Question of reading the bry.nc
lbt19
#1 Unread post by lbt19 »
Hi everyone,
I am a new user of ROMS. The model don't read the Input Boundary file(bry.nc),after reading the forcing file ,just skip. And I am trying to figure out the problem for couple of days,but still can't find the reason.
Thanks.
My CPP options
** Options for cs.
** Application flag: cs
** Input script: ocean_cs.in
#define NO_HIS
#undef NETCDF4
#undef PARALLEL_IO
#undef OFFLINE_FLOATS
#ifdef SOLVE3D
#define SPLINES
#undef WET_DRY
#undef T_PASSIVE
#ifdef T_PASSIVE
#define ANA_PASSIVE
#define TRC_PSOURCE
#define ANA_TRC_PSOURCE
#define AGE_PASSIVE
#define NO_WRITE_GRID
#undef OUT_DOUBLE
#define RST_SINGLE
#define AVERAGES2
#ifdef SOLVE3D
#undef AVERAGES_DETIDE
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#ifdef SOLVE3D
#define UV_LDRAG
#undef UV_SADVECTION
#ifdef SOLVE3D
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef TS_MPDATA
#undef UV_SMAGORINSKY
#undef VISC_3DCOEF
#define VISC_GRID
#define SPONGE
#ifdef SOLVE3D
#define MIX_GEO_TS
#define DIFF_GRID
#ifdef SOLVE3D
#define SOLAR_SOURCE
#define WTYPE_GRID
#undef LMD_MIXING
#ifdef LMD_MIXING
#define LMD_RIMIX
#define LMD_CONVEC
#define LMD_SKPP
#undef LMD_BKPP
#define LMD_NONLOCAL
#define LMD_SHAPIRO
#undef LMD_DDMIX
#define GLS_MIXING
#undef MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
#ifdef SOLVE3D
#define NCEP_FLUXES
#ifdef SOLVE3D
#define SCORRECTION
#undef QCORRECTION
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define RADIATION_2D
#ifdef SOLVE3D
#else
#define ANA_SMFLUX
#define LTIDES
#ifdef LTIDES
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
The .in file
! Application title.
TITLE = cs
! C-preprocessing Flag.
MyAppCPP = cs
VARNAME = /disk1/greensky/libingtian/ROMS/project1/varinfo.dat
! Number of nested grids.
Ngrids = 1
! Number of grid nesting layers. This parameter is used to allow refinement
NestLayers = 1
GridsInLayer = 1
! these parameters correctly.
Lm == 119 ! Number of I-direction INTERIOR RHO-points
Mm == 191 ! Number of J-direction INTERIOR RHO-points
N == 5 ! Number of vertical levels
Nbed = 0 ! Number of sediment bed layers
NAT = 2 ! Number of active tracers (usually, 2)
NPT = 0 ! Number of inactive passive tracers
NCS = 0 ! Number of cohesive (mud) sediment tracers
NNS = 0 ! Number of non-cohesive (sand) sediment tracers
NtileI == 1 ! I-direction partition
NtileJ == 4 ! J-direction partition
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Clo Rad Rad Clo ! free-surface
LBC(isUbar) == Clo Rad Rad Clo ! 2D U-momentum
LBC(isVbar) == Clo Rad Rad Clo ! 2D V-momentum
LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum
LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
LBC(isMtke) == Clo Rad Rad Clo ! mixing TKE
LBC(isTvar) == Clo Rad Rad Clo \ ! temperature
Clo Rad Rad Clo ! salinity
! conditions keywords.
ad_LBC(isFsur) == Clo Rad Rad Clo ! free-surface
ad_LBC(isUbar) == Clo Rad Rad Clo ! 2D U-momentum
ad_LBC(isVbar) == Clo Rad Rad Clo ! 2D U-momentum
ad_LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum
ad_LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
ad_LBC(isMtke) == Clo Rad Rad Clo ! mixing TKE
ad_LBC(isTvar) == Clo Rad Rad Clo \ ! temperature
VolCons(west) == F ! western boundary
VolCons(east) == T ! eastern boundary
VolCons(south) == T ! southern boundary
VolCons(north) == F ! northern boundary
ad_VolCons(west) == F ! western boundary
ad_VolCons(east) == T ! eastern boundary
ad_VolCons(south) == T ! southern boundary
ad_VolCons(north) == F ! northern boundary
! Time-Stepping parameters.
