MCT error Inlet test case on a Mac
Hey all,
I'm having troubles compiling the inlet test case.
It might have something to do with how I compiled MCT?!
I'm running ROMS on a Mac (Mountain Lion).
I compiled MCT using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/opt/local/include LDFLAGS=-L/opt/local/lib --prefix=/opt/local --enable-mpiserial
The MCT example cases can be made so it seems like it's all good there.
I compiled my openmpi using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
When I run the build.bash for the inlet case I get the following error:
USE m_MCTWorld, ONLY : MCTWorld_init => init
1
Fatal Error: Can't open module file 'm_mctworld.mod' for reading at (1): No such file or directory
make: *** [/Users/Hawky/ROMS/Projects/test2//Build/ocean_coupler.o] Error 1
I changed the Darwin-gfortran.mk compiler (saw that in another post) to include the directories of the MCT into
ifdef USE_MCT
MCT_INCDIR ?= /opt/local/include
MCT_LIBDIR ?= /opt/local/lib
FFLAGS += -I$(MCT_INCDIR)
LIBS += -L$(MCT_LIBDIR) -lmct -lmpeu
endif
and now I get the following error:
USE distribute_mod, ONLY : mp_reduce
1
Error: Symbol 'mp_reduce' referenced at (1) not found in module 'distribute_mod'
ocean_coupler.f90:362.57:
Asize=GlobalSegMap_lsize (GSMapROMS, OCN_COMM_WORLD)
1
Error: Symbol 'ocn_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:160.49:
CALL MCTWorld_init (Nmodels, MPI_COMM_WORLD, OCN_COMM_WORLD, &
1
Error: Symbol 'mpi_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:155.40:
CALL mpi_comm_rank (OCN_COMM_WORLD, MyRank, MyError)
1
Any ideas what I did wrong or where the issue might be?
Cheers!
Moritz
1
ifdef USE_MCT
endif
1
1
1
1
Cheers!
Moritz
Re: MCT error Inlet test case on a Mac
"USE m_MCTWorld, ONLY : MCTWorld_init => init
1
make: *** [/Users/Hawky/ROMS/Projects/test2//Build/ocean_coupler.o] Error 1"
I have seen this before. it sounds like issues related to the "make install" portion for MCT. make sure the *.mod files and *.libs for mct have been copied to your
usr/local/include and usr/local/lib (or other apporpriate dirs) and that those dirs are in your path.
1
Thanks for the answer, as I said before, it was a path error but after setting the paths correctly it still leaves me with this error message:
1
1
1
1
Could be that I made a mistake in installing OpenMPI?
Thanks for any suggestions.
1
1
1
1
"Error: Symbol 'ocn_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:160.49:"
did you define to use MPI in the bash file?
Of course thanks!
I had
USE_OpenMP=on
instead of
USE_MPI=on
USE_MPIF90=on
I guess I got confused with the open MPI. I can compile it now, however I can't run the model.
To run it I type
mpirun -np 4 oceanM ocean_inlet_test.in
and get
Coupled Input File name = ocean_inlet_test.in
MOD_COUPLER - Unable to open variable information file:
Default file is located in source directory.
mpirun has exited due to process rank 1 with PID 15625 on
node Moritzs-MacBook-Pro.local exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Any ideas?
Moritz
I had
USE_OpenMP=on
instead of
USE_MPI=on
USE_MPIF90=on
To run it I type
and get
Any ideas?
Moritz
you need to point to the coupling_inlet_test.in, not the ocean.in
Thanks for the help.
I now get the following error:
Node # 0 (pid= 847) is active.
Node # 1 (pid= 848) is active.
[Moritzs-MacBook-Pro.local:848] *** An error occurred in MPI_Gather
[Moritzs-MacBook-Pro.local:848] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
[Moritzs-MacBook-Pro.local:848] *** MPI_ERR_TYPE: invalid datatype
[Moritzs-MacBook-Pro.local:848] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 1 with PID 848 on
[Moritzs-MacBook-Pro.local:00845] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[Moritzs-MacBook-Pro.local:00845] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Any idea what I'm doing wrong?
you need to make sure that you launch the job with the same number of procs that are being used. so if you use
mpirun -np 4
then in the coupling.in file you need to assign 4 procs, lets say 2 to roms and 2 to swan. Then you need to make sure the roms ocean.in file has ntileI and ntileJ to be set for 2 procs. you do not need to set anything in the swan input file to set the number of procs, it figures it out.
mpirun -np 4
in the coupling.in I have
Nthreads(ocean) = 2
Nthreads(waves) = 2
and in the ocean.in I have
NtileI == 2 ! I-direction partition
NtileJ == 1 ! J-direction partition
so it should work? I keep getting the error as above though.
