0: RESHAPE: not enough elements in SOURCE array
donghua
#1 Unread post by donghua »
Hi all
I tried to run a case with nested grid. Simulations with only parent or child grid are successful. But the result of the child grid is problematic. So we'd like to run a case with nested grid.
The child grid is a refined grid and completely inside the parent grid. The child grid has 15 sigma levels, while the parent grid has 42 sigma levels. I used contact.m to generate the contact file.
In the test run log file, it seems that the model can read two grids. But I got these errors:
I wonder if anyone has got this problem before. Could you guys give me some suggestion?
Thanks a million in advance!
Donghua
ocean_66m22m_wave.in
(122.09 KiB) Downloaded 211 times
test.out.639359.txt
(65.42 KiB) Downloaded 228 times
Re: 0: RESHAPE: not enough elements in SOURCE array
My suggestion is to use the same number of vertical levels in both grids to see if that runs.
donghua
#3 Unread post by donghua »
Thanks, Kate
I will try to run a job with the same sigma levels.
