
ROMS told you the problem:
and not
You need to try "./romsG roms_upwelling.in" or perhaps:
mpirun -np 4 ./romsG roms_upwelling.in
Ghasedak
#3 Unread post by Ghasedak »
thanks Kate.
i use "./romsG roms_upwelling.in" and now i get this:
[ghasedak@nobody upwelling]$ ./romsG roms_upwelling.in
Sunday - April 28, 2019 - 1:30:38 PM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -
MPI Communicator : 1140850688 PET size = 1
Input Script : roms_upwelling.in
SVN Revision : 963M
Local Root : /home/ghasedak/src
Header Dir : /home/ghasedak/Projects/upwelling
Header file : upwelling.h
Analytical Dir: /home/ghasedak/Projects/upwelling
Resolution, Grid 01: 41x80x16, Parallel Nodes: 1, Tiling: 1x1
1440 ntimes Number of timesteps for 3-D equations.
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
3.0000E+00 theta_s S-coordinate surface control parameter.
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
Tile partition information for Grid 01: 41x80x16 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 41 1 80 52480
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 41.50 0.50 80.50 RHO-points
0 1.00 41.00 0.50 80.50 U-points
0 0.50 41.50 1.00 80.00 V-points
HaloSizeI(1) = 162
HaloSizeJ(1) = 273
TileSide(1) = 85
TileSize(1) = 4080
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ANA_GRID Analytical grid set-up
ANA_INITIAL Analytical initial conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
ASSUMED_SHAPE Using assumed-shape arrays
AVERAGES Writing out time-averaged nonlinear model fields
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
POWER_LAW Power-law shape time-averaging barotropic filter
PROFILE Time profiling activated
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine
!RST_SINGLE Double precision fields in restart NetCDF file
SALINITY Using salinity
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
TS_U3HADVECTION Third-order upstream horizontal advection of tracers
TS_C4VADVECTION Fourth-order centered vertical advection of tracers
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_U3HADVECTION Third-order upstream horizontal advection of 3D momentum
UV_C4VADVECTION Fourth-order centered vertical advection of momentum
UV_LDRAG Linear bottom stress
UV_VIS2 Harmonic mixing of momentum
VAR_RHO_2D Variable density barotropic mode
Process Information:
Node # 0 (pid= 18367) is active.
ANA_GRID - x-location of PSI-points: x_psi
(Grid = 01, Min = 0.00000000E+00 Max = 4.00000000E+04)
ANA_GRID - y-location of PSI-points: y_psi
(Grid = 01, Min = 0.00000000E+00 Max = 8.00000000E+04)
ANA_GRID - x-location of RHO-points: x_rho
(Grid = 01, Min = 5.00000000E+02 Max = 4.05000000E+04)
ANA_GRID - y-location of RHO-points: y_rho
(Grid = 01, Min = -5.00000000E+02 Max = 8.05000000E+04)
ANA_GRID - x-location of U-points: x_u
ANA_GRID - y-location of U-points: y_u
ANA_GRID - x-location of V-points: x_v
ANA_GRID - y-location of V-points: y_v
ANA_GRID - reciprocal XI-grid spacing: pm
(Grid = 01, Min = 1.00000000E-03 Max = 1.00000000E-03)
ANA_GRID - reciprocal ETA-grid spacing: pn
ANA_GRID - angle between XI-axis and EAST: angler
(Grid = 01, Min = 0.00000000E+00 Max = 0.00000000E+00)
ANA_GRID - Coriolis parameter at RHO-points: f
(Grid = 01, Min = -8.26000000E-05 Max = -8.26000000E-05)
ANA_GRID - bathymetry at RHO-points: h
(Grid = 01, Min = 2.52004887E+01 Max = 1.50000000E+02)
16 0.0000000 0.0000000 0.000 0.000 0.000 0.000
15 -0.0625000 -0.0019442 -0.809 -0.806 -1.348 -1.589
14 -0.1250000 -0.0078455 -1.668 -1.661 -2.966 -3.687
13 -0.1875000 -0.0179119 -2.580 -2.568 -4.867 -6.321
12 -0.2500000 -0.0324983 -3.549 -3.531 -7.077 -9.535
11 -0.3125000 -0.0521190 -4.581 -4.558 -9.630 -13.397
10 -0.3750000 -0.0774659 -5.686 -5.656 -12.573 -17.996
9 -0.4375000 -0.1094327 -6.875 -6.837 -15.967 -23.445
8 -0.5000000 -0.1491465 -8.162 -8.114 -19.889 -29.890
7 -0.5625000 -0.1980075 -9.564 -9.506 -24.435 -37.512
6 -0.6250000 -0.2577387 -11.104 -11.034 -29.721 -46.531
5 -0.6875000 -0.3304460 -12.808 -12.724 -35.892 -57.218
4 -0.7500000 -0.4186931 -14.709 -14.609 -43.121 -69.903
3 -0.8125000 -0.5255915 -16.846 -16.726 -51.622 -84.987
2 -0.8750000 -0.6549105 -19.266 -19.124 -61.651 -102.953
1 -0.9375000 -0.8112096 -22.028 -21.859 -73.518 -124.388
0 -1.0000000 -1.0000000 -25.200 -25.000 -87.600 -150.000
