CG_DELTA not positive
jsaynisch
#1 Unread post by jsaynisch »
I use IS4DVAR with the following configuration:
ADJOINT             Adjoint Model.
 BACKGROUND          Include background cost function.
 BALANCE_OPERATOR    Error Covariance Multivariate Balance Operator.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 FORWARD_MIXING      Read in Forward vertical mixing for Tangent/Adjoint.
 FORWARD_READ        Read in Forward solution for Tangent/Adjoint.
 FORWARD_WRITE       Write out Forward solution for Tangent/Adjoint.
 !FULL_GRID          Considering observations at interior points only.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 IMPLICIT_VCONV      Implicit Vertical Convolution Algorithm.
 IS4DVAR             Incremental strong constraint 4D-Var data assimilation.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 OBSERVATIONS        Processing 4DVar observations.
 OUT_DOUBLE          Double precision output fields in NetCDF files.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 SPHERICAL           Spherical grid configuration.
 TANGENT             Tangent Linear Model.
 TS_U3HADVECTION_TL  TL/AD third-order upstream horizontal tracer advection.
 TS_C4VADVECTION_TL  TL/AD fourth-order centered vertical tracer advection.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
 VCONVOLUTION        Include vertical correlations in convolutions.
 ZETA_ELLIPTIC       Solving SSH elliptic equation in balance operator.
I use artificial SSH observations and get (I guess) reasonable results from the NLM, TLM and the adjoint model.
Nonetheless, I get the following error message:
 TLM: GET_STATE - Read v-space increments,                   t =  2193 00:00:00
                   (Grid 01, File: ocean_itl.nc, Rec=0001, Index=1)
                - free-surface
                   (Min = -2.81705926E-02 Max =  2.77907880E-02)
                - u-momentum component
                   (Min = -3.50023965E-02 Max =  3.09755988E-02)
                - v-momentum component
                   (Min = -5.58496923E-02 Max =  3.39090215E-02)
                - potential temperature
                   (Min = -3.78477034E-01 Max =  2.17940332E-01)
                - salinity
                   (Min = -2.35268280E-02 Max =  5.59604732E-02)
                   (Grid 01, File: ocean_itl.nc, Rec=0001, Index=2)
                - free-surface
                - salinity
 ADM: GET_STATE - Read latest adjoint state solution,        t =  2193 00:00:00
                   (Grid 01, File: za_adj_001.nc, Rec=0001, Index=2)
                - free-surface
                   (Min = -2.84382716E-05 Max =  6.53508152E-04)
                   (Min = -1.25437686E+03 Max =  1.43251412E+03)
                   (Min = -1.99218268E+03 Max =  1.40747070E+03)
                   (Min = -1.29402765E-02 Max =  1.46191528E-02)
                   (Min = -2.47037059E-02 Max =  1.81783417E-02)
                   (Min = -6.74280091E-02 Max =  5.43788692E-02)
                - salinity
                   (Min = -8.36367447E-03 Max =  7.47036749E-03)
 NLM: GET_STATE - Read previous state initial conditions,    t =  2193 00:00:00
                   (Grid 01, File: za_ini.nc, Rec=0002, Index=2)
                - free-surface
                   (Min = -1.67400898E+00 Max =  1.64807835E+00)
                   (Min = -1.49075648E+00 Max =  6.44656120E-01)
                   (Min = -1.52064299E+00 Max =  8.20836836E-01)
                   (Min = -2.87649882E+00 Max =  2.72146996E+00)
                   (Min = -3.23322773E+00 Max =  2.28254094E+00)
                   (Min = -5.35978216E+00 Max =  2.92327918E+01)
                - salinity
                   (Min =  3.28323630E+01 Max =  3.68394618E+01)
                - vertical viscosity coefficient
                   (Min =  0.00000000E+00 Max =  9.10820383E+01)
                - temperature vertical diffusion coefficient
                   (Min =  0.00000000E+00 Max =  1.23642693E+02)
                - salinity vertical diffusion coefficient
 ADM: GET_STATE - Read previous adjoint state solution,      t =  2193 00:00:00
                   (Grid 01, File: za_adj_001.nc, Rec=0001, Index=1)
                - free-surface
                - salinity
 <<<< Descent Algorithm >>>>
  CG_DELTA not positive.
  CG_DELTA =  -2959.10090971697127 , outer =  1 , inner =  1
As I understand it this means that some of the Hessian is negative determined? In the code it is calculated as some kind of dot product... I see that the respective entries for AMD and TLM do not differ and I guess they should?
What can I do about it? Is this just due to to the artificial nature of my observations or a mistake in the model configuration or maybe a problem of I/O file handling...
Alas, I have two more (related) questions:
Is the value of obs_provenance of any relevance? I could not find that it is used somewhere in the code.
On what time basis are the modeled values and the observations compared? Is it just model snapshots versus the observations or can I specify a time averaging window for the model values?
I hope you can help me here.
wangzc
Location: National Marine Environmental Forecasting Center
Re: CG_DELTA not positive
#2 Unread post by wangzc »
hey!
Last time I came up this situation is "NRREC=-1". After making ini.nc, it's ok!
jsaynisch
#3 Unread post by jsaynisch »
AWESOME, this did the trick!
Thank you, wangzc - it would have taken me quite a while before I would have thought of NRREC! (If at all!)
So thanks gain!
Jan
