Hi everyone,
I am a new user of ROMS. The model don't read the Input Boundary file(bry.nc),after reading the forcing file ,just skip. And I am trying to figure out the problem for couple of days,but still can't find the reason.
Thanks.
My CPP options
** Options for cs.
** Application flag: cs
** Input script: ocean_cs.in
#define NO_HIS
#undef NETCDF4
#undef PARALLEL_IO
#undef OFFLINE_FLOATS
#ifdef SOLVE3D
#define SPLINES
#undef WET_DRY
#undef T_PASSIVE
#ifdef T_PASSIVE
#define ANA_PASSIVE
#define TRC_PSOURCE
#define ANA_TRC_PSOURCE
#define AGE_PASSIVE
#define NO_WRITE_GRID
#undef OUT_DOUBLE
#define RST_SINGLE
#define AVERAGES2
#ifdef SOLVE3D
#undef AVERAGES_DETIDE
#undef DIAGNOSTICS_TS
#undef DIAGNOSTICS_UV
#ifdef SOLVE3D
#define UV_LDRAG
#undef UV_SADVECTION
#ifdef SOLVE3D
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#undef TS_MPDATA
#undef UV_SMAGORINSKY
#undef VISC_3DCOEF
#define VISC_GRID
#define SPONGE
#ifdef SOLVE3D
#define MIX_GEO_TS
#define DIFF_GRID
#ifdef SOLVE3D
#define SOLAR_SOURCE
#define WTYPE_GRID
#undef LMD_MIXING
#ifdef LMD_MIXING
#define LMD_RIMIX
#define LMD_CONVEC
#define LMD_SKPP
#undef LMD_BKPP
#define LMD_NONLOCAL
#define LMD_SHAPIRO
#undef LMD_DDMIX
#define GLS_MIXING
#undef MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
#ifdef SOLVE3D
#define NCEP_FLUXES
#ifdef SOLVE3D
#define SCORRECTION
#undef QCORRECTION
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define RADIATION_2D
#ifdef SOLVE3D
#else
#define ANA_SMFLUX
#define LTIDES
#ifdef LTIDES
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
The .in file
! Application title.
TITLE = cs
! C-preprocessing Flag.
MyAppCPP = cs
! Input variable information file name. This file needs to be processed
VARNAME = /disk1/greensky/libingtian/ROMS/project1/varinfo.dat
! Number of nested grids.
Ngrids = 1
! Number of grid nesting layers. This parameter is used to allow refinement
! and composite grid combinations.
NestLayers = 1
! Number of grids in each nesting layer [1:NestLayers].
GridsInLayer = 1
! Grid dimension parameters. See notes below in the Glossary for how to set
! these parameters correctly.
Lm == 119 ! Number of I-direction INTERIOR RHO-points
Mm == 191 ! Number of J-direction INTERIOR RHO-points
N == 5 ! Number of vertical levels
Nbed = 0 ! Number of sediment bed layers
NAT = 2 ! Number of active tracers (usually, 2)
NPT = 0 ! Number of inactive passive tracers
NCS = 0 ! Number of cohesive (mud) sediment tracers
NNS = 0 ! Number of non-cohesive (sand) sediment tracers
! Domain decomposition parameters for serial, distributed-memory or
! shared-memory configurations used to determine tile horizontal range
! indices (Istr,Iend) and (Jstr,Jend), [1:Ngrids].
NtileI == 1 ! I-direction partition
NtileJ == 4 ! J-direction partition
! Set lateral boundary conditions keyword. Notice that a value is expected
! for each boundary segment per nested grid for each state variable.
! Each tracer variable requires [1:4,1:NAT+NPT,Ngrids] values. Otherwise,
! [1:4,1:Ngrids] values are expected for other variables. The boundary
! order is: 1=west, 2=south, 3=east, and 4=north. That is, anticlockwise
! starting at the western boundary.
! The keyword is case insensitive and usually has three characters. However,
! it is possible to have compound keywords, if applicable. For example, the
! keyword "RadNud" implies radiation boundary condition with nudging. This
! combination is usually used in active/passive radiation conditions.