12 0.0043042707117221 0.0335513677379153-0.0022367614257356 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864348 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001213 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565097 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906204 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716643 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402368 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399432 0.6603333185976138
21 0.0256737146312911 0.0297153720153352 0.1342125541712342 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524359 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729578 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236653 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893981 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886213 0.8237939964192927
27 0.0432936737565710 0.0230872677537126 0.3506756411451924 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772280 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880565 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442384 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256415 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325521 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348098 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479478 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213239 0.9738247715198165
36 0.0503158038019030 0.0080591141492892 0.8085423793232269 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497611 0.9930692679747334
39 0.0376397765791564 0.0033640675316746 0.9367177506289175 0.9964333355064080
40 0.0305543017255206 0.0021094083123694 0.9672720523544381 0.9985427438187774
41 0.0217382098544504 0.0010909315881854 0.9890102622088885 0.9996336754069628
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 8.08965824E-01 m
Maximum Z-grid spacing, DZmax = 2.56123321E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
ANA_INITIAL - vertically integrated u-momentum component: ubar
ANA_INITIAL - vertically integrated v-momentum component: vbar
ANA_INITIAL - free-surface: zeta
ANA_INITIAL - u-momentum component: u
ANA_INITIAL - v-momentum component: v
ANA_INITIAL - potential temperature: temp
(Grid = 01, Min = 1.45204834E+01 Max = 2.19365219E+01)
ANA_INITIAL - salinity: salt
(Grid = 01, Min = 3.50000000E+01 Max = 3.50000000E+01)
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 8.661243E-01 (Haney)
Initial domain volumes: TotVolume = 3.8843755884E+11 m3
MinCellVol = 8.4521383562E+05 m3
MaxCellVol = 2.5612332106E+07 m3
Max/Min = 3.0302783777E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000001440)
0 0001-01-01 00:00:00.00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
DEF_HIS - creating history file, Grid 01: roms_his.nc
ASAN:DEADLYSIGNAL
==18367==ERROR: AddressSanitizer: SEGV on unknown address 0x00000000000b (pc 0x7fde4f65ebe1 bp 0x000000000000 sp 0x7ffe80ad5c60 T0)
#0 0x7fde4f65ebe0 in __netcdf_MOD_nf90_create /home/ghasedak/Downloads/netcdf-fortran-4.4.4/fortran/netcdf4_file.f90:111
#1 0x1f23f39 in __mod_netcdf_MOD_netcdf_create /home/ghasedak/Projects/upwelling/Build_romsG/mod_netcdf.f90:6479
#2 0x18f9860 in def_his_ /home/ghasedak/Projects/upwelling/Build_romsG/def_his.f90:69
#3 0x7e4059 in output_ /home/ghasedak/Projects/upwelling/Build_romsG/output.f90:112
#4 0x70a84d in main3d_ /home/ghasedak/Projects/upwelling/Build_romsG/main3d.f90:231
#5 0x406b5c in __ocean_control_mod_MOD_roms_run /home/ghasedak/Projects/upwelling/Build_romsG/ocean_control.f90:181
#6 0x404b16 in ocean /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:108
#7 0x404bce in main /home/ghasedak/Projects/upwelling/Build_romsG/master.f90:50
#8 0x7fde4d05b430 in __libc_start_main (/lib64/libc.so.6+0x20430)
#9 0x4040e9 in _start (/home/ghasedak/Projects/upwelling/romsG+0x4040e9)
SUMMARY: AddressSanitizer: SEGV /home/ghasedak/Downloads/netcdf-fortran-4.4.4/fortran/netcdf4_file.f90:111 in __netcdf_MOD_nf90_create
==18367==ABORTING
________________________________________________________________________
It failed in the call to DEF_HIS. Are you trying to write to somewhere where you don't have permissions? Do you have a local computer support staff to ask for help?
Does this line have "CALL netcdf_create"?
Has your netcdf library been tested in any way so that you know it works?
neelbasak08
Location: Thapar Institute of Engineering and Technology, Patiala, PN, India
#5 Unread post by neelbasak08 »
Hello!
