could not find input file: ocean_frc.nc
NFFILES == 1 ! number of forcing files
FRCNAME == ocean_frc.nc ! forcing file 1, grid 1
mpirun -np 1 ./coawstM ocean_inlet_test_ref5.in
Process Information:
Node # 0 (pid= 4277) is active.
Model Input Parameters: ROMS/TOMS version 3.4
Wednesday - September 10, 2014 - 5:58:41 PM
Inlet Test Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/lib/mpich2/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script : ocean_inlet_test_ref5.in
SVN Root URL :
SVN Revision : 791M
Local Root : /home/FF/CS_project/COAWST_791
Header Dir : /home/FF/CS_project/COAWST_791/CSsea_project/Refine/inlet_refin
Header file : inlet_test.h
Analytical Dir: /home/FF/CS_project/COAWST_791/CSsea_project/Refine/inlet_refin
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 1, Tiling: 001x001
720 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for turbulent energy.
0.000 charnok_alpha Charnok factor for Zos calculation.
0.000 zos_hsig_alpha Factor for Zos calculation using Hsig(Awave).
0.000 sz_alpha Factor for Wave dissipation surface tke flux .
0.000 crgban_cw Factor for Craig/Banner surface tke flux.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for 3D momentum.
of State.
T Hout(idUbms) Write out bottom U-momentum stress.
T Hout(idVbms) Write out bottom V-momentum stress.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idUbot) Write out bed wave orbital U-velocity.
T Hout(idVbot) Write out bed wave orbital V-velocity.
T Hout(idUbur) Write out bottom U-momentum above bed.
T Hout(idVbvr) Write out bottom V-momentum above bed.
T Hout(idWpbt) Write out wave bottom period.
T Hout(idWorb) Write out wave bottom orbital velocity.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
T Hout(idBott) Write out bottom property 10: Zo_Nik
Output Restart File: ocean_rst_ref1.nc
Output History File: ocean_inlet_his_ref1.nc
Input Grid File: inlet_test_grid.nc
READ_PHYPAR - could not find input file: ocean_frc.nc
Elapsed CPU time (seconds):
Node # 0 CPU: 0.008
Total: 0.008
Total: 0.000 0.0000
All percentages are with respect to total time = 0.008
ROMS/TOMS - I/O error ............... exit_flag: 4
ERROR: I/O related problem.
NFFILES == 1
NFFILES ==
unable to find requested variable: Dwave
in file:
woud you please tell me what is the problem?