! Keyword Lateral Boundary Condition Type
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Clo Rad Rad Clo ! free-surface
LBC(isUbar) == Clo Rad Rad Clo ! 2D U-momentum
LBC(isVbar) == Clo Rad Rad Clo ! 2D V-momentum
LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum
LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
LBC(isMtke) == Clo Rad Rad Clo ! mixing TKE
LBC(isTvar) == Clo Rad Rad Clo \ ! temperature
Clo Rad Rad Clo ! salinity
! conditions keywords.
ad_LBC(isFsur) == Clo Rad Rad Clo ! free-surface
ad_LBC(isUbar) == Clo Rad Rad Clo ! 2D U-momentum
ad_LBC(isVbar) == Clo Rad Rad Clo ! 2D U-momentum
ad_LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum
ad_LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
ad_LBC(isMtke) == Clo Rad Rad Clo ! mixing TKE
ad_LBC(isTvar) == Clo Rad Rad Clo \ ! temperature
! Set lateral open boundary edge volume conservation switch for
! nonlinear model and adjoint-based algorithms. Usually activated
! with radiation boundary conditions to enforce global mass
! conservation, except if tidal forcing is enabled. [1:Ngrids].
VolCons(west) == F ! western boundary
VolCons(east) == T ! eastern boundary
VolCons(south) == T ! southern boundary
VolCons(north) == F ! northern boundary
ad_VolCons(west) == F ! western boundary
ad_VolCons(east) == T ! eastern boundary
ad_VolCons(south) == T ! southern boundary
ad_VolCons(north) == F ! northern boundary
! Time-Stepping parameters.
NTIMES == 105120 !一年
DT == 300d0 !5分钟
NDTFAST == 30
! Model iteration loops parameters.
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Number of eigenvalues (NEV) and eigenvectors (NCV) to compute for the
! Lanczos/Arnoldi problem in the Generalized Stability Theory (GST)
! analysis. NCV must be greater than NEV (see documentation below).
NEV = 2 ! Number of eigenvalues
NCV = 10 ! Number of eigenvectors
! Input/Output parameters.
NRREC == -1
LcycleRST == F
NRST == 8640
NSTA == 1
NFLT == 1
NINFO == 1
! Output history, average, diagnostic files parameters.
LDEFOUT == T
NHIS == 8640
NDEFHIS == 105120
NTSAVG == 1
NAVG == 8640
NDEFAVG == 105120
NTSDIA == 1
NDIA == 8640
NDEFDIA == 105120
! Output tangent linear and adjoint models parameters.
LcycleTLM == F
NTLM == 72
NDEFTLM == 0
LcycleADJ == F
NADJ == 72
NDEFADJ == 0
NSFF == 72
NOBC == 72
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
LrstGST = F ! GST restart switch
MaxIterGST = 500 ! maximum number of iterations
NGST = 10 ! check pointing interval
! Relative accuracy of the Ritz values computed in the GST analysis.
Ritz_tol = 1.0d-15
! Harmonic/biharmonic horizontal diffusion of tracer for nonlinear model
! and adjoint-based algorithms: [1:NAT+NPT,Ngrids].
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
! Harmonic/biharmonic, horizontal viscosity coefficient for nonlinear model
! and adjoint-based algorithms: [Ngrids].
VISC2 == 5.0d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
! Logical switches (TRUE/FALSE) to increase/decrease horizontal viscosity
! and/or diffusivity in specific areas of the application domain (like
! sponge areas) for the desired application grid.
LuvSponge == F ! horizontal momentum
LtracerSponge == F F ! temperature, salinity, inert
! Vertical mixing coefficients for tracers in nonlinear model and
! basic state scale factor in adjoint-based algorithms: [1:NAT+NPT,Ngrids]
AKT_BAK == 1.0d-6 1.0d-6 ! m2/s
ad_AKT_fac == 1.0d0 1.0d0 ! nondimensional
! Vertical mixing coefficient for momentum for nonlinear model and
! basic state scale factor in adjoint-based algorithms: [Ngrids].
AKV_BAK == 1.0d-5 ! m2/s
ad_AKV_fac == 1.0d0 ! nondimensional
! Turbulent closure parameters.
