Resolution, Grid 01: 0302x0145x030, Parallel Nodes: 16, Tiling: 004x004
4000 ntimes Number of timesteps for 3-D equations.
100.000 dt Timestep size (s) for 3-D equations.
into restart fields.
to standard output.
9 nSTA Number of timesteps between the writing of data
the stations file.
9 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
9 nAVG Number of timesteps between the writing of
9 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
for tracer 02: salt
for 3D momentum.
of State.
Output Restart File: /home/austinj/gloegel/roms-models/model-001/Output/model-001_rst.nc
Output History File: /home/austinj/gloegel/roms-models/model-001/Output/model-001_his.nc
Output Averages File: /home/austinj/gloegel/roms-models/model-001/Output/model-001_avg.nc
Output Diagnostics File: /home/austinj/gloegel/roms-models/model-001/Output/model-001_dia.nc
Output Stations File: /home/austinj/gloegel/roms-models/model-001/Output/model-001_sta.nc
Input Grid File: /home/austinj/gloegel/roms-grids/LS_grid_2km.nc
Station positions File: /home/austinj/gloegel/roms-models/model-001/run-files/stations.in
Tile partition information for Grid 01: 0302x0145x0030 tiling: 004x004
tile Istr Iend Jstr Jend Npts
0 1 75 1 36 81000
1 76 151 1 36 82080
2 152 227 1 36 82080
3 228 302 1 36 81000
4 1 75 37 73 83250
5 76 151 37 73 84360
6 152 227 37 73 84360
7 228 302 37 73 83250
8 1 75 74 110 83250
9 76 151 74 110 84360
10 152 227 74 110 84360
11 228 302 74 110 83250
12 1 75 111 145 78750
13 76 151 111 145 79800
14 152 227 111 145 79800
15 228 302 111 145 78750
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 75.50 0.50 36.50 RHO-points
1 75.50 151.50 0.50 36.50 RHO-points
2 151.50 227.50 0.50 36.50 RHO-points
3 227.50 302.50 0.50 36.50 RHO-points
4 0.50 75.50 36.50 73.50 RHO-points
5 75.50 151.50 36.50 73.50 RHO-points
6 151.50 227.50 36.50 73.50 RHO-points
7 227.50 302.50 36.50 73.50 RHO-points
8 0.50 75.50 73.50 110.50 RHO-points
9 75.50 151.50 73.50 110.50 RHO-points
10 151.50 227.50 73.50 110.50 RHO-points
11 227.50 302.50 73.50 110.50 RHO-points
12 0.50 75.50 110.50 145.50 RHO-points
13 75.50 151.50 110.50 145.50 RHO-points
14 151.50 227.50 110.50 145.50 RHO-points
15 227.50 302.50 110.50 145.50 RHO-points
0 1.00 75.50 0.50 36.50 U-points
1 75.50 151.50 0.50 36.50 U-points
2 151.50 227.50 0.50 36.50 U-points
3 227.50 302.00 0.50 36.50 U-points
4 1.00 75.50 36.50 73.50 U-points
5 75.50 151.50 36.50 73.50 U-points
6 151.50 227.50 36.50 73.50 U-points
7 227.50 302.00 36.50 73.50 U-points
8 1.00 75.50 73.50 110.50 U-points
9 75.50 151.50 73.50 110.50 U-points
10 151.50 227.50 73.50 110.50 U-points
11 227.50 302.00 73.50 110.50 U-points
12 1.00 75.50 110.50 145.50 U-points
13 75.50 151.50 110.50 145.50 U-points
14 151.50 227.50 110.50 145.50 U-points
15 227.50 302.00 110.50 145.50 U-points
0 0.50 75.50 1.00 36.50 V-points
1 75.50 151.50 1.00 36.50 V-points
2 151.50 227.50 1.00 36.50 V-points
3 227.50 302.50 1.00 36.50 V-points
4 0.50 75.50 36.50 73.50 V-points
5 75.50 151.50 36.50 73.50 V-points
6 151.50 227.50 36.50 73.50 V-points
7 227.50 302.50 36.50 73.50 V-points
8 0.50 75.50 73.50 110.50 V-points
9 75.50 151.50 73.50 110.50 V-points
10 151.50 227.50 73.50 110.50 V-points
11 227.50 302.50 73.50 110.50 V-points
12 0.50 75.50 110.50 145.00 V-points
13 75.50 151.50 110.50 145.00 V-points
14 151.50 227.50 110.50 145.00 V-points
15 227.50 302.50 110.50 145.00 V-points
HaloSizeI(1) = 264
HaloSizeJ(1) = 147
TileSide(1) = 82
TileSize(1) = 3526
Stations Parameters, Grid: 01
3 Nstation Number of stations to write out into stations file.
T Sout(idTvar) Write out tracer 01: temp
T Sout(idUsms) Write out surface U-momentum stress.
