big jump occured when restart
xiaozhu557
#1 Unread post by xiaozhu557 »
I have a trouble with RESTART even I defined PERFECT_RESTART.
For the first run, it ended in 930240 step, the screen output like this
 930238  3229 23:50:00  2.343559E-03  2.323374E+04  2.323374E+04  4.688070E+17
         (0389,498,18)  6.291085E-03  3.352070E-03  1.438732E-01  2.145083E+00
 930239  3229 23:55:00  2.343540E-03  2.323374E+04  2.323374E+04  4.688070E+17
         (0389,498,18)  6.287961E-03  3.355134E-03  1.438942E-01  2.145129E+00
 930240  3230 00:00:00  2.343522E-03  2.323374E+04  2.323374E+04  4.688070E+17
         (0389,498,18)  6.284754E-03  3.358239E-03  1.439150E-01  2.145175E+00
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000070
      WRT_AVG   - wrote averaged fields into time record =             0000035
Terminated
Then the model outputed a restart file in step 930240, I restart the model from that step with the restart file, but got the screen output from the restart run, as follow,
 930240  3230 00:00:00  2.343522E-03  2.323367E+04  2.323368E+04  4.688070E+17
         (0200,050,02)  3.130760E-02  3.470927E-02  0.000000E+00  2.145175E+00
      DEF_HIS   - inquiring history file, Grid 01: np8_his_0009.nc
      DEF_AVG   - inquiring average file, Grid 01: np8_avg_0009.nc
 930241  3230 00:05:00  2.345268E-03  2.323367E+04  2.323368E+04  4.688070E+17
         (0389,498,18)  6.270005E-03  3.394958E-03  1.439145E-01  2.144243E+00
 930242  3230 00:10:00  2.345296E-03  2.323367E+04  2.323368E+04  4.688070E+17
         (0406,495,30)  3.082030E-02  4.629990E-03  4.852346E-01  2.143983E+00
 930243  3230 00:15:00  2.345144E-03  2.323367E+04  2.323368E+04  4.688070E+17
         (0401,494,30)  2.442397E-02  8.826006E-03  4.320690E-01  2.143462E+00
I have got so much differences for the variables Cu, Cv, Cw between the first and restart run in step 930240. I also upload two figures about the variations of the total kinetic Energy (KE) with model time. It included a too big jump after the restart step.
What is the reason for that? How can I fix it?
the variations of the total kinetic Energy in model domain
Re: big jump occured when restart
Did you check to make sure that PERFECT_RESTART was defined in your model output? It was not correct in your post above. Misspellings will cause ROMS to ignore your #define directives.
xiaozhu557
#3 Unread post by xiaozhu557 »
kate wrote:Did you check to make sure that PERFECT_RESTART was defined in your model output? It was not correct in your post above. Misspellings will cause ROMS to ignore your #define directives.
Yes, I have checked that it was defined. I just typed incorrectly in my last post. Sorry about that.
Here is some of my model's screen output,
Warning: no access to tty (Bad file descriptor).
Thus no job control in this shell.
./oceanM
 Model Input Parameters:  ROMS/TOMS version 3.7
                          Sunday - February 9, 2014 -  2:25:57 PM
 North Pacific Model
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /apps/mvapich2/1.8-r5609-intel/bin/mpif90
 Compiler flags   : -heap-arrays -fp-model precise -ip -O3 -free -free -free
 Input Script  :
 SVN Revision  : exported
 Local Root    : /mnt/lfs2/projects/lecpbm/zhuxm/trunk
 Header Dir    : /mnt/lfs2/projects/lecpbm/zhuxm/np8_new
 Header file   : np8.h
 Analytical Dir: /mnt/lfs2/projects/lecpbm/zhuxm/np8_new
 Resolution, Grid 01: 1543x0631x030,  Parallel Nodes: 432,  Tiling: 016x027
   10368000  ntimes          Number of timesteps for 3-D equations.
    300.000  dt              Timestep size (s) for 3-D equations.
         10  ndtfast         Number of timesteps for 2-D equations between
         -1  nrrec           Number of restart records to read from disk.
       2880  nRST            Number of timesteps between the writing of data
                               into restart fields.
                               to standard output.
       1440  nHIS            Number of timesteps between the writing fields
                               into history file.
     103680  ndefHIS         Number of timesteps between creation of new
                               history files.
          1  ntsAVG          Starting timestep for the accumulation of output
                               time-averaged data.
       2880  nAVG            Number of timesteps between the writing of
     103680  ndefAVG         Number of timesteps between creation of new
                               time-averaged file.