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
! Generic length-scale turbulence closure parameters.
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
! Constants used in surface turbulent kinetic energy flux computation.
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
ZOS_HSIG_ALPHA == 0.5d0 ! roughness from wave amplitude
SZ_ALPHA == 0.25d0 ! roughness from wave dissipation
CRGBAN_CW == 100.0d0 ! Craig and Banner wave breaking
! Constants used in momentum stress computation.
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
! Height (m) of atmospheric measurements for Bulk fluxes parameterization.
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 3.0d0 ! surface stretching parameter
THETA_B == 0.4d0 ! bottom stretching parameter
TCLINE == 2.0d0 ! critical depth (m)
! Mean Density and Brunt-Vaisala frequency.
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! Time-stamp assigned for model initialization, reference time
! origin for tidal forcing, and model reference time for output
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20090101.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*100.0d0 ! days
ZNUDG == 0.0d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 0.0d0 ! nondimensional
! Linear equation of State parameters:
R0 == 1027.0d0 ! kg/m3
T0 == 14.0d0 ! Celsius
S0 == 35.0d0 ! nondimensional
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 0.0d0 ! nondimensional
! Slipperiness parameter: 1.0 (free slip) or -1.0 (no slip)
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to activate horizontal momentum transport
! point Sources/Sinks (like river runoff transport) and mass point
! Sources/Sinks (like volume vertical influx), [1:Ngrids].
LuvSrc == F ! horizontal momentum transport
LwSrc == F ! volume vertical influx
! Logical switches (TRUE/FALSE) to activate tracers point Sources/Sinks
! (like river runoff) and to specify which tracer variables to consider:
! [1:NAT+NPT,Ngrids]. See glossary below for details.
LtracerSrc == F F ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to read and process climatology fields.
! See glossary below for details.
LsshCLM == T ! sea-surface height
Lm2CLM == T ! 2D momentum
Lm3CLM == T ! 3D momentum
LtracerCLM == T T ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to nudge the desired climatology field(s).
! If not analytical climatology fields, users need to turn ON the logical
! switches above to process the fields from the climatology NetCDF file
! that are needed for nudging. See glossary below for details.
LnudgeM2CLM == F ! 2D momentum
LnudgeM3CLM == F ! 3D momentum
LnudgeTCLM == F F ! temperature, salinity, inert
! Starting (DstrS) and ending (DendS) day for adjoint sensitivity forcing.
! DstrS must be less or equal to DendS. If both values are zero, their
! values are reset internally to the full range of the adjoint integration.
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
! Starting and ending vertical levels of the 3D adjoint state variables
! whose sensitivity is required.
KstrS == 1 ! starting level
KendS == 1 ! ending level
! Logical switches (TRUE/FALSE) to specify the adjoint state variables
Lstate(isFsur) == F ! free-surface
Lstate(isUbar) == F ! 2D U-momentum
Lstate(isVbar) == F ! 2D V-momentum
Lstate(isUvel) == F ! 3D U-momentum
Lstate(isVvel) == F ! 3D V-momentum
Lstate(isTvar) == F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
Fstate(isUbar) == F ! 2D U-momentum
Fstate(isVbar) == F ! 2D V-momentum
Fstate(isUvel) == F ! 3D U-momentum
Fstate(isVvel) == F ! 3D V-momentum
Fstate(isTvar) == F F ! NT tracers
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
Fstate(isTsur) == F F ! NT surface tracers flux
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUbar) == 1.0d0 ! 2D U-momentum
SO_sdev(isVbar) == 1.0d0 ! 2D V-momentum
SO_sdev(isUvel) == 1.0d0 ! 3D U-momentum
SO_sdev(isVvel) == 1.0d0 ! 3D V-momentum
SO_sdev(isTvar) == 1.0d0 1.0d0 ! NT tracers
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! Logical switches (TRUE/FALSE) to activate writing of fields into
! HISTORY output file.