NTIMES == 105120 !一年
DT == 300d0 !5分钟
NDTFAST == 30
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == -1
LcycleRST == F
NRST == 8640
NSTA == 1
NFLT == 1
NINFO == 1
LDEFOUT == T
NHIS == 8640
NDEFHIS == 105120
NTSAVG == 1
NAVG == 8640
NDEFAVG == 105120
NTSDIA == 1
NDIA == 8640
NDEFDIA == 105120
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 72
NDEFADJ == 0
NSFF == 72
NOBC == 72
LmultiGST = F ! one eigenvector per file
MaxIterGST = 500 ! maximum number of iterations
Ritz_tol = 1.0d-15
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 5.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
LuvSponge == F ! horizontal momentum
LtracerSponge == F F ! temperature, salinity, inert
AKT_BAK == 1.0d-6 1.0d-6 ! m2/s
AKV_BAK == 1.0d-5 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
CRGBAN_CW == 100.0d0 ! Craig and Banner wave breaking
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
THETA_S == 3.0d0 ! surface stretching parameter
THETA_B == 0.4d0 ! bottom stretching parameter
TCLINE == 2.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20090101.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*100.0d0 ! days
ZNUDG == 0.0d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 0.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 14.0d0 ! Celsius
S0 == 35.0d0 ! nondimensional
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 0.0d0 ! nondimensional
GAMMA2 == 1.0d0
LuvSrc == F ! horizontal momentum transport
LwSrc == F ! volume vertical influx
! [1:NAT+NPT,Ngrids]. See glossary below for details.
LtracerSrc == F F ! temperature, salinity, inert
LsshCLM == T ! sea-surface height
Lm2CLM == T ! 2D momentum
Lm3CLM == T ! 3D momentum
LtracerCLM == T T ! temperature, salinity, inert
LnudgeM2CLM == F ! 2D momentum
LnudgeM3CLM == F ! 3D momentum
LnudgeTCLM == F F ! temperature, salinity, inert
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isTvar) == F F ! NT tracers
Fstate(isFsur) == F ! free-surface
Fstate(isUbar) == F ! 2D U-momentum
Fstate(isVbar) == F ! 2D V-momentum
Fstate(isUvel) == F ! 3D U-momentum
Fstate(isVvel) == F ! 3D V-momentum
Fstate(isTvar) == F F ! NT tracers
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
Fstate(isTsur) == F F ! NT surface tracers flux
! red noise processes.
SO_decay == 2.0d0 ! days
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUbar) == 1.0d0 ! 2D U-momentum
SO_sdev(isVbar) == 1.0d0 ! 2D V-momentum
SO_sdev(isUvel) == 1.0d0 ! 3D U-momentum
SO_sdev(isVvel) == 1.0d0 ! 3D V-momentum
SO_sdev(isTvar) == 1.0d0 1.0d0 ! NT tracers
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idu3dE) == F ! u_eastward 3D U-eastward at RHO-points
Hout(idv3dN) == F ! v_northward 3D V-northward at RHO-points
Hout(idWvel) == T ! w 3D W-velocity
Hout(idOvel) == T ! omega omega vertical velocity
Hout(idUbar) == T ! ubar 2D U-velocity
Hout(idVbar) == T ! vbar 2D V-velocity
Hout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Hout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Hout(idBath) == T ! bath time-dependent bathymetry
Hout(idTvar) == T T ! temp, salt temperature and salinity
Hout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Hout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Hout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Hout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Hout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Hout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Hout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Hout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Hout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Hout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Hout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Hout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Hout(idWamp) == F ! Hwave wave height