 5.0000E+01  nl_tnu4(01)     NLM Horizontal, biharmonic mixing coefficient
                               (m4/s) for tracer 01: temp
 5.0000E+01  nl_tnu4(02)     NLM Horizontal, biharmonic mixing coefficient
                               (m4/s) for tracer 02: salt
 5.0000E+01  nl_visc4        NLM Horizontal, biharmonic mixing coefficient
                               (m4/s) for momentum.
 1.0000E-05  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 1.0000E-05  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 3.0000E-03  rdrg            Linear bottom drag coefficient (m/s).
 1.0000E-03  Zob             Bottom roughness (m).
          1  lmd_Jwt         Jerlov water type.
          2  Vtransform      S-coordinate transformation equation.
          4  Vstretching     S-coordinate stretching function.
 5.0000E+00  theta_s         S-coordinate surface control parameter.
 3.0000E-01  theta_b         S-coordinate bottom  control parameter.
     30.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1000.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
19900101.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 3.6000E+02  Tnudg(01)       Nudging/relaxation time scale (days)
 3.6000E+02  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 3.6000E+02  Znudg           Nudging/relaxation time scale (days)
 3.6000E+02  M2nudg          Nudging/relaxation time scale (days)
 3.6000E+02  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 1.2000E+02  obcfac          Factor between passive and active
          T  VolCons(1)      NLM western  edge boundary volume conservation.
          T  VolCons(2)      NLM southern edge boundary volume conservation.
          F  VolCons(3)      NLM eastern  edge boundary volume conservation.
          T  VolCons(4)      NLM northern edge boundary volume conservation.
     10.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
          T  LuvSrc          Turning ON  momentum point Sources/Sinks.
          T  LwSrc           Turning ON  volume influx point Sources/Sinks.
          T  LtracerSrc(01)  Turning ON  point Sources/Sinks on tracer 01: temp
          T  LtracerSrc(02)  Turning ON  point Sources/Sinks on tracer 02: salt
          T  Hout(idDano)    Write out density anomaly.
          T  Hout(idVvis)    Write out vertical viscosity: AKv.
          T  Hout(idTdif)    Write out vertical diffusion: AKt(itemp).
          T  Hout(idSdif)    Write out vertical diffusion: AKt(isalt).
          T  Hout(idHsbl)    Write out depth of surface boundary layer.
          T  Aout(idFsur)    Write out averaged free-surface.
          T  Aout(idUbar)    Write out averaged 2D U-momentum component.
          T  Aout(idVbar)    Write out averaged 2D V-momentum component.
          T  Aout(idu2dE)    Write out averaged 2D U-eastward  at RHO-points.
          T  Aout(idv2dN)    Write out averaged 2D V-northward at RHO-points.
          T  Aout(idUvel)    Write out averaged 3D U-momentum component.
          T  Aout(idVvel)    Write out averaged 3D V-momentum component.
          T  Aout(idWvel)    Write out averaged W-momentum component.
          T  Aout(idTvar)    Write out averaged tracer 01: temp
          T  Aout(idTvar)    Write out averaged tracer 02: salt
          T  Aout(idDano)    Write out averaged density anomaly.
          T  Aout(idVvis)    Write out averaged vertical viscosity: AKv.
          T  Aout(idTdif)    Write out averaged vertical diffusion: AKt(itemp).
          T  Aout(idSdif)    Write out averaged vertical diffusion: AKt(isalt).
          T  Aout(idHsbl)    Write out averaged depth of surface boundary layer.
             Output Restart File:  np8_rst.nc
        Prefix for History Files:  np8_his
       Prefix for Averages Files:  np8_avg
                 Input Grid File:  np8_grd.nc
    Input Nonlinear Initial File:  np8_rst.nc
        Input Sources/Sinks File:  np8_river_clm.nc
           Input Forcing File 01:  np8_frc.nc
             Input Boundary File:  np8_bry.nc
 Tile partition information for Grid 01:  1543x0631x0030  tiling: 016x027
   (interior points only)
 RHO-points
   U-points
   V-points
               HaloSizeI(1) =     333
               HaloSizeJ(1) =     114
                TileSide(1) =     105
                TileSize(1) =    3360
 zeta                     1   Chapman Imp  Chapman Imp  Closed       Chapman Imp
 ubar                     1   Flather      Flather      Closed       Flather
 vbar                     1   Flather      Flather      Closed       Flather
 u                        1   Rad + Nud    Rad + Nud    Closed       Rad + Nud
 v                        1   Rad + Nud    Rad + Nud    Closed       Rad + Nud
 temp                     1   Rad + Nud    Rad + Nud    Closed       Rad + Nud
 salt                     1   Rad + Nud    Rad + Nud    Closed       Rad + Nud
 NP                  North Pacific Model
 DIFF_3DCOEF         Horizontal, time-dependent 3D diffusion coefficient.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 DIURNAL_SRFLUX      Modulate shortwave radiation by the local diurnal cycle.
