MCT error Inlet test case on a Mac
moritz.wandres
#1 Unread post by moritz.wandres »
Hey all,
I'm having troubles compiling the inlet test case.
It might have something to do with how I compiled MCT?!
I'm running ROMS on a Mac (Mountain Lion).
I compiled MCT using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/opt/local/include LDFLAGS=-L/opt/local/lib --prefix=/opt/local --enable-mpiserial
The MCT example cases can be made so it seems like it's all good there.
I compiled my openmpi using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
When I run the build.bash for the inlet case I get the following error:
USE m_MCTWorld, ONLY : MCTWorld_init => init
1
Fatal Error: Can't open module file 'm_mctworld.mod' for reading at (1): No such file or directory
make: *** [/Users/Hawky/ROMS/Projects/test2//Build/ocean_coupler.o] Error 1
I changed the Darwin-gfortran.mk compiler (saw that in another post) to include the directories of the MCT into
ifdef USE_MCT
MCT_INCDIR ?= /opt/local/include
MCT_LIBDIR ?= /opt/local/lib
FFLAGS += -I$(MCT_INCDIR)
LIBS += -L$(MCT_LIBDIR) -lmct -lmpeu
endif
and now I get the following error:
USE distribute_mod, ONLY : mp_reduce
1
Error: Symbol 'mp_reduce' referenced at (1) not found in module 'distribute_mod'
ocean_coupler.f90:362.57:
Asize=GlobalSegMap_lsize (GSMapROMS, OCN_COMM_WORLD)
1
Error: Symbol 'ocn_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:160.49:
CALL MCTWorld_init (Nmodels, MPI_COMM_WORLD, OCN_COMM_WORLD, &
1
Error: Symbol 'mpi_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:155.40:
CALL mpi_comm_rank (OCN_COMM_WORLD, MyRank, MyError)
1
Any ideas what I did wrong or where the issue might be?
Cheers!
Moritz
Re: MCT error Inlet test case on a Mac
"USE m_MCTWorld, ONLY : MCTWorld_init => init
1
make: *** [/Users/Hawky/ROMS/Projects/test2//Build/ocean_coupler.o] Error 1"
I have seen this before. it sounds like issues related to the "make install" portion for MCT. make sure the *.mod files and *.libs for mct have been copied to your
usr/local/include and usr/local/lib (or other apporpriate dirs) and that those dirs are in your path.
moritz.wandres
#3 Unread post by moritz.wandres »
Thanks for the answer, as I said before, it was a path error but after setting the paths correctly it still leaves me with this error message:
1
1
1
1
Could be that I made a mistake in installing OpenMPI?
Thanks for any suggestions.
#4 Unread post by jcwarner »
"Error: Symbol 'ocn_comm_world' at (1) has no IMPLICIT type
ocean_coupler.f90:160.49:"
did you define to use MPI in the bash file?
moritz.wandres
#5 Unread post by moritz.wandres »
Of course thanks!
I had
USE_OpenMP=on
instead of
USE_MPI=on
USE_MPIF90=on
I guess I got confused with the open MPI. I can compile it now, however I can't run the model.
To run it I type
mpirun -np 4 oceanM ocean_inlet_test.in
and get
Coupled Input File name = ocean_inlet_test.in
MOD_COUPLER - Unable to open variable information file:
Default file is located in source directory.
mpirun has exited due to process rank 1 with PID 15625 on
node Moritzs-MacBook-Pro.local exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Any ideas?
Moritz
#6 Unread post by jcwarner »
you need to point to the coupling_inlet_test.in, not the ocean.in
moritz.wandres
#7 Unread post by moritz.wandres »
Thanks for the help.
I now get the following error:
Node # 0 (pid= 847) is active.
Node # 1 (pid= 848) is active.
[Moritzs-MacBook-Pro.local:848] *** An error occurred in MPI_Gather
[Moritzs-MacBook-Pro.local:848] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
[Moritzs-MacBook-Pro.local:848] *** MPI_ERR_TYPE: invalid datatype
[Moritzs-MacBook-Pro.local:848] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 1 with PID 848 on
[Moritzs-MacBook-Pro.local:00845] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[Moritzs-MacBook-Pro.local:00845] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Any idea what I'm doing wrong?
#8 Unread post by jcwarner »
you need to make sure that you launch the job with the same number of procs that are being used. so if you use
mpirun -np 4
then in the coupling.in file you need to assign 4 procs, lets say 2 to roms and 2 to swan. Then you need to make sure the roms ocean.in file has ntileI and ntileJ to be set for 2 procs. you do not need to set anything in the swan input file to set the number of procs, it figures it out.
moritz.wandres
#9 Unread post by moritz.wandres »
in the coupling.in I have
Nthreads(ocean) = 2
Nthreads(waves) = 2
and in the ocean.in I have
NtileI == 2 ! I-direction partition
NtileJ == 1 ! J-direction partition
so it should work? I keep getting the error as above though.