Hout(idUvel) == T ! u 3D U-velocity
Hout(idVvel) == T ! v 3D V-velocity
Hout(idu3dE) == F ! u_eastward 3D U-eastward at RHO-points
Hout(idv3dN) == F ! v_northward 3D V-northward at RHO-points
Hout(idWvel) == T ! w 3D W-velocity
Hout(idOvel) == T ! omega omega vertical velocity
Hout(idUbar) == T ! ubar 2D U-velocity
Hout(idVbar) == T ! vbar 2D V-velocity
Hout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Hout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Hout(idFsur) == T ! zeta free-surface
Hout(idBath) == T ! bath time-dependent bathymetry
Hout(idTvar) == T T ! temp, salt temperature and salinity
Hout(idUsms) == F ! sustr surface U-stress
Hout(idVsms) == F ! svstr surface V-stress
Hout(idUbms) == F ! bustr bottom U-stress
Hout(idVbms) == F ! bvstr bottom V-stress
Hout(idUbrs) == F ! bustrc bottom U-current stress
Hout(idVbrs) == F ! bvstrc bottom V-current stress
Hout(idUbws) == F ! bustrw bottom U-wave stress
Hout(idVbws) == F ! bvstrw bottom V-wave stress
Hout(idUbcs) == F ! bustrcwmax bottom max wave-current U-stress
Hout(idVbcs) == F ! bvstrcwmax bottom max wave-current V-stress
Hout(idUbot) == F ! Ubot bed wave orbital U-velocity
Hout(idVbot) == F ! Vbot bed wave orbital V-velocity
Hout(idUbur) == F ! Ur bottom U-velocity above bed
Hout(idVbvr) == F ! Vr bottom V-velocity above bed
Hout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Hout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Hout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Hout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Hout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Hout(idU2Sd) == F ! ubar_stokes 2D U-Stokes velocity
Hout(idV2Sd) == F ! vbar_stokes 2D V-Stokes velocity
Hout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Hout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Hout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Hout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Hout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Hout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Hout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Hout(idU3Sd) == F ! u_stokes 3D U-Stokes velocity
Hout(idV3Sd) == F ! v_stokes 3D V-Stokes velocity
Hout(idWamp) == F ! Hwave wave height
Hout(idWlen) == F ! Lwave wave length
Hout(idWdir) == F ! Dwave wave direction
Hout(idWptp) == F ! Pwave_top wave surface period
Hout(idWpbt) == F ! Pwave_bot wave bottom period
Hout(idWorb) == F ! Ub_swan wave bottom orbital velocity
Hout(idWdis) == F ! Wave_dissip wave dissipation
Hout(idPair) == F ! Pair surface air pressure
Hout(idUair) == F ! Uair surface U-wind component
Hout(idVair) == F ! Vair surface V-wind component
Hout(idTsur) == F F ! shflux, ssflux surface net heat and salt flux
Hout(idLhea) == F ! latent latent heat flux
Hout(idShea) == F ! sensible sensible heat flux
Hout(idLrad) == F ! lwrad longwave radiation flux
Hout(idSrad) == F ! swrad shortwave radiation flux
Hout(idEmPf) == F ! EminusP E-P flux
Hout(idevap) == F ! evaporation evaporation rate
Hout(idrain) == F ! rain precipitation rate
Hout(idDano) == F ! rho density anomaly
Hout(idVvis) == F ! AKv vertical viscosity
Hout(idTdif) == F ! AKt vertical T-diffusion
Hout(idSdif) == F ! AKs vertical Salinity diffusion
Hout(idHsbl) == F ! Hsbl depth of surface boundary layer
Hout(idHbbl) == F ! Hbbl depth of bottom boundary layer
Hout(idMtke) == F ! tke turbulent kinetic energy
Hout(idMtls) == F ! gls turbulent length scale
! Logical switches (TRUE/FALSE) to activate writing of extra inert passive
! tracers other than biological and sediment tracers. An inert passive tracer
! is one that it is only advected and diffused. Other processes are ignored.
! These tracers include, for example, dyes, pollutants, oil spills, etc.
! NPT values are expected. However, these switches can be activated using
! compact parameter specification.