 INLINE_2DIO         Processing 3D IO level by level to reduce memory needs.
 LMD_CONVEC          LMD convective mixing due to shear instability.
 LMD_MIXING          Large/McWilliams/Doney interior mixing.
 LMD_NONLOCAL        LMD convective nonlocal transport.
 LMD_RIMIX           LMD diffusivity due to shear instability.
 LMD_SKPP            KPP surface boundary layer mixing.
 M2CLM_NUDGING       Nudging toward 2D momentum climatology.
 M3CLM_NUDGING       Nudging toward 3D momentum climatology.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 NO_WRITE_GRID       Not Writing grid arrays into NetCDF ouput files.
 PERFECT_RESTART     Processing perfect restart variables.
 SCORRECTION         Surface salinity flux correction.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SPONGE              Enhanced horizontal mixing in the sponge areas.
 TCLM_NUDGING        Nudging toward tracer climatology.
 TS_DIF4             Biharmonic mixing of tracers.
 TS_SMAGORINSKY      Smagorinksy-like time-dependent diffusion coefficients.
 UV_VIS4             Biharmonic mixing of momentum.
 UV_SMAGORINSKY      Smagorinksy-like time-dependent viscosity coefficients.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
 VISC_3DCOEF         Horizontal, time-dependent 3D viscosity coefficient.
 CHECKADJ - use caution when activating: TS_SMAGORINSKY
            REASON: stability problems, WARNING.
 CHECKADJ - use caution when activating: UV_SMAGORINSKY
 Process Information:
xiaozhu557
#4 Unread post by xiaozhu557 »
Hi Kate or anybody,
Can you give me any clue for this problem? I really need your help.
Thanks.
#5 Unread post by kate »
I would check to make sure that PERFECT_RESTART really is giving a perfect restart for the options you have chosen. I see you are getting a warning about the little-used SMAGORINSKY options. Perhaps PERFECT_RESTART doesn't work with them.
In other words:
* Check to see if PERFECT_RESTART behaves as advertised by running some short tests.
* If not, fix it.
* Check your energetics again.
I should add that step two can be accomplished by running two debugger sessions, one in a restart case, one in a case run from the beginning. Or perhaps print statements of the fields in question if you get lucky in guessing what they are, perhaps after seeing what differs in step one.
xiaozhu557
#6 Unread post by xiaozhu557 »
kate wrote:I would check to make sure that PERFECT_RESTART really is giving a perfect restart for the options you have chosen. I see you are getting a warning about the little-used SMAGORINSKY options. Perhaps PERFECT_RESTART doesn't work with them.
In other words:
* If not, fix it.
Thank you for your reply. I have used the same defined options to restart the model many times, I have run my model for 10 years, 1 year each time, but it works fine in sometime, sometime not. Do you mean that PERFECT_RESTART may not work if I define the SMAGORINSKY options with it together? Are you sure this?
By the way, I have used the same forcing files for each running.
#7 Unread post by kate »
I can be sure of nothing without trying it. PERFECT_RESTART can be checked by starting from a known state and running for a day, restarting and running for a second day. Then, start from the same known state and run for two days. Compare results. They should match perfectly.
osua72
#8 Unread post by osua72 »
I am running into a similar problem, I'm trying to run a model for a year, outputting both hourly data and daily averages. Because of the time-limit on the super computer I need to restart the model every three days which I do using NRREC == -1. I'm running with PERFECT_RESTART defined and the results in my history file seem fine, however in the averages files I get a spike when the model is restarted and was wondering whether anybody could shed a light on why this might be:
IS Irish Sea
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
BULK_FLUXES Surface bulk fluxes parameterization.
EMINUSP Compute Salt Flux using E-P.
LONGWAVE Compute net longwave radiation internally.
MASKING Land/Sea masking.
MIX_ISO_TS Mixing of tracers along isopycnal surfaces.
NONLINEAR Nonlinear Model.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SPHERICAL Spherical grid configuration.
STATIONS Writing out station data.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