#10 Unread post by jcwarner »
maybe if i could see the whole stdout that might help.
moritz.wandres
#11 Unread post by moritz.wandres »
Here it is. The PRINT-001 and -002 files and the Errfiles created by SWAN are empty.
Moritzs-MacBook-Pro:test2 Hawky$ mpirun -np 4 oceanM coupling_inlet_test.in
 Coupled Input File name = coupling_inlet_test.in
 Model Coupling Parallel Threads:
   Ocean Model MPI nodes:   000 - 001
   Waves Model MPI nodes:   002 - 003
   Ocean Export: bath:SSH:Ubar:Vbar:ZO
   Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot:Wubot
 Model Input Parameters:  ROMS/TOMS version 3.6
                          Wednesday - May 1, 2013 -  3:52:06 PM
 Inlet Test Case
 Operating system : Darwin
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /usr/local/bin/mpif90
 Compiler flags   : -frepack-arrays -O3 -ffast-math -I/usr/local/include -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
 Input Script  : /Users/Hawky/ROMS/Projects/test2/ocean_inlet_test.in
 SVN Root URL  : https://www.myroms.org/svn/src/trunk
 SVN Revision  : 655M
 Local Root    : /Users/Hawky/ROMS/trunk
 Header Dir    : /Users/Hawky/ROMS/Projects/test2
 Header file   : inlet_test.h
 Analytical Dir: /Users/Hawky/ROMS/Projects/test2
 Resolution, Grid 01: 0075x0070x008,  Parallel Nodes:   2,  Tiling: 002x001
      34560  ntimes          Number of timesteps for 3-D equations.
      5.000  dt              Timestep size (s) for 3-D equations.
         20  ndtfast         Number of timesteps for 2-D equations between
          1  ERstr           Starting ensemble/perturbation run number.
          1  ERend           Ending ensemble/perturbation run number.
          0  nrrec           Number of restart records to read from disk.
          T  LcycleRST       Switch to recycle time-records in restart file.
        720  nRST            Number of timesteps between the writing of data
                               into restart fields.
          1  ninfo           Number of timesteps between print of information
                               to standard output.
          T  ldefout         Switch to create a new output NetCDF file(s).
        720  nHIS            Number of timesteps between the writing fields
                               into history file.
 1.0000E-03  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 5.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 5.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 3.0000E-04  rdrg            Linear bottom drag coefficient (m/s).
 2.5000E-02  rdrg2           Quadratic bottom drag coefficient.
 1.5000E-02  Zob             Bottom roughness (m).
          1  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 1.0000E+00  theta_s         S-coordinate surface control parameter.
 1.0000E+00  theta_b         S-coordinate bottom  control parameter.
      0.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1025.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
      0.000  dstart          Time-stamp assigned to model initialization (days).
       0.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 0.0000E+00  Znudg           Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg          Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 0.0000E+00  obcfac          Factor between passive and active
          F  VolCons(1)      NLM western  edge boundary volume conservation.
          F  VolCons(2)      NLM southern edge boundary volume conservation.
          F  VolCons(3)      NLM eastern  edge boundary volume conservation.
          F  VolCons(4)      NLM northern edge boundary volume conservation.
     10.000  T0              Background potential temperature (C) constant.
     30.000  S0              Background salinity (PSU) constant.
   1027.000  R0              Background density (kg/m3) used in linear Equation
                               of State.
 1.7000E-04  Tcoef           Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef           Saline contraction coefficient (1/PSU).
      1.000  gamma2          Slipperiness variable: free-slip (1.0) or
          T  Hout(idFsur)    Write out free-surface.
          T  Hout(idUbar)    Write out 2D U-momentum component.
          T  Hout(idVbar)    Write out 2D V-momentum component.
          T  Hout(idUvel)    Write out 3D U-momentum component.
          T  Hout(idVvel)    Write out 3D V-momentum component.
          T  Hout(idWvel)    Write out W-momentum component.
          T  Hout(idOvel)    Write out omega vertical velocity.
          T  Hout(idTvar)    Write out tracer 01: temp
          T  Hout(idTvar)    Write out tracer 02: salt
          T  Hout(idW2xx)    Write out 2D radiation stress, Sxx.
          T  Hout(idW2xy)    Write out 2D radiation stress, Sxy.