Hout(idWlen) == F ! Lwave wave length
Hout(idWdir) == F ! Dwave wave direction
Hout(idWorb) == F ! Ub_swan wave bottom orbital velocity
Hout(idWdis) == F ! Wave_dissip wave dissipation
Hout(idPair) == F ! Pair surface air pressure
Hout(idUair) == F ! Uair surface U-wind component
Hout(idVair) == F ! Vair surface V-wind component
Hout(idDano) == F ! rho density anomaly
Hout(idMtls) == F ! gls turbulent length scale
Hout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stress critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == T T T T T T T T T F F F F F F F
Aout(idUvel) == T ! u 3D U-velocity
Aout(idVvel) == T ! v 3D V-velocity
Aout(idu3dE) == F ! u_eastward 3D U-eastward at RHO-points
Aout(idv3dN) == F ! v_northward 3D V-northward at RHO-points
Aout(idWvel) == T ! w 3D W-velocity
Aout(idOvel) == T ! omega omega vertical velocity
Aout(idUbar) == T ! ubar 2D U-velocity
Aout(idVbar) == T ! vbar 2D V-velocity
Aout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Aout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Aout(idFsur) == T ! zeta free-surface
Aout(idTvar) == T T ! temp, salt temperature and salinity
Aout(idUsms) == F ! sustr surface U-stress
Aout(idVsms) == F ! svstr surface V-stress
Aout(idUbms) == F ! bustr bottom U-stress
Aout(idVbms) == F ! bvstr bottom V-stress
Aout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Aout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Aout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Aout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Aout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Aout(idU2Sd) == F ! ubar_stokes 2D U-Stokes velocity
Aout(idV2Sd) == F ! vbar_stokes 2D V-Stokes velocity
Aout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Aout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Aout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Aout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Aout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Aout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Aout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Aout(idU3Sd) == F ! u_stokes 3D U-Stokes velocity
Aout(idV3Sd) == F ! v_stokes 3D V-Stokes velocity
Aout(idPair) == F ! Pair surface air pressure
Aout(idUair) == F ! Uair surface U-wind component
Aout(idVair) == F ! Vair surface V-wind component
Aout(idTsur) == F F ! shflux, ssflux surface net heat and salt flux
Aout(idLhea) == F ! latent latent heat flux
Aout(idShea) == F ! sensible sensible heat flux
Aout(idLrad) == F ! lwrad longwave radiation flux
Aout(idSrad) == F ! swrad shortwave radiation flux
Aout(idevap) == F ! evaporation evaporation rate
Aout(idrain) == F ! rain precipitation rate
Aout(idDano) == F ! rho density anomaly
Aout(idVvis) == F ! AKv vertical viscosity
Aout(idTdif) == F ! AKt vertical T-diffusion
Aout(idSdif) == F ! AKs vertical Salinity diffusion
Aout(idHsbl) == F ! Hsbl depth of surface boundary layer
Aout(idHbbl) == F ! Hbbl depth of bottom boundary layer
Aout(idu3dD) == F ! u_detided detided 3D U-velocity
Aout(idv3dD) == F ! v_detided detided 3D V-velocity
Aout(idu2dD) == F ! ubar_detided detided 2D U-velocity
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
Aout(idFsuD) == F ! zeta_detided detided free-surface
Aout(idTrcD) == F F ! temp_detided, ... detided temperature and salinity
Aout(idHUav) == F ! Huon u-volume flux, Huon
Aout(idHVav) == F ! Hvom v-volume flux, Hvom
Aout(idUUav) == F ! uu quadratic <u*u> term
Aout(idUVav) == F ! uv quadratic <u*v> term
Aout(idVVav) == F ! vv quadratic <v*v> term
Aout(idU2av) == F ! ubar2 quadratic <ubar*ubar> term
Aout(idV2av) == F ! vbar2 quadratic <vbar*vbar> term