T Sout(idVsms) Write out surface V-momentum stress.
Flag and positions for station 0001: 0 80.0000 40.0000
Flag and positions for station 0002: 0 80.0000 30.0000
Flag and positions for station 0003: 0 80.0000 20.0000
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
tke 1 Periodic Closed Periodic Closed
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
STATIONS Writing out station data.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 1871) is active.
Node # 3 (pid= 1874) is active.
Node # 5 (pid= 1876) is active.
Node # 1 (pid= 1872) is active.
Node # 2 (pid= 1873) is active.
Node # 4 (pid= 1875) is active.
Node # 6 (pid= 1877) is active.
Node # 7 (pid= 1878) is active.
Node # 8 (pid= 16684) is active.
Node # 9 (pid= 16685) is active.
Node # 10 (pid= 16686) is active.
Node # 11 (pid= 16687) is active.
Node # 12 (pid= 16688) is active.
Node # 13 (pid= 16689) is active.
Node # 14 (pid= 16690) is active.
Node # 15 (pid= 16691) is active.
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
reading f
Vertical S-coordinate System:
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0005519 -0.032 -0.424 -0.840 -0.993
28 -0.0666667 -0.0022130 -0.064 -0.861 -1.879 -2.407
27 -0.1000000 -0.0050000 -0.096 -1.313 -3.120 -4.246
26 -0.1333333 -0.0089408 -0.129 -1.778 -4.568 -6.522
25 -0.1666667 -0.0140748 -0.161 -2.259 -6.230 -9.250
24 -0.2000000 -0.0204535 -0.193 -2.756 -8.115 -12.448
23 -0.2333333 -0.0281406 -0.225 -3.268 -10.234 -16.142
22 -0.2666667 -0.0372130 -0.258 -3.798 -12.602 -20.360
21 -0.3000000 -0.0477616 -0.290 -4.347 -15.234 -25.137
20 -0.3333333 -0.0598920 -0.323 -4.915 -18.150 -30.512
19 -0.3666667 -0.0737256 -0.355 -5.505 -21.371 -36.532
18 -0.4000000 -0.0894007 -0.388 -6.118 -24.922 -43.249
17 -0.4333333 -0.1070744 -0.421 -6.755 -28.832 -50.723
16 -0.4666667 -0.1269234 -0.454 -7.420 -33.131 -59.020
15 -0.5000000 -0.1491465 -0.487 -8.114 -37.856 -68.215
14 -0.5333333 -0.1739660 -0.520 -8.841 -43.047 -78.392
13 -0.5666667 -0.2016303 -0.553 -9.604 -48.747 -89.647
12 -0.6000000 -0.2324164 -0.586 -10.405 -55.007 -102.083
11 -0.6333333 -0.2666323 -0.619 -11.250 -61.882 -115.817
10 -0.6666667 -0.3046205 -0.653 -12.141 -69.433 -130.979
9 -0.7000000 -0.3467612 -0.686 -13.085 -77.729 -147.712
8 -0.7333333 -0.3934761 -0.720 -14.085 -86.844 -166.176
7 -0.7666667 -0.4452328 -0.754 -15.149 -96.863 -186.549
6 -0.8000000 -0.5025493 -0.789 -16.282 -107.879 -209.026
5 -0.8333333 -0.5659992 -0.823 -17.492 -119.995 -233.824
4 -0.8666667 -0.6362176 -0.858 -18.786 -133.323 -261.183
3 -0.9000000 -0.7139071 -0.893 -20.174 -147.991 -291.371
2 -0.9333333 -0.7998455 -0.928 -21.665 -164.138 -324.680
1 -0.9666667 -0.8948927 -0.964 -23.269 -181.917 -361.436
0 -1.0000000 -1.0000000 -1.000 -25.000 -201.500 -402.000
Time Splitting Weights: ndtfast = 30 nfast = 42
37 0.0473537721847153 0.0063819206892258 0.8558961515079423 0.9882658063583315