          T  Hout(idW2yy)    Write out 2D radiation stress, Syy.
          T  Hout(idWamp)    Write out wave height.
          T  Hout(idWlen)    Write out wavelength.
          T  Hout(idWdir)    Write out wave direction.
             Output Restart File:  ocean_rst.nc
             Output History File:  ocean_his.nc
        Physical parameters File:  /Users/Hawky/ROMS/Projects/test2/ocean_inlet_test.in
                 Input Grid File:  inlet_test_grid.nc
 Tile partition information for Grid 01:  0075x0070x0008  tiling: 002x001
        0        1       38        1       70    21280
        1       39       75        1       70    20720
   (interior points only)
        0     0.50    38.50     0.50    70.50  RHO-points
        1    38.50    75.50     0.50    70.50  RHO-points
        0     1.00    38.50     0.50    70.50    U-points
        1    38.50    75.00     0.50    70.50    U-points
        0     0.50    38.50     1.00    70.00    V-points
        1    38.50    75.50     1.00    70.00    V-points
               HaloSizeI(1) =     150
               HaloSizeJ(1) =     243
                TileSide(1) =      75
                TileSize(1) =    3300
 Variable               Grid    West Edge   South Edge  East Edge   North Edge
 zeta                     1     ?!O  ?/? L    H%
 ubar                     1     ?!O  ?/? L    H%
 vbar                     1     ?!O  ?/? L    H%
 u                        1     ?!O  ?/? L    H%
 v                        1     ?!O  ?/? L    H%
 temp                     1     ?!O  ?/? L    H%
 salt                     1     ?!O  ?/? L    H%
 INLET_TEST          Inlet Test Case
 ANA_FSOBC           Analytical free-surface boundary conditions.
 ANA_INITIAL         Analytical initial conditions.
 ANA_M2OBC           Analytical 2D momentum boundary conditions.
 ANA_SMFLUX          Analytical kinematic surface momentum flux.
 ANA_SSFLUX          Analytical kinematic surface salinity flux.
 ANA_STFLUX          Analytical kinematic surface temperature flux.
 FSOBC_REDUCED       Using free-surface data in reduced physics conditions
 MCT_LIB             Using Model Coupling Toolkit library.
 NEARSHORE_MELLOR08  Nearshore Radiation Stress Terms (Mellor 2008).
 !NONLIN_EOS         Linear Equation of State for seawater.
 SWAN_COUPLING       Two-way SWAN/ROMS coupling.
 TS_MPDATA           Recursive flux corrected MPDATA 3D advection of tracers.
 UV_LDRAG            Linear bottom stress.
 WAVES_OCEAN         Two-way wave-ocean models coupling.
 Process Information:
 Node #  0 (pid=    1477) is active.
 Node #  1 (pid=    1478) is active.
[Moritzs-MacBook-Pro.local:1478] *** An error occurred in MPI_Gather
[Moritzs-MacBook-Pro.local:1478] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
[Moritzs-MacBook-Pro.local:1478] *** MPI_ERR_TYPE: invalid datatype
[Moritzs-MacBook-Pro.local:1478] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 1 with PID 1478 on
[Moritzs-MacBook-Pro.local:01474] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[Moritzs-MacBook-Pro.local:01474] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
#12 Unread post by jcwarner »
i am not sure. you could try to use 1 proc for each model and see if that works. if you are getting an Errfile from SWAN, then something is wrong with the swan input files. if you run w/ just 1 proc for swan, then those files usually get written to.
#13 Unread post by arango »
I just ran the INLET_TEST on my MacBook Pro using gfortran and two CPUs and it finished successfully. I am using the latest version of the code (revision 661) and all the input scripts distributed in the ROMS test repository :arrow: https://www.myroms.org/svn/src/test.
It seems to me that you are doing something that it is inconsistent. The MCT library and ROMS needs to be compiled with the same version of the gfortran compiler and the OpenMPI library. Also, you need to use the appropriate mpirun associated with that version of the OpenMPI library. Many users have problems with this test case because this inconsistency.
I noticed that the ROMS standard output has a lot weird characters when reporting the lateral boundary conditions. It is always useful to put such text in this forum using the Code tag for easy read.
moritz.wandres
#14 Unread post by moritz.wandres »
Thanks for the replies.
My SWAN output tells me that there's an input file missing. I have defined the locations for inlet_test_grid_coord.grd and inlet_test_bathy.bot though. Any other input files I could be missing?
I just ran the INLET_TEST on my MacBook Pro using gfortran and two CPUs and it finished successfully. I am using the latest version of the code (revision 661) and all the input scripts distributed in the ROMS test repository https://www.myroms.org/svn/src/test.