Aout(idZZav) == F ! zeta2 quadratic <zeta*zeta> term
Aout(idTTav) == F F ! temp_2, ... quadratic <t*t> tracer terms
Aout(idUTav) == F F ! u_temp, ... quadratic <u*t> tracer terms
Aout(idVTav) == F F ! v_temp, ... quadratic <v*t> tracer terms
Aout(iHUTav) == F F ! Huon_temp, ... tracer volume flux, <Huon*t>
Aout(iHVTav) == F F ! Hvom_temp, ... tracer volume flux, <Hvom*t>
Aout(inert) == T ! dye_01, ... inert passive tracers
Dout(M2rate) == T ! ubar_accel, ... acceleration
Dout(M2pgrd) == T ! ubar_prsgrd, ... pressure gradient
Dout(M2fcor) == T ! ubar_cor, ... Coriolis force
Dout(M2hadv) == T ! ubar_hadv, ... horizontal total advection
Dout(M2xadv) == T ! ubar_xadv, ... horizontal XI-advection
Dout(M2yadv) == T ! ubar_yadv, ... horizontal ETA-advection
Dout(M2hrad) == T ! ubar_hrad, ... horizontal total radiation stress
Dout(M2hvis) == T ! ubar_hvisc, ... horizontal total viscosity
Dout(M2xvis) == T ! ubar_xvisc, ... horizontal XI-viscosity
Dout(M2yvis) == T ! ubar_yvisc, ... horizontal ETA-viscosity
Dout(M2sstr) == T ! ubar_sstr, ... surface stress
Dout(M2bstr) == T ! ubar_bstr, ... bottom stress
Dout(M3rate) == T ! u_accel, ... acceleration
Dout(M3pgrd) == T ! u_prsgrd, ... pressure gradient
Dout(M3fcor) == T ! u_cor, ... Coriolis force
Dout(M3hadv) == T ! u_hadv, ... horizontal total advection
Dout(M3xadv) == T ! u_xadv, ... horizontal XI-advection
Dout(M3yadv) == T ! u_yadv, ... horizontal ETA-advection
Dout(M3vadv) == T ! u_vadv, ... vertical advection
Dout(M3hrad) == T ! u_hrad, ... horizontal total radiation stress
Dout(M3vrad) == T ! u_vrad, ... vertical radiation stress
Dout(M3hvis) == T ! u_hvisc, ... horizontal total viscosity
Dout(M3xvis) == T ! u_xvisc, ... horizontal XI-viscosity
Dout(M3yvis) == T ! u_yvisc, ... horizontal ETA-viscosity
Dout(M3vvis) == T ! u_vvisc, ... vertical viscosity
Dout(iTrate) == T T ! temp_rate, ... time rate of change
Dout(iThadv) == T T ! temp_hadv, ... horizontal total advection
Dout(iTxadv) == T T ! temp_xadv, ... horizontal XI-advection
Dout(iTyadv) == T T ! temp_yadv, ... horizontal ETA-advection
Dout(iTvadv) == T T ! temp_vadv, ... vertical advection
Dout(iThdif) == T T ! temp_hdiff, ... horizontal total diffusion
Dout(iTxdif) == T T ! temp_xdiff, ... horizontal XI-diffusion
Dout(iTydif) == T T ! temp_ydiff, ... horizontal ETA-diffusion
Dout(iTsdif) == T T ! temp_sdiff, ... horizontal S-diffusion
Dout(iTvdif) == T T ! temp_vdiff, ... vertical diffusion
NUSER = 0
USER = 0.d0
! NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
NC_DEFLATE = 1 ! if non-zero, turn on deflate filter
NC_DLEVEL = 1 ! deflate level [0-9]
GRDNAME == roms_cs_grd.nc
ININAME == roms_cs_ini.nc
ITLNAME == ocean_itl.nc
IRPNAME == ocean_irp.nc
IADNAME == ocean_iad.nc
FWDNAME == ocean_fwd.nc
ADSNAME == ocean_ads.nc
NGCNAME = ocean_ngc.nc
! Input lateral boundary conditions and climatology file names. The
! USER has the option to split input data time records into several
! NetCDF files (see prologue instructions above). If so, use a single
! line per entry with a vertical bar (|) symbol after each entry,
! except the last one.
BRYNAME == roms_cs_bry.nc
CLMNAME == ocean_clm.nc
NUDNAME == ocean_nud.nc
SSFNAME == ocean_rivers.nc
! Input forcing NetCDF file name(s). The USER has the option to enter
! have different files for wind products, heat fluxes, tides, etc.
! The model will scan the file list and will read the needed data from
! the first file in the list containing the forcing field. Therefore,
! and so on. It is also possible to split input data time records into
! several NetCDF files (see prologue instructions above). Use a single line
! per entry with a continuation (\) or vertical bar (|) symbol after each
! entry, except the last one.