Nthreads(ocean) = 2
Nthreads(waves) = 2
maybe if i could see the whole stdout that might help.
Here it is. The PRINT-001 and -002 files and the Errfiles created by SWAN are empty.
Moritzs-MacBook-Pro:test2 Hawky$ mpirun -np 4 oceanM coupling_inlet_test.in
[Moritzs-MacBook-Pro.local:1478] *** An error occurred in MPI_Gather
[Moritzs-MacBook-Pro.local:1478] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
[Moritzs-MacBook-Pro.local:1478] *** MPI_ERR_TYPE: invalid datatype
[Moritzs-MacBook-Pro.local:1478] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 1 with PID 1478 on
[Moritzs-MacBook-Pro.local:01474] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[Moritzs-MacBook-Pro.local:01474] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Coupled Input File name = coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 001
Waves Model MPI nodes: 002 - 003
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
Wednesday - May 1, 2013 - 3:52:06 PM
Inlet Test Case
Operating system : Darwin
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/local/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -I/usr/local/include -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
Input Script : /Users/Hawky/ROMS/Projects/test2/ocean_inlet_test.in
SVN Revision : 655M
Local Root : /Users/Hawky/ROMS/trunk
Header Dir : /Users/Hawky/ROMS/Projects/test2
Header file : inlet_test.h
Analytical Dir: /Users/Hawky/ROMS/Projects/test2
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 2, Tiling: 002x001
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
into restart fields.
to standard output.
into history file.
1.0000E-03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1.5000E-02 Zob Bottom roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wavelength.
T Hout(idWdir) Write out wave direction.
Physical parameters File: /Users/Hawky/ROMS/Projects/test2/ocean_inlet_test.in
Input Grid File: inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 002x001
tile Istr Iend Jstr Jend Npts
0 1 38 1 70 21280
1 39 75 1 70 20720
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 38.50 0.50 70.50 RHO-points
1 38.50 75.50 0.50 70.50 RHO-points
0 1.00 38.50 0.50 70.50 U-points
1 38.50 75.00 0.50 70.50 U-points
0 0.50 38.50 1.00 70.00 V-points
1 38.50 75.50 1.00 70.00 V-points
HaloSizeI(1) = 150
HaloSizeJ(1) = 243
TileSide(1) = 75
TileSize(1) = 3300
zeta 1 ?!O ?/? L H%
ubar 1 ?!O ?/? L H%
vbar 1 ?!O ?/? L H%
u 1 ?!O ?/? L H%
v 1 ?!O ?/? L H%
temp 1 ?!O ?/? L H%
salt 1 ?!O ?/? L H%
INLET_TEST Inlet Test Case
FSOBC_REDUCED Using free-surface data in reduced physics conditions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR08 Nearshore Radiation Stress Terms (Mellor 2008).
NONLINEAR Nonlinear Model.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
Process Information:
Node # 0 (pid= 1477) is active.
Node # 1 (pid= 1478) is active.
i am not sure. you could try to use 1 proc for each model and see if that works. if you are getting an Errfile from SWAN, then something is wrong with the swan input files. if you run w/ just 1 proc for swan, then those files usually get written to.
I just ran the INLET_TEST on my MacBook Pro using gfortran and two CPUs and it finished successfully. I am using the latest version of the code (revision 661) and all the input scripts distributed in the ROMS test repository https://www.myroms.org/svn/src/test.
It seems to me that you are doing something that it is inconsistent. The MCT library and ROMS needs to be compiled with the same version of the gfortran compiler and the OpenMPI library. Also, you need to use the appropriate mpirun associated with that version of the OpenMPI library. Many users have problems with this test case because this inconsistency.
I noticed that the ROMS standard output has a lot weird characters when reporting the lateral boundary conditions. It is always useful to put such text in this forum using the Code tag for easy read.
Thanks for the replies.
Is there a chance that there's something wrong with my header file when compiling the model? Here's my header file.
and openmpi using
So I'm using the same flags for both. Anything else I could try?