Hout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of exposed sediment
! layer properties into HISTORY output file. Currently, MBOTP properties
! are expected for the bottom boundary layer and/or sediment models:
! idBott( 1=isd50) grain_diameter mean grain diameter
! idBott( 2=idens) grain_density mean grain density
! idBott( 3=iwsed) settling_vel mean settling velocity
! idBott( 4=itauc) erosion_stress critical erosion stress
! idBott( 5=irlen) ripple_length ripple length
! idBott( 6=irhgt) ripple_height ripple height
! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude
! idBott( 8=izdef) Zo_def default bottom roughness
! idBott( 9=izapp) Zo_app apparent bottom roughness
! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness
! idBott(11=izbio) Zo_bio biological bottom roughness
! idBott(12=izbfm) Zo_bedform bed form bottom roughness
! idBott(13=izbld) Zo_bedload bed load bottom roughness
! idBott(14=izwbl) Zo_wbl wave bottom roughness
! idBott(15=iactv) active_layer_thickness active layer thickness
! idBott(16=ishgt) saltation saltation height
! 1 1 1 1 1 1 1
! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
Hout(idBott) == T T T T T T T T T F F F F F F F
! Logical switches (TRUE/FALSE) to activate writing of time-averaged
! fields into AVERAGE output file.
Aout(idUvel) == T ! u 3D U-velocity
Aout(idVvel) == T ! v 3D V-velocity
Aout(idu3dE) == F ! u_eastward 3D U-eastward at RHO-points
Aout(idv3dN) == F ! v_northward 3D V-northward at RHO-points
Aout(idWvel) == T ! w 3D W-velocity
Aout(idOvel) == T ! omega omega vertical velocity
Aout(idUbar) == T ! ubar 2D U-velocity
Aout(idVbar) == T ! vbar 2D V-velocity
Aout(idu2dE) == F ! ubar_eastward 2D U-eastward at RHO-points
Aout(idv2dN) == F ! vbar_northward 2D V-northward at RHO-points
Aout(idFsur) == T ! zeta free-surface
Aout(idTvar) == T T ! temp, salt temperature and salinity
Aout(idUsms) == F ! sustr surface U-stress
Aout(idVsms) == F ! svstr surface V-stress
Aout(idUbms) == F ! bustr bottom U-stress
Aout(idVbms) == F ! bvstr bottom V-stress
Aout(idW2xx) == F ! Sxx_bar 2D radiation stress, Sxx component
Aout(idW2xy) == F ! Sxy_bar 2D radiation stress, Sxy component
Aout(idW2yy) == F ! Syy_bar 2D radiation stress, Syy component
Aout(idU2rs) == F ! Ubar_Rstress 2D radiation U-stress
Aout(idV2rs) == F ! Vbar_Rstress 2D radiation V-stress
Aout(idU2Sd) == F ! ubar_stokes 2D U-Stokes velocity
Aout(idV2Sd) == F ! vbar_stokes 2D V-Stokes velocity
Aout(idW3xx) == F ! Sxx 3D radiation stress, Sxx component
Aout(idW3xy) == F ! Sxy 3D radiation stress, Sxy component
Aout(idW3yy) == F ! Syy 3D radiation stress, Syy component
Aout(idW3zx) == F ! Szx 3D radiation stress, Szx component
Aout(idW3zy) == F ! Szy 3D radiation stress, Szy component
Aout(idU3rs) == F ! u_Rstress 3D U-radiation stress
Aout(idV3rs) == F ! v_Rstress 3D V-radiation stress
Aout(idU3Sd) == F ! u_stokes 3D U-Stokes velocity
Aout(idV3Sd) == F ! v_stokes 3D V-Stokes velocity
Aout(idPair) == F ! Pair surface air pressure
Aout(idUair) == F ! Uair surface U-wind component
Aout(idVair) == F ! Vair surface V-wind component
Aout(idTsur) == F F ! shflux, ssflux surface net heat and salt flux
Aout(idLhea) == F ! latent latent heat flux
Aout(idShea) == F ! sensible sensible heat flux
Aout(idLrad) == F ! lwrad longwave radiation flux
Aout(idSrad) == F ! swrad shortwave radiation flux
Aout(idevap) == F ! evaporation evaporation rate
