A confusion in the run
sun_92
#1 Unread post by sun_92 »
Hey all,
I have given a test simulation with the biological module fennel on, however the model stops at one point each time. I'm getting this error.
SET_2DFLD - current model time exceeds ending value for variable: Tair
TDAYS = 360.0035
Data Tmin = 0.0000 Data Tmax = 360.0000
Data Tstr = 0.0000 Data Tend = 45.0000
TINTRP1 = 360.0000 TINTRP2 = 360.0000
FAC1 = -0.0035 FAC2 = 0.0035
I'm attaching the log file of my run
Please help me.
log_fennel_rst_13feb.txt
(18.17 MiB) Downloaded 300 times
Re: A confusion in the run
What we need to see is the ncdump on your Tair file. Are these monthly means you are cycling through? Do you have the cycle_length attribute set?
sun_92
#3 Unread post by sun_92 »
I'm attaching the ncdump txt of the forcing file. Yes we have set cycle length to 360. I'm facing problem only when i switch on biology, the same files are running fine without fennel. Kindly help me
frc.txt
(7.58 KiB) Downloaded 299 times
sun_92
#4 Unread post by sun_92 »
Can anyone please help me with the simulation over Indian domain using bio fennel? It stops exactly after an year in the climatological simulation. However the same files are running fine with Physical simulation. Please can you help me in this regard?
sun_92
#5 Unread post by sun_92 »
Can anyone please help me with the run. I'm attaching the screenshot of the error
sun_92
#6 Unread post by sun_92 »
I tried with cycle length 360 and 365.25 both are causing errors, however, my physical run is successful with the same files. I'm stuck with this error since a long time, so kindly help me.
#7 Unread post by kate »
This is why people invest in learning debuggers such as totalview, ddt, gdb. It's a tough road, but sometimes it's the only way to figure out what's really going on.