My SWAN output tells me that there's an input file missing. I have defined the locations for inlet_test_grid_coord.grd and inlet_test_bathy.bot though. Any other input files I could be missing?i am not sure. you could try to use 1 proc for each model and see if that works. if you are getting an Errfile from SWAN, then something is wrong with the swan input files. if you run w/ just 1 proc for swan, then those files usually get written to.
The INLET_TEST on the site is for sediment transport so I guess I have to modify it to couple ocean_inlet_test.in with swan_inlet_test.in instead of sediment_inlet_test.in?I just ran the INLET_TEST on my MacBook Pro using gfortran and two CPUs and it finished successfully. I am using the latest version of the code (revision 661) and all the input scripts distributed in the ROMS test repository https://www.myroms.org/svn/src/test.
** svn $Id: inlet_test.h 645 2013-01-22 23:21:54Z arango $
** Copyright (c) 2002-2013 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Inlet Test Case, waves-ocean (SWAN/ROMS) two-way coupling.
** Application flag: INLET_TEST
** Input script: ocean_inlet_test.in
** coupling_inlet_test.in
** swan_inlet_test.in
#define TS_MPDATA
#define SPLINES
#define ANA_INITIAL
#define ANA_SMFLUX
#define ANA_FSOBC
#define ANA_M2OBC
#undef UV_COR
#define UV_LDRAG
#define FSOBC_REDUCED
#define SWAN_COUPLING
#define NEARSHORE_MELLOR08
#ifdef SOLVE3D
#define GLS_MIXING
#ifdef GLS_MIXING
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_BPFLUX
#define ANA_SPFLUX
#define ANA_SRFLUX
#ifdef SWAN_COUPLING
# define MCT_LIB
I have compiled MCT usingThe MCT library and ROMS needs to be compiled with the same version of the gfortran compiler and the OpenMPI library. Also, you need to use the appropriate mpirun associated with that version of the OpenMPI library. Many users have problems with this test case because this inconsistency.
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local --enable-mpiserial
As I mentioned above, you just need to download the test repository and check the inlet_test sub-directory to see how everything is set-up. Check the input scripts and inlet_test/Data sub-directory. You can find all your answers there...
I did download it but the header file says
and I want to use swan_inlet_test.in as input so I assume I have to modify the header file, which I did, as stated above.
** sediment_inlet_test.in
Just a quick update.
Like I suspected, I made the error when compiling MCT.
I compiled MCT without openMPI using --enable-mpiserial
To get it to work I had to compile openmpi first using
and then MCT using
Now it's all good.
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CC=gcc CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
./configure CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
I have a similar problem with MCT on my mac. I am using macbook late 2009 Core 2 Duo. Procedure for installation of ROMS is followed based on https://www.myroms.org/wiki/ROMS_Mac_Snow_Leopard and The upwelling case is run successfully. Netcdf-3.6.3 is installed using post: viewtopic.php?f=14&t=4156
Openmpi is successfully installed with slight modification from previous post as follows:
$ ./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++45 CC=gcc45 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
$ make -j 4
$ make -j 4 check
$ sudo make install
However, installation of MCT did not work out. I tried various ways for instance:
or
$ ./configure CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
The configure part goes well, but when I try make, I get the following error:
$ make
make[1]: Entering directory `/Users/soroush/source_builds/MCT/mpeu'
gfortran -c -I. -I../ -DSYSDARWIN -DCPRGNU -O2 m_mpif.F90
m_mpif.F90:60: Error: Can't open included file 'mpif.h'
make[1]: *** [m_mpif.o] Error 1
make[1]: Leaving directory `/Users/soroush/source_builds/MCT/mpeu'
make: *** [subdirs] Error 2
I very much appreciate any help and advice how to install MCT. Config.log file is also attached.
Many thanks,
Soroush
$ make -j 4
$ make -j 4 check
$ sudo make install
or
$ make
Many thanks,
Soroush
- config.log
- (28.96 KiB) Downloaded 509 times
Hi Soroush,
It looks like it can't find your mpif.h file.
I did a quick google search and it seems like your problem is similar to this one here https://bb.cgd.ucar.edu/node/1001293
Maybe this helps?
Maybe this helps?