Aout(idrain) == F ! rain precipitation rate
Aout(idDano) == F ! rho density anomaly
Aout(idVvis) == F ! AKv vertical viscosity
Aout(idTdif) == F ! AKt vertical T-diffusion
Aout(idSdif) == F ! AKs vertical Salinity diffusion
Aout(idHsbl) == F ! Hsbl depth of surface boundary layer
Aout(idHbbl) == F ! Hbbl depth of bottom boundary layer
Aout(id2dRV) == F ! pvorticity_bar 2D relative vorticity
Aout(id3dRV) == F ! pvorticity 3D relative vorticity
Aout(id2dPV) == F ! rvorticity_bar 2D potential vorticity
Aout(id3dPV) == F ! rvorticity 3D potential vorticity
Aout(idu3dD) == F ! u_detided detided 3D U-velocity
Aout(idv3dD) == F ! v_detided detided 3D V-velocity
Aout(idu2dD) == F ! ubar_detided detided 2D U-velocity
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
Aout(idFsuD) == F ! zeta_detided detided free-surface
Aout(idTrcD) == F F ! temp_detided, ... detided temperature and salinity
Aout(idHUav) == F ! Huon u-volume flux, Huon
Aout(idHVav) == F ! Hvom v-volume flux, Hvom
Aout(idUUav) == F ! uu quadratic <u*u> term
Aout(idUVav) == F ! uv quadratic <u*v> term
Aout(idVVav) == F ! vv quadratic <v*v> term
Aout(idU2av) == F ! ubar2 quadratic <ubar*ubar> term
Aout(idV2av) == F ! vbar2 quadratic <vbar*vbar> term
Aout(idZZav) == F ! zeta2 quadratic <zeta*zeta> term
Aout(idTTav) == F F ! temp_2, ... quadratic <t*t> tracer terms
Aout(idUTav) == F F ! u_temp, ... quadratic <u*t> tracer terms
Aout(idVTav) == F F ! v_temp, ... quadratic <v*t> tracer terms
Aout(iHUTav) == F F ! Huon_temp, ... tracer volume flux, <Huon*t>
Aout(iHVTav) == F F ! Hvom_temp, ... tracer volume flux, <Hvom*t>
! tracers other than biological and sediment tracers into the AVERAGE file.
Aout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of time-averaged,
! 2D momentum (ubar,vbar) diagnostic terms into DIAGNOSTIC output file.
Dout(M2rate) == T ! ubar_accel, ... acceleration
Dout(M2pgrd) == T ! ubar_prsgrd, ... pressure gradient
Dout(M2fcor) == T ! ubar_cor, ... Coriolis force
Dout(M2hadv) == T ! ubar_hadv, ... horizontal total advection
Dout(M2xadv) == T ! ubar_xadv, ... horizontal XI-advection
Dout(M2yadv) == T ! ubar_yadv, ... horizontal ETA-advection
Dout(M2hrad) == T ! ubar_hrad, ... horizontal total radiation stress
Dout(M2hvis) == T ! ubar_hvisc, ... horizontal total viscosity
Dout(M2xvis) == T ! ubar_xvisc, ... horizontal XI-viscosity
Dout(M2yvis) == T ! ubar_yvisc, ... horizontal ETA-viscosity
Dout(M2sstr) == T ! ubar_sstr, ... surface stress
Dout(M2bstr) == T ! ubar_bstr, ... bottom stress
! 3D momentum (u,v) diagnostic terms into DIAGNOSTIC output file.
Dout(M3rate) == T ! u_accel, ... acceleration
Dout(M3pgrd) == T ! u_prsgrd, ... pressure gradient
Dout(M3fcor) == T ! u_cor, ... Coriolis force
Dout(M3hadv) == T ! u_hadv, ... horizontal total advection
Dout(M3xadv) == T ! u_xadv, ... horizontal XI-advection
Dout(M3yadv) == T ! u_yadv, ... horizontal ETA-advection
Dout(M3vadv) == T ! u_vadv, ... vertical advection
Dout(M3hrad) == T ! u_hrad, ... horizontal total radiation stress
Dout(M3vrad) == T ! u_vrad, ... vertical radiation stress
Dout(M3hvis) == T ! u_hvisc, ... horizontal total viscosity
Dout(M3xvis) == T ! u_xvisc, ... horizontal XI-viscosity
Dout(M3yvis) == T ! u_yvisc, ... horizontal ETA-viscosity
Dout(M3vvis) == T ! u_vvisc, ... vertical viscosity
! active (temperature and salinity) and passive (inert) tracer diagnostic
! terms into DIAGNOSTIC output file: [1:NAT+NPT,Ngrids].
