SOS : kuroshio in east china sea
zhang_1988
Location: institute of oceanology,chinese academy of science
#1 Unread post by zhang_1988 »
Dear everyone
recently, i am working on simulating kuroshio
below is my setting
6.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient(m2/s) for tracer 01: temp
6.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient(m2/s) for tracer 02: salt
6.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient(m2/s) for momentum.
1.0000E-06 Akt_bak(01) Background vertical mixing coefficient (m2/s)for tracer 01: temp
1.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)for tracer 02: salt
1.0000E-05 Akv_bak Background vertical mixing coefficient (m2/s)for momentum.
5.0000E-06 Akk_bak Background vertical mixing coefficient (m2/s)for turbulent energy.
5.0000E-06 Akp_bak Background vertical mixing coefficient (m2/s)for turbulent generic statistical field.
2.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) usedin vertical coordinate stretching.
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)for tracer 01: temp
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)for free-surface.
3.0000E+01 M2nudg Nudging/relaxation time scale (days)for 2D momentum.
3.0000E+01 M3nudg Nudging/relaxation time scale (days)for 3D momentum.
0.0000E+00 obcfac Factor between passive and activeopen boundary conditions.
my simulate area :
simulate area
simulate area
simulate area.png (14.8 KiB) Viewed 4939 times
grid size is 5'*5'
Lateral Boundary Condition Type
LBC(isFsur) == Cha Cha Cha Cha ! free-surface
LBC(isUbar) == Fla Fla Fla Fla ! 2D U-momentum
LBC(isVbar) == Fla Fla Fla Fla ! 2D V-momentum
LBC(isUvel) == RadNud RadNud RadNud RadNud ! 3D U-momentum
LBC(isVvel) == RadNud RadNud RadNud RadNud ! 3D V-momentum
LBC(isMtke) == Rad Rad Rad Rad ! mixing TKE
LBC(isTvar) == RadNud RadNud RadNud RadNud ! temperature
RadNud RadNud RadNud RadNud ! salinity
Useing HYCOM reanalysis data to make initial conditions and bounday conditions
Wind force comes from NCEP
Here comes focus ; simulate for two years ;The outcome is some kind driving me crazy
the surface flow :
surfrce.rar
surface flow
(25.89 MiB) Downloaded 554 times
flow at 200m level :
flow-200m.rar
flow at 200m level
(17.59 MiB) Downloaded 453 times
from all the graphs in the .rar, there are two annoying eddies sucking all the waters which i want them to flow through Okinawa trough out the trough .
And , i am trapped in this situation .
sos
sos
Any advice would be appreciated sincerely
Re: SOS : kuroshio in east china sea
I am not familiar with the .rar file format. Your .png and your .jpg show up nicely, though.
0.0000E+00 obcfac Factor between passive and active open boundary conditions.
What does this mean? Your Tnudg and friends are set to 30 days for the outgoing timescale. I have my incoming timescale set to 3 days, so you'd need to set obcfac to 10 to get that (if that's what you want). Anyway, obcfac is meant to be larger than one, so that the nudging is stronger on inflow than outflow.
zhang_1988
#3 Unread post by zhang_1988 »
Thanks kate .i will make a try with reducing the Tnudg and other nudge parameter.
In addition, May i have your opinion about the other parameters like nl_tnu1,nl_tnu2 and nl_visc2 setting to be 60 60 60 .
For horizontal smoothing, the "right" values depend on grid spacing. All I know about it is here.
xwbin
#5 Unread post by xwbin »
I have a question about your theta_s,theta_b and Tcline.My model area is South China Sea,and I set the theta_s=7,theta_b=1 like the example in romswiki.I also set the Tcline=300 which in your model is 10.I couldn't tell whether my parameter setting is right or not.You and me have the same area like the western Pacific and Kuroshio.Can you give me some advise on these three parameters?
Looking forward to your reply.
