run error
redhat007
run error
#1 Unread post by redhat007 »
I have run inlet test just for coarse grid and without coupling with swan . As you know all force files provided form analytically files. But in run step i face with error which say:
could not find input file: ocean_frc.nc
 NFFILES == 1                          ! number of forcing files
     FRCNAME == ocean_frc.nc              ! forcing file 1, grid 1
mpirun -np 1 ./coawstM ocean_inlet_test_ref5.in
 Process Information:
 Node #  0 (pid=    4277) is active.
 Model Input Parameters:  ROMS/TOMS version 3.4
                          Wednesday - September 10, 2014 -  5:58:41 PM
 Inlet Test Case
 Operating system : Linux
 CPU/hardware     : i686
 Compiler system  : gfortran
 Compiler command : /usr/lib/mpich2/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
 Input Script  : ocean_inlet_test_ref5.in
 SVN Root URL  :
 SVN Revision  : 791M
 Local Root    : /home/FF/CS_project/COAWST_791
 Header Dir    : /home/FF/CS_project/COAWST_791/CSsea_project/Refine/inlet_refin
 Header file   : inlet_test.h
 Analytical Dir: /home/FF/CS_project/COAWST_791/CSsea_project/Refine/inlet_refin
 Resolution, Grid 01: 0075x0070x008,  Parallel Nodes:   1,  Tiling: 001x001
        720  ntimes          Number of timesteps for 3-D equations.
     60.000  dt              Timestep size (s) for 3-D equations.
         20  ndtfast         Number of timesteps for 2-D equations between
        720  nRST            Number of timesteps between the writing of data
                               into restart fields.
                               to standard output.
         60  nHIS            Number of timesteps between the writing fields
                               into history file.
 1.0000E-03  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 5.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 5.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
      3.000  gls_p           GLS stability exponent.
      1.500  gls_m           GLS turbulent kinetic energy exponent.
     -1.000  gls_n           GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin        GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin        GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0        GLS stability coefficient.
 1.4400E+00  gls_c1          GLS shear production coefficient.
 1.9200E+00  gls_c2          GLS dissipation coefficient.
-4.0000E-01  gls_c3m         GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p         GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk        GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp        GLS constant Schmidt number for PSI.
      0.000  charnok_alpha   Charnok factor for Zos calculation.
      0.000  zos_hsig_alpha  Factor for Zos calculation using Hsig(Awave).
      0.000  sz_alpha        Factor for Wave dissipation surface tke flux .
      0.000  crgban_cw       Factor for Craig/Banner surface tke flux.
 2.5000E-02  rdrg2           Quadratic bottom drag coefficient.
 1.5000E-02  Zob             Bottom roughness (m).
 5.0000E-01  Zos             Surface roughness (m).
          1  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 1.0000E+00  theta_s         S-coordinate surface control parameter.
 1.0000E+00  theta_b         S-coordinate bottom  control parameter.
      0.000  Tcline          S-coordinate surface/bottom layer width (m) used
       0.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
                               for 3D momentum.
     10.000  T0              Background potential temperature (C) constant.
     30.000  S0              Background salinity (PSU) constant.
   1027.000  R0              Background density (kg/m3) used in linear Equation
                               of State.
 1.7000E-04  Tcoef           Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef           Saline contraction coefficient (1/PSU).
          T  Hout(idUbms)    Write out bottom U-momentum stress.
          T  Hout(idVbms)    Write out bottom V-momentum stress.
          T  Hout(idUbrs)    Write out bottom U-current stress.
          T  Hout(idVbrs)    Write out bottom V-current stress.
          T  Hout(idUbws)    Write out wind-induced, bottom U-wave stress.
          T  Hout(idVbws)    Write out wind-induced, bottom V-wave stress.
          T  Hout(idUbcs)    Write out max wind + current, bottom U-wave stress.
          T  Hout(idVbcs)    Write out max wind + current, bottom V-wave stress.
          T  Hout(idUbot)    Write out bed wave orbital U-velocity.
          T  Hout(idVbot)    Write out bed wave orbital V-velocity.
          T  Hout(idUbur)    Write out bottom U-momentum above bed.
          T  Hout(idVbvr)    Write out bottom V-momentum above bed.
          T  Hout(idWpbt)    Write out wave bottom period.
          T  Hout(idWorb)    Write out wave bottom orbital velocity.
          T  Hout(idBott)    Write out bottom property 01: grain_diameter
          T  Hout(idBott)    Write out bottom property 02: grain_density
          T  Hout(idBott)    Write out bottom property 03: settling_vel
          T  Hout(idBott)    Write out bottom property 04: erosion_stress
          T  Hout(idBott)    Write out bottom property 05: ripple_length
          T  Hout(idBott)    Write out bottom property 06: ripple_height
          T  Hout(idBott)    Write out bottom property 07: bed_wave_amp
          T  Hout(idBott)    Write out bottom property 08: Zo_def
          T  Hout(idBott)    Write out bottom property 09: Zo_app
          T  Hout(idBott)    Write out bottom property 10: Zo_Nik
             Output Restart File:  ocean_rst_ref1.nc
             Output History File:  ocean_inlet_his_ref1.nc
                 Input Grid File:  inlet_test_grid.nc
 READ_PHYPAR - could not find input file:  ocean_frc.nc
 Node   #  0 CPU:       0.008
 Total:                 0.008
                                              Total:         0.000    0.0000
 All percentages are with respect to total time =            0.008
 ROMS/TOMS - I/O error ............... exit_flag:   4
 ERROR: I/O related problem.
and when change
NFFILES == 1
to
NFFILES ==
it face with other erro"
unable to find requested variable: Dwave
               in file:
woud you please tell me what is the problem?
Re: run error
if you are running COAWST, please update to the latest version which now uses ROMS v 3.7
Wednesday - September 10, 2014 - 11:03:13 AM
If you are running COAWST and have specific issues with model coupling, please post them to
https://coawstmodel-trac.sourcerepo.com ... el_COAWST/
and login to post a ticket.
In general, the inlet_test is set up to run roms+swan. If you only run roms, then you need to
1) provide the wave data as ana functions
-- or --
2) turn off cpp options that need wave information.
thanks,
john