Moritz,
Thank you very much for your response. I agree that mpif.h is probably not found or read. This file is located in:
$ ll /opt/gfortransoft/openmpi/openmpi-1.4.5/include/
total 288
drwxr-xr-x 9 root wheel 306B May 17 20:53 .
drwxr-xr-x 7 root wheel 238B May 17 20:52 ..
-rw-r--r-- 1 root wheel 108K May 17 20:53 mpi.h
-rw-r--r--@ 1 root wheel 19K May 17 20:53 mpif-common.h
-rw-r--r-- 1 root wheel 3.6K May 17 20:53 mpif-config.h
-rw-r--r--@ 1 root wheel 3.8K May 17 20:53 mpif-mpi-io.h
-rw-r--r-- 1 root wheel 3.6K May 17 20:53 mpif.h
drwxr-xr-x 3 root wheel 102B May 17 20:53 openmpi
drwxr-xr-x 26 root wheel 884B May 17 20:53 vampirtrace
Do you think I need to add something to ./configure to make it work? I tried to add FC=mpi90 CC=mpicc CXX=mpicc without success for instance:
$ ./configure CXX=mpiCC CC=mpicc FC=mpi90 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
checking whether the C compiler works... no
configure: error: in `/Users/soroush/source_builds/MCT':
configure: error: C compiler cannot create executables
See `config.log' for more details
Any thoughts?
total 288
Any thoughts?
It told you to look in the config.log for details. Was there anything of interest there?
I looked into my config.log file. There are some other errors found there as follows:
configure cc -E -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include conftest.c
conftest.c:9:10: fatal error: 'ac_nonexistent.h' file not found
#include <ac_nonexistent.h>
1 error generated.
1 error generated.
configure $? = 1
configure cc -c -g -O2 -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include conftest.c >&5
conftest.c:26:4: error: use of undeclared identifier 'not'
not big endian
1 error generated.
./configure: line 1638: mpi90: command not found
configure $? = 127
configure: failed program was:
| program main
| end
configure result: unknown
configure error: Fortran could not compile .F90 files
However, I don't have any clue what to add in my configure to overcome them.
1 error generated.
1 error generated.
configure $? = 1
not big endian
1 error generated.
configure $? = 127
| program main
| end
- config.log
- (14.87 KiB) Downloaded 474 times
Ah, this:
should be:
FC=mpi90
FC=mpif90
Thank you Kate, I made this change yet error persists as follows:
$ ./configure CXX=mpiCC CC=mpicc FC=mpif90 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
Now it seems that mpicc is not found since in new config.log file I see the following:
configure checking for C compiler version
configure mpicc --version >&5
./configure: line 2371: mpicc: command not found
configure $? = 127
configure mpicc -v >&5
configure $? = 127
configure mpicc -V >&5
configure $? = 127
configure mpicc -qversion >&5
configure $? = 127
configure checking whether the C compiler works
configure mpicc -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include -L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib conftest.c >&5
./configure: line 2424: mpicc: command not found
The config.log file is attached.
configure $? = 127
configure $? = 127
configure $? = 127
configure $? = 127
- config.log
- (6.11 KiB) Downloaded 467 times
Do you have mpicc? What happens when you type "which mpicc" on the command line?
chinook01 353% which mpicc
/opt/scyld/openmpi/1.10.2/gnu/bin/mpicc
Actually, nothing is reported back. Seems I don't have mpicc. I followed the procedure from https://www.myroms.org/wiki/ROMS_Mac_Snow_Leopard and downloaded and installed opemmpi as stated before. Is there any step that I am missing? How can I adjust mpicc?
soroushs-MacBook:~ soroush$ which mpicc
I'm using brew to install things on a Mac and its openmpi comes with mpicc:
Kates-MacBook-Pro:remapping kate$ which mpicc
/usr/local/bin/mpicc
Kates-MacBook-Pro:remapping kate$ ls -l /usr/local/bin/mpicc
lrwxr-xr-x 1 kate admin 35 May 2 09:24 /usr/local/bin/mpicc@ -> ../Cellar/open-mpi/1.10.2/bin/mpicc
Kate,
Thank you very much for your advice. I re-installed openmpi with macports using:
$ sudo port install openmpi
Now everything is ok. After installation, the location of mpicc and mpif90 should be added to paths. For my case The following line is added to .bash_profile:
export PATH=$PATH:/opt/local/libexec/openmpi-mp