Dout(iTrate) == T T ! temp_rate, ... time rate of change
Dout(iThadv) == T T ! temp_hadv, ... horizontal total advection
Dout(iTxadv) == T T ! temp_xadv, ... horizontal XI-advection
Dout(iTyadv) == T T ! temp_yadv, ... horizontal ETA-advection
Dout(iTvadv) == T T ! temp_vadv, ... vertical advection
Dout(iThdif) == T T ! temp_hdiff, ... horizontal total diffusion
Dout(iTxdif) == T T ! temp_xdiff, ... horizontal XI-diffusion
Dout(iTydif) == T T ! temp_ydiff, ... horizontal ETA-diffusion
Dout(iTsdif) == T T ! temp_sdiff, ... horizontal S-diffusion
Dout(iTvdif) == T T ! temp_vdiff, ... vertical diffusion
! Generic User parameters, [1:NUSER].
NUSER = 0
USER = 0.d0
! NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
NC_DEFLATE = 1 ! if non-zero, turn on deflate filter
NC_DLEVEL = 1 ! deflate level [0-9]
GRDNAME == roms_cs_grd.nc
ININAME == roms_cs_ini.nc
ITLNAME == ocean_itl.nc
IRPNAME == ocean_irp.nc
IADNAME == ocean_iad.nc
FWDNAME == ocean_fwd.nc
ADSNAME == ocean_ads.nc
! Nesting grids connectivity data: contact points information. This
! NetCDF file is special and complex. It is currently generated using
! the script "matlab/grid/contact.m" from the Matlab repository.
NGCNAME = ocean_ngc.nc
! Input lateral boundary conditions and climatology file names. The
! USER has the option to split input data time records into several
! NetCDF files (see prologue instructions above). If so, use a single
! line per entry with a vertical bar (|) symbol after each entry,
! except the last one.
BRYNAME == roms_cs_bry.nc
CLMNAME == ocean_clm.nc
! Input climatology nudging coefficients file name.
NUDNAME == ocean_nud.nc
! Input Sources/Sinks forcing (like river runoff) file name.
SSFNAME == ocean_rivers.nc
! Input forcing NetCDF file name(s). The USER has the option to enter
! several file names for each nested grid. For example, the USER may
! have different files for wind products, heat fluxes, tides, etc.
! The model will scan the file list and will read the needed data from
! the first file in the list containing the forcing field. Therefore,
! the order of the file names is very important. If using multiple forcing
! files per grid, first enter all the file names for grid 1, then grid 2,
! and so on. It is also possible to split input data time records into
! several NetCDF files (see prologue instructions above). Use a single line
! per entry with a continuation (\) or vertical bar (|) symbol after each
! entry, except the last one.
NFFILES == 1 ! number of unique forcing files
FRCNAME == roms_cs_frc.nc ! forcing file 1, grid 1
! Output NetCDF file names, [1:Ngrids].
GSTNAME == ocean_cs_gst.nc
RSTNAME == ocean_cs_rst.nc
HISNAME == ocean_cs_his.nc
TLMNAME == ocean_cs_tlm.nc
TLFNAME == ocean_cs_tlf.nc
ADJNAME == ocean_cs_adj.nc
AVGNAME == ocean_cs_avg.nc
DIANAME == ocean_cs_dia.nc
STANAME == ocean_cs_sta.nc
FLTNAME == ocean_cs_flt.nc
! Input ASCII parameter filenames.
APARNAM = ROMS/External/s4dvar.in
SPOSNAM = ROMS/External/stations.in
FPOSNAM = ROMS/External/floats.in
BPARNAM = ROMS/External/bio_Fennel.in
SPARNAM = ROMS/External/sediment.in
USRNAME = ROMS/External/MyFile.dat
Parts out the out(.o file)
105120 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
-1 nrrec Number of restart records to read from disk.