The INLET_TEST on the site is for sediment transport so I guess I have to modify it to couple ocean_inlet_test.in with swan_inlet_test.in instead of sediment_inlet_test.in?
Is there a chance that there's something wrong with my header file when compiling the model? Here's my header file.
** svn $Id: inlet_test.h 645 2013-01-22 23:21:54Z arango $
** Copyright (c) 2002-2013 The ROMS/TOMS Group                               **
**   Licensed under a MIT/X style license                                    **
**   See License_ROMS.txt                                                    **
** Options for Inlet Test Case, waves-ocean (SWAN/ROMS) two-way coupling.
** Application flag:   INLET_TEST
** Input script:       ocean_inlet_test.in
**                     coupling_inlet_test.in
**                     swan_inlet_test.in
#define TS_MPDATA
#define SPLINES
#define ANA_INITIAL
#define ANA_SMFLUX
#define ANA_FSOBC
#define ANA_M2OBC
#undef  UV_COR
#define UV_LDRAG
#define FSOBC_REDUCED
#define SWAN_COUPLING
#define NEARSHORE_MELLOR08
#ifdef SOLVE3D
#define GLS_MIXING
#ifdef GLS_MIXING
#  define KANTHA_CLAYSON
#  define N2S2_HORAVG
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_BPFLUX
#define ANA_SPFLUX
#define ANA_SRFLUX
#ifdef SWAN_COUPLING
# define MCT_LIB
I have compiled MCT using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local --enable-mpiserial
and openmpi using
So I'm using the same flags for both. Anything else I could try?
#15 Unread post by arango »
As I mentioned above, you just need to download the test repository and check the inlet_test sub-directory to see how everything is set-up. Check the input scripts and inlet_test/Data sub-directory. You can find all your answers there...
moritz.wandres
#16 Unread post by moritz.wandres »
I did download it but the header file says
**                     sediment_inlet_test.in
and I want to use swan_inlet_test.in as input so I assume I have to modify the header file, which I did, as stated above.
moritz.wandres
#17 Unread post by moritz.wandres »
Just a quick update.
Like I suspected, I made the error when compiling MCT.
I compiled MCT without openMPI using --enable-mpiserial
To get it to work I had to compile openmpi first using
./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ CC=gcc CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
and then MCT using
./configure CPPFLAGS=-I/usr/local/include LDFLAGS=-L/usr/local/lib --prefix=/usr/local
Now it's all good.
ssorou1
#18 Unread post by ssorou1 »
I have a similar problem with MCT on my mac. I am using macbook late 2009 Core 2 Duo. Procedure for installation of ROMS is followed based on https://www.myroms.org/wiki/ROMS_Mac_Snow_Leopard and The upwelling case is run successfully. Netcdf-3.6.3 is installed using post: viewtopic.php?f=14&t=4156
Openmpi is successfully installed with slight modification from previous post as follows:
$ ./configure FC=gfortran F77=gfortran F90=gfortran CXX=g++45 CC=gcc45 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
$ make -j 4
$ make -j 4 check
$ sudo make install
However, installation of MCT did not work out. I tried various ways for instance:
or
$ ./configure CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
The configure part goes well, but when I try make, I get the following error:
$ make
make[1]: Entering directory `/Users/soroush/source_builds/MCT/mpeu'
gfortran -c -I. -I../ -DSYSDARWIN -DCPRGNU -O2 m_mpif.F90
m_mpif.F90:60: Error: Can't open included file 'mpif.h'
make[1]: *** [m_mpif.o] Error 1
make[1]: Leaving directory `/Users/soroush/source_builds/MCT/mpeu'
make: *** [subdirs] Error 2
I very much appreciate any help and advice how to install MCT. Config.log file is also attached.
Many thanks,
Soroush
config.log
(28.96 KiB) Downloaded 1256 times
moritz.wandres
#19 Unread post by moritz.wandres »
Hi Soroush,
It looks like it can't find your mpif.h file.
I did a quick google search and it seems like your problem is similar to this one here https://bb.cgd.ucar.edu/node/1001293
Maybe this helps?
ssorou1
#20 Unread post by ssorou1 »
Moritz,
Thank you very much for your response. I agree that mpif.h is probably not found or read. This file is located in:
$ ll /opt/gfortransoft/openmpi/openmpi-1.4.5/include/
total 288
drwxr-xr-x 9 root wheel 306B May 17 20:53 .
drwxr-xr-x 7 root wheel 238B May 17 20:52 ..