42 0.0109897377911118 0.0003663245930371 1.0000000000000004 0.9999999999999999
Minimum X-grid spacing, DXmin = 2.00000000E+00 km
Maximum X-grid spacing, DXmax = 2.00000000E+00 km
Minimum Y-grid spacing, DYmin = 2.00000000E+00 km
Maximum Y-grid spacing, DYmax = 2.00000000E+00 km
Minimum Z-grid spacing, DZmin = 3.20725078E-02 m
Maximum Z-grid spacing, DZmax = 4.05638507E+01 m
Minimum barotropic Courant Number = 7.38241153E-03
Maximum barotropic Courant Number = 1.48016891E-01
Maximum Coriolis Courant Number = 1.10000000E-02
Maximum grid stiffness ratios: rx0 = 9.682540E-01 (Beckmann and Haidvogel)
rx1 = 2.974274E+01 (Haney)
Initial basin volumes: TotVolume = 1.1818404000E+13 m3
MinVolume = 1.2829003124E+05 m3
MaxVolume = 1.6225540264E+08 m3
Max/Min = 1.2647545649E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00004000)
0 0 00:00:00 0.000000E+00 8.702628E+02 8.702628E+02 1.228302E+13
DEF_HIS - creating history file: /home/austinj/gloegel/roms-models/model-001/Output/model-001_his.nc
DEF_AVG - creating average file: /home/austinj/gloegel/roms-models/model-001/Output/model-001_avg.nc
DEF_DIAGS - creating diagnostics file: /home/austinj/gloegel/roms-models/model-001/Output/model-001_dia.nc
DEF_STATION - creating stations file: /home/austinj/gloegel/roms-models/model-001/Output/model-001_sta.nc
1 0 00:01:40 2.294946E-04 8.702606E+02 8.702608E+02 1.228258E+13
(113,086,01) 2.467573E-02 2.539287E-02 0.000000E+00 1.135981E+00
2 0 00:03:20 7.700370E-04 8.702543E+02 8.702551E+02 1.228156E+13
(111,096,01) 3.220059E-02 4.033535E-02 4.664799E+01 2.059685E+00
3 0 00:05:00 1.530783E-03 8.702329E+02 8.702345E+02 1.228025E+13
(111,096,01) 5.648131E-02 6.783622E-02 8.453411E+01 2.789785E+00
4 0 00:06:40 2.470958E-03 8.701939E+02 8.701964E+02 1.227881E+13
(111,096,01) 8.368497E-02 9.658389E-02 1.121651E+02 3.431938E+00
5 0 00:08:20 3.557556E-03 8.701424E+02 8.701460E+02 1.227733E+13
(111,096,01) 1.083242E-01 1.223930E-01 1.316511E+02 3.963897E+00
6 0 00:10:00 4.755493E-03 8.700833E+02 8.700880E+02 1.227585E+13
(111,096,01) 1.285067E-01 1.426415E-01 1.431047E+02 4.765708E+00
7 0 00:11:40 6.035806E-03 8.700189E+02 8.700249E+02 1.227440E+13
(111,096,01) 1.460593E-01 1.607027E-01 1.469665E+02 6.306291E+00
8 0 00:13:20 7.936571E-03 8.699506E+02 8.699586E+02 1.227296E+13
(111,096,01) 1.602873E-01 1.783562E-01 1.490090E+02 2.462400E+01
Node # 6 CPU: 15.849
Node # 5 CPU: 16.202
Node # 1 CPU: 17.056
Node # 7 CPU: 16.050
Node # 2 CPU: 17.246
Node # 3 CPU: 17.195
Node # 4 CPU: 16.399
WRT_RST - wrote re-start fields (Index=1,1) into time record = 0000001
Node # 0 CPU: 15.668
Node # 14 CPU: 16.701
Node # 15 CPU: 16.095
Node # 9 CPU: 16.065
Node # 8 CPU: 15.173
Node # 11 CPU: 16.406
Node # 12 CPU: 17.201
Node # 13 CPU: 17.160
Node # 10 CPU: 15.873
number of time records written in STATION file = 00000001
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/TOMS: DONE... Saturday - June 29, 2013 - 8:24:44 PM
