Problems compiling in Windows
gislita
#1 Unread post by gislita »
I am trying to compile ROMS using Compaq Visual Fortran 6.1 in a Windows XP computer, and I am unable to make it work. I have tried to modify the jobcomp file, but I am getting too many errors when trying to compile and build the executable. I wonder if somebody can please help me in this matter. I know most people are not using Windows as their operating system, but I thought this should work anyway in a Windows computer. Therefore, I was wondering if somebody knows how my jobcomp has to be defined for the compilation process to work.
Again, any help would be highly appreciated. Thank you very much
Juan
i had tried a long time ago to compile roms in that utility, but had some troubles. I think I eventually got it to work, but needed to set the correct preprocessor step, library locations, etc.
I suggest on a Windows machine that you use the Cygwin environment. I have found it much easier to just compile at the command prompt using make. There has been a lot of effort to get the makefiles and the compilers folder to function properly.
