ADJOINT Adjoint Model.
BACKGROUND Include background cost function.
BALANCE_OPERATOR Error Covariance Multivariate Balance Operator.
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
FORWARD_MIXING Read in Forward vertical mixing for Tangent/Adjoint.
FORWARD_READ Read in Forward solution for Tangent/Adjoint.
FORWARD_WRITE Write out Forward solution for Tangent/Adjoint.
!FULL_GRID Considering observations at interior points only.
IMPLICIT_VCONV Implicit Vertical Convolution Algorithm.
IS4DVAR Incremental strong constraint 4D-Var data assimilation.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
OBSERVATIONS Processing 4DVar observations.
OUT_DOUBLE Double precision output fields in NetCDF files.
SALINITY Using salinity.
SPHERICAL Spherical grid configuration.
TANGENT Tangent Linear Model.
TS_U3HADVECTION_TL TL/AD third-order upstream horizontal tracer advection.
TS_C4VADVECTION_TL TL/AD fourth-order centered vertical tracer advection.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
VCONVOLUTION Include vertical correlations in convolutions.
ZETA_ELLIPTIC Solving SSH elliptic equation in balance operator.
Nonetheless, I get the following error message:
TLM: GET_STATE - Read v-space increments, t = 2193 00:00:00
(Grid 01, File: ocean_itl.nc, Rec=0001, Index=1)
- free-surface
(Min = -2.81705926E-02 Max = 2.77907880E-02)
- u-momentum component
(Min = -3.50023965E-02 Max = 3.09755988E-02)
- v-momentum component
(Min = -5.58496923E-02 Max = 3.39090215E-02)
- potential temperature
(Min = -3.78477034E-01 Max = 2.17940332E-01)
- salinity
(Min = -2.35268280E-02 Max = 5.59604732E-02)
(Grid 01, File: ocean_itl.nc, Rec=0001, Index=2)
- free-surface
- salinity
ADM: GET_STATE - Read latest adjoint state solution, t = 2193 00:00:00
(Grid 01, File: za_adj_001.nc, Rec=0001, Index=2)
- free-surface
(Min = -2.84382716E-05 Max = 6.53508152E-04)
(Min = -1.25437686E+03 Max = 1.43251412E+03)
(Min = -1.99218268E+03 Max = 1.40747070E+03)
(Min = -1.29402765E-02 Max = 1.46191528E-02)
(Min = -2.47037059E-02 Max = 1.81783417E-02)
(Min = -6.74280091E-02 Max = 5.43788692E-02)
- salinity
(Min = -8.36367447E-03 Max = 7.47036749E-03)
NLM: GET_STATE - Read previous state initial conditions, t = 2193 00:00:00
(Grid 01, File: za_ini.nc, Rec=0002, Index=2)
- free-surface
(Min = -1.67400898E+00 Max = 1.64807835E+00)
(Min = -1.49075648E+00 Max = 6.44656120E-01)
(Min = -1.52064299E+00 Max = 8.20836836E-01)
(Min = -2.87649882E+00 Max = 2.72146996E+00)
(Min = -3.23322773E+00 Max = 2.28254094E+00)
(Min = -5.35978216E+00 Max = 2.92327918E+01)
- salinity
(Min = 3.28323630E+01 Max = 3.68394618E+01)
- vertical viscosity coefficient
(Min = 0.00000000E+00 Max = 9.10820383E+01)
- temperature vertical diffusion coefficient
(Min = 0.00000000E+00 Max = 1.23642693E+02)
- salinity vertical diffusion coefficient
ADM: GET_STATE - Read previous adjoint state solution, t = 2193 00:00:00
(Grid 01, File: za_adj_001.nc, Rec=0001, Index=1)
- free-surface
- salinity
<<<< Descent Algorithm >>>>
CG_DELTA not positive.
CG_DELTA = -2959.10090971697127 , outer = 1 , inner = 1
What can I do about it? Is this just due to to the artificial nature of my observations or a mistake in the model configuration or maybe a problem of I/O file handling...
Alas, I have two more (related) questions:
Is the value of obs_provenance of any relevance? I could not find that it is used somewhere in the code.
On what time basis are the modeled values and the observations compared? Is it just model snapshots versus the observations or can I specify a time averaging window for the model values?
I hope you can help me here.