I am facing some similar sort of issues while trying to run my model in a parallel mode. I am attaching the complete output of the Linux terminal. The following is a part of the output in the terminal :
SINGAPORE ISLAND MODEL
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -g -O0 -fbounds-check -fbacktrace -fcheck=all -fsanitize=address -fsanitize=undefined -finit-real=nan -ffpe-trap=invalid,zero,overflow -fopenmp -static-libgcc -
SVN Revision : 1061
Local Root : /home/lkannappan/roms
Header Dir : /home/lkannappan/roms/project/singapore
Header file : singapore.h
Analytical Dir : /home/lkannappan/roms/project/singapore
Resolution, Grid 01: 298x148x15, Parallel Threads: 16, Tiling: 8x1
ROMS/TOMS: Wrong choice of grid 01 partition or number of parallel threads.
NtileI*NtileJ must be a positive multiple of the number of threads.
Change number of threads (environment variable) or
change domain partition in input script.
Found Error: 06 Line: 191 Source: ROMS/Utility/inp_par.F
Found Error: 06 Line: 115 Source: ROMS/Drivers/nl_ocean.h, ROMS_initialize
Elapsed wall CPU time for each process (seconds):
At line 127 of file memory.f90
Fortran runtime error: Index '15' of dimension 1 of array 'dsize' outside of expected range (7:0)
Error termination. Backtrace:
inp_par.f90:93: runtime error: load of null pointer of type 'struct t_adv'
ASAN:DEADLYSIGNAL
==21230==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7fc8104a6e91 bp 0x7fffcde09ae0 sp 0x7fffcde05d40 T0)
==21230==The signal is caused by a READ memory access.
==21230==Hint: address points to the zero page.
ASAN:DEADLYSIGNAL
==21231==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7ffa284a6e91 bp 0x7fffc626eed0 sp 0x7fffc626b130 T0)
==21231==The signal is caused by a READ memory access.
==21231==Hint: address points to the zero page.
I was able to sort out the tiling issue as it was very clearly mentioned in the error what is to be done but I was unable to sort out the other errors in the latter part of log file.
Any leads as to how to solve these issues?
Kind regards
-Neel
roms error.txt
(13.74 KiB) Downloaded 743 times
robertson
#6 Unread post by robertson »
In order have any idea what is going on we would need to see the error after you fixed your tiling error.
neelbasak08
#7 Unread post by neelbasak08 »
Thanks Mr. Robertson,
The tiling error was removed as stated by me earlier but the error in the latter sections of the previous log still persists:
ASAN:DEADLYSIGNAL
==21348==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f92c78a6e91 bp 0x7fffc2f867b0 sp 0x7fffc2f82a10 T0)
==21348==The signal is caused by a READ memory access.
==21348==Hint: address points to the zero page.
#0 0x7f92c78a6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f92c6910a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f92c690d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f92c690da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f92c1901bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f92c690d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
SUMMARY: AddressSanitizer: SEGV /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93 in __inp_par_mod_MOD_inp_par
==21348==ABORTING
ASAN:DEADLYSIGNAL
==21349==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f008eca6e91 bp 0x7ffff734c500 sp 0x7ffff7348760 T0)
==21349==The signal is caused by a READ memory access.
==21349==Hint: address points to the zero page.
#0 0x7f008eca6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f008dd10a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f008dd0d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f008dd0da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f0088d01bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f008dd0d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
==21349==ABORTING
ASAN:DEADLYSIGNAL
==21350==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000010 (pc 0x7f7d71ea6e91 bp 0x7fffcc7a0cb0 sp 0x7fffcc79cf10 T0)
==21350==The signal is caused by a READ memory access.
==21350==Hint: address points to the zero page.
#0 0x7f7d71ea6e90 in __inp_par_mod_MOD_inp_par /home/lkannappan/roms/project/singapore/Build_romsG/inp_par.f90:93
#1 0x7f7d70f10a21 in __ocean_control_mod_MOD_roms_initialize /home/lkannappan/roms/project/singapore/Build_romsG/ocean_control.f90:83
#2 0x7f7d70f0d38a in ocean /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:73
#3 0x7f7d70f0da00 in main /home/lkannappan/roms/project/singapore/Build_romsG/master.f90:50
#4 0x7f7d6bf01bf6 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21bf6)
#5 0x7f7d70f0d1d9 in _start (/home/lkannappan/roms/project/singapore/romsG+0x1f0d1d9)
Here is my updated error log
roms error.txt
updated log from terminal
(28.92 KiB) Downloaded 868 times
robertson
#8 Unread post by robertson »
Is it possible that you are trying to run an OpenMP (shared memory) ROMS executable using an 'mpirun' command? You have -fopenmp in your list of flags but the multiple occurrences of:
Model Input Parameters: ROMS/TOMS version 3.9
Monday - May 3, 2021 - 10:50:38 PM
suggest MPI is being used with a non-MPI compiled executable.