F LcycleRST Switch to recycle time-records in restart file.
2880 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
2880 nHIS Number of timesteps between the writing fields
into history file.
105120 ndefHIS Number of timesteps between creation of new
history files.
time-averaged data.
2880 nAVG Number of timesteps between the writing of
105120 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
1 lmd_Jwt Jerlov water type.
2.000 Tcline S-coordinate surface/bottom layer width (m) used
20090101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+02 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
for 3D momentum.
T VolCons(2) NLM southern edge boundary volume conservation.
T VolCons(3) NLM eastern edge boundary volume conservation.
Output Restart File: ocean_cs_rst.nc
Prefix for History Files: ocean_cs_his
Prefix for Averages Files: ocean_cs_avg
Input Grid File: roms_cs_grd.nc
Input Nonlinear Initial File: roms_cs_ini.nc
Input Forcing File 01: roms_cs_frc.nc
Tile partition information for Grid 01: 0119x0191x0005 tiling: 001x004
tile Istr Iend Jstr Jend Npts
0 1 119 1 48 28560
1 1 119 49 96 28560
2 1 119 97 144 28560
3 1 119 145 191 27965
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 119.50 0.50 48.50 RHO-points
1 0.50 119.50 48.50 96.50 RHO-points
2 0.50 119.50 96.50 144.50 RHO-points
3 0.50 119.50 144.50 191.50 RHO-points
0 1.00 119.00 0.50 48.50 U-points
1 1.00 119.00 48.50 96.50 U-points
2 1.00 119.00 96.50 144.50 U-points
3 1.00 119.00 144.50 191.50 U-points
0 0.50 119.50 1.00 48.50 V-points
1 0.50 119.50 48.50 96.50 V-points
2 0.50 119.50 96.50 144.50 V-points
3 0.50 119.50 144.50 191.00 V-points
HaloSizeI(1) = 258
HaloSizeJ(1) = 120
TileSide(1) = 123
TileSize(1) = 6642
zeta 1 Closed Radiation Radiation Closed
ubar 1 Closed Radiation Radiation Closed
vbar 1 Closed Radiation Radiation Closed
u 1 Closed Radiation Radiation Closed
v 1 Closed Radiation Radiation Closed
temp 1 Closed Radiation Radiation Closed
salt 1 Closed Radiation Radiation Closed
tke 1 Closed Radiation Radiation Closed
cs cs
ADD_FSOBC Adding tidal elevation to processed OBC data.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
RST_SINGLE Single precision fields in restart NetCDF file.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 29292) is active.
Node # 1 (pid= 29293) is active.
Node # 2 (pid= 29294) is active.
Node # 3 (pid= 29295) is active.
Vertical S-coordinate System:
5 0.0000000 0.0000000 0.000 0.000 0.000 0.000
4 -0.2000000 -0.0798591 -0.400 -0.400 -80.179 -159.959
3 -0.4000000 -0.2260381 -0.800 -0.800 -226.612 -452.424
2 -0.6000000 -0.4405834 -1.200 -1.200 -441.343 -881.486
1 -0.8000000 -0.6856605 -1.600 -1.600 -686.575 -1371.550
0 -1.0000000 -1.0000000 -2.000 -2.000 -1001.000 -2000.000
Question of reading the bry.nc
Re: Question of reading the bry.nc
Some boundary conditions require external boundary values, some do not. You have chosen those that do not:
ROMS will check to make sure it needs external values before trying to read them.
Thank you,Kate.It works when I change the boundary conditions to Clamped and that it really helps much,thanks again.kate wrote:Some boundary conditions require external boundary values, some do not. You have chosen those that do not:ROMS will check to make sure it needs external values before trying to read them.Code: Select all
LBC(isFsur) == Clo Rad Rad Clo ! free-surface LBC(isUbar) == Clo Rad Rad Clo ! 2D U-momentum LBC(isVbar) == Clo Rad Rad Clo ! 2D V-momentum LBC(isUvel) == Clo Rad Rad Clo ! 3D U-momentum LBC(isVvel) == Clo Rad Rad Clo ! 3D V-momentum