NFFILES == 1 ! number of unique forcing files
FRCNAME == roms_cs_frc.nc ! forcing file 1, grid 1
GSTNAME == ocean_cs_gst.nc
RSTNAME == ocean_cs_rst.nc
HISNAME == ocean_cs_his.nc
TLMNAME == ocean_cs_tlm.nc
TLFNAME == ocean_cs_tlf.nc
ADJNAME == ocean_cs_adj.nc
AVGNAME == ocean_cs_avg.nc
DIANAME == ocean_cs_dia.nc
STANAME == ocean_cs_sta.nc
FLTNAME == ocean_cs_flt.nc
APARNAM = ROMS/External/s4dvar.in
SPOSNAM = ROMS/External/stations.in
FPOSNAM = ROMS/External/floats.in
BPARNAM = ROMS/External/bio_Fennel.in
SPARNAM = ROMS/External/sediment.in
USRNAME = ROMS/External/MyFile.dat
Parts out the out(.o file)
105120 ntimes Number of timesteps for 3-D equations.
-1 nrrec Number of restart records to read from disk.
F LcycleRST Switch to recycle time-records in restart file.
2880 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
2880 nHIS Number of timesteps between the writing fields
into history file.
105120 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
2880 nAVG Number of timesteps between the writing of
105120 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
2.000 Tcline S-coordinate surface/bottom layer width (m) used
20090101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+02 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
Output Restart File: ocean_cs_rst.nc
Prefix for History Files: ocean_cs_his
Prefix for Averages Files: ocean_cs_avg
Input Grid File: roms_cs_grd.nc
Input Nonlinear Initial File: roms_cs_ini.nc
Input Forcing File 01: roms_cs_frc.nc
Tile partition information for Grid 01: 0119x0191x0005 tiling: 001x004
tile Istr Iend Jstr Jend Npts
0 1 119 1 48 28560
1 1 119 49 96 28560
2 1 119 97 144 28560
3 1 119 145 191 27965
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 119.50 0.50 48.50 RHO-points
1 0.50 119.50 48.50 96.50 RHO-points
2 0.50 119.50 96.50 144.50 RHO-points
3 0.50 119.50 144.50 191.50 RHO-points
0 1.00 119.00 0.50 48.50 U-points
1 1.00 119.00 48.50 96.50 U-points
2 1.00 119.00 96.50 144.50 U-points
3 1.00 119.00 144.50 191.50 U-points
0 0.50 119.50 1.00 48.50 V-points
1 0.50 119.50 48.50 96.50 V-points
2 0.50 119.50 96.50 144.50 V-points
3 0.50 119.50 144.50 191.00 V-points
HaloSizeI(1) = 258
HaloSizeJ(1) = 120
TileSide(1) = 123
TileSize(1) = 6642
zeta 1 Closed Radiation Radiation Closed
ubar 1 Closed Radiation Radiation Closed
vbar 1 Closed Radiation Radiation Closed
u 1 Closed Radiation Radiation Closed
v 1 Closed Radiation Radiation Closed
temp 1 Closed Radiation Radiation Closed
salt 1 Closed Radiation Radiation Closed
tke 1 Closed Radiation Radiation Closed
cs cs
ADD_FSOBC Adding tidal elevation to processed OBC data.
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
SCORRECTION Surface salinity flux correction.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 29292) is active.
Node # 1 (pid= 29293) is active.
Node # 2 (pid= 29294) is active.
Node # 3 (pid= 29295) is active.
Vertical S-coordinate System:
5 0.0000000 0.0000000 0.000 0.000 0.000 0.000
4 -0.2000000 -0.0798591 -0.400 -0.400 -80.179 -159.959
3 -0.4000000 -0.2260381 -0.800 -0.800 -226.612 -452.424
2 -0.6000000 -0.4405834 -1.200 -1.200 -441.343 -881.486
1 -0.8000000 -0.6856605 -1.600 -1.600 -686.575 -1371.550
0 -1.0000000 -1.0000000 -2.000 -2.000 -1001.000 -2000.000
Re: Question of reading the bry.nc
Some boundary conditions require external boundary values, some do not. You have chosen those that do not:
ROMS will check to make sure it needs external values before trying to read them.
lbt19
#3 Unread post by lbt19 »
kate wrote:Some boundary conditions require external boundary values, some do not. You have chosen those that do not:
Thank you,Kate.It works when I change the boundary conditions to Clamped and that it really helps much,thanks again.