-rw-r--r-- 1 root wheel 108K May 17 20:53 mpi.h
-rw-r--r--@ 1 root wheel 19K May 17 20:53 mpif-common.h
-rw-r--r-- 1 root wheel 3.6K May 17 20:53 mpif-config.h
-rw-r--r--@ 1 root wheel 3.8K May 17 20:53 mpif-mpi-io.h
-rw-r--r-- 1 root wheel 3.6K May 17 20:53 mpif.h
drwxr-xr-x 3 root wheel 102B May 17 20:53 openmpi
drwxr-xr-x 26 root wheel 884B May 17 20:53 vampirtrace
Do you think I need to add something to ./configure to make it work? I tried to add FC=mpi90 CC=mpicc CXX=mpicc without success for instance:
$ ./configure CXX=mpiCC CC=mpicc FC=mpi90 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
checking whether the C compiler works... no
configure: error: in `/Users/soroush/source_builds/MCT':
configure: error: C compiler cannot create executables
See `config.log' for more details
Any thoughts?
#21 Unread post by kate »
It told you to look in the config.log for details. Was there anything of interest there?
ssorou1
#22 Unread post by ssorou1 »
I looked into my config.log file. There are some other errors found there as follows:
configure:2898: cc -E -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include conftest.c
conftest.c:9:10: fatal error: 'ac_nonexistent.h' file not found
#include <ac_nonexistent.h>
1 error generated.
configure:2957: cc -E -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include conftest.c
1 error generated.
configure:2957: $? = 1
configure:3323: cc -c -g -O2 -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include conftest.c >&5
conftest.c:26:4: error: use of undeclared identifier 'not'
not big endian
1 error generated.
./configure: line 1638: mpi90: command not found
configure:3716: $? = 127
configure: failed program was:
| program main
| end
configure:3725: result: unknown
configure:3728: error: Fortran could not compile .F90 files
However, I don't have any clue what to add in my configure to overcome them. :(
config.log
(14.87 KiB) Downloaded 1475 times
#23 Unread post by kate »
Ah, this:
FC=mpi90
should be:
FC=mpif90
ssorou1
#24 Unread post by ssorou1 »
Thank you Kate, I made this change yet error persists as follows:
$ ./configure CXX=mpiCC CC=mpicc FC=mpif90 CPPFLAGS=-I/opt/gfortransoft/openmpi/openmpi-1.4.5/include LDFLAGS=-L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib --prefix=/opt/gfortransoft/openmpi/openmpi-1.4.5
Now it seems that mpicc is not found since in new config.log file I see the following:
configure:2360: checking for C compiler version
configure:2369: mpicc --version >&5
./configure: line 2371: mpicc: command not found
configure:2380: $? = 127
configure:2369: mpicc -v >&5
configure:2369: mpicc -V >&5
configure:2369: mpicc -qversion >&5
configure:2400: checking whether the C compiler works
configure:2422: mpicc -I/opt/gfortransoft/openmpi/openmpi-1.4.5/include -L/opt/gfortransoft/openmpi/openmpi-1.4.5/lib conftest.c >&5
./configure: line 2424: mpicc: command not found
The config.log file is attached.
config.log
(6.11 KiB) Downloaded 1432 times
#25 Unread post by kate »
Do you have mpicc? What happens when you type "which mpicc" on the command line?
chinook01 353% which mpicc
/opt/scyld/openmpi/1.10.2/gnu/bin/mpicc
ssorou1
#26 Unread post by ssorou1 »
Actually, nothing is reported back. Seems I don't have mpicc. I followed the procedure from https://www.myroms.org/wiki/ROMS_Mac_Snow_Leopard and downloaded and installed opemmpi as stated before. Is there any step that I am missing? How can I adjust mpicc?
soroushs-MacBook:~ soroush$ which mpicc
#27 Unread post by kate »
I'm using brew to install things on a Mac and its openmpi comes with mpicc:
Kates-MacBook-Pro:remapping kate$ which mpicc
/usr/local/bin/mpicc
Kates-MacBook-Pro:remapping kate$ ls -l /usr/local/bin/mpicc
lrwxr-xr-x  1 kate  admin  35 May  2 09:24 /usr/local/bin/mpicc@ -> ../Cellar/open-mpi/1.10.2/bin/mpicc
ssorou1
#28 Unread post by ssorou1 »
Kate,
Thank you very much for your advice. I re-installed openmpi with macports using:
$ sudo port install openmpi
Now everything is ok. After installation, the location of mpicc and mpif90 should be added to paths. For my case The following line is added to .bash_profile:
export PATH=$PATH:/opt/local/libexec/openmpi-mp
