First of all, sorry for the lengthy post. I tried to make it as short as possible without disregarding important info.
I know that a lot of posts are about ROMS blowing up, and I also know that the solution is very user-specific. I do not expect someone to solve my problem, but maybe give me clues on how to identify the reason why my model is blowing up at the second timestep.
My setup is a channel (2 closed boundary, one clamped boundary upstream, one radiation boundary downstream), with a clamped 2D flow at both the upstream and downstream boundary. Here is what ROMS prints (I striped off what I think is non relevant, just to make the post less overwhelming)
Resolution, Grid 01: 0050x0200x030, Parallel Threads: 1, Tiling: 001x001
86400 ntimes Number of timesteps for 3-D equations.
231.000 dt Timestep size (s) for 3-D equations.
36 ndtfast Number of timesteps for 2-D equations between
200 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
200 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
200 nAVG Number of timesteps between the writing of
200 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
5.0000E-06 Akv_bak Background vertical mixing coefficient (m2/s)
for turbulent energy.
7.0000E+00 theta_s S-coordinate surface control parameter.
2.5000E+00 theta_b S-coordinate bottom control parameter.
30.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
9.000 T0 Background potential temperature (C) constant.
32.000 S0 Background salinity (PSU) constant.
1025.000 R0 Background density (kg/m3) used in linear Equation
of State.
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0050x0200x0030 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 50 1 200 300000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 51.50 0.50 201.50 RHO-points
0 0.00 51.00 0.50 201.50 U-points
0 0.50 51.50 0.00 201.00 V-points
zeta 1 Closed Radiation Closed Clamped
ubar 1 Closed Radiation Closed Clamped
vbar 1 Closed Radiation Closed Clamped
u 1 Closed Radiation Closed Clamped
v 1 Closed Radiation Closed Clamped
temp 1 Closed Radiation Closed Clamped
salt 1 Closed Radiation Closed Clamped
tke 1 Closed Radiation Closed Clamped
COASTAL_CURRENT Coastal Current project
ANA_M3OBC Analytical 3D momentum boundary conditions.
ANA_TOBC Analytical tracers boundary conditions.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
!STOCH_OPT_WHITE Stochastic Optimals, red noise processes.
TS_A4HADVECTION Fourth-order Akima horizontal advection of tracers.
TS_A4VADVECTION Fourth-order Akima vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 7384) is active.
Vertical S-coordinate System:
ndtfast, nfast = 36 50 nfast/ndtfast = 1.38889
1.000000000000 1.042155637315 0.521077818658 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.20511
Minimum X-grid spacing, DXmin = 3.00000000E+00 km
Maximum X-grid spacing, DXmax = 3.00000000E+00 km
Minimum Y-grid spacing, DYmin = 3.01500000E-03 km
Maximum Y-grid spacing, DYmax = 3.01500000E-03 km
Minimum Z-grid spacing, DZmin = 6.29252209E-01 m
Maximum Z-grid spacing, DZmax = 2.16989607E+01 m
Minimum barotropic Courant Number = 4.71348238E+01
Maximum barotropic Courant Number = 1.05396670E+02
Maximum Coriolis Courant Number = 2.31000000E-02
Maximum grid stiffness ratios: rx0 = 8.000000E-02 (Beckmann and Haidvogel)
rx1 = 3.029772E+00 (Haney)
Initial basin volumes: TotVolume = 1.8286630435E+10 m3
MinVolume = 5.6915862271E+03 m3
MaxVolume = 1.9626709935E+05 m3
Max/Min = 3.4483725892E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00086400)
0 0 00:00:00 0.000000E+00 1.095119E+03 1.095119E+03 1.828663E+10
(00,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_AVG - creating average file: ocean_avg.nc
DEF_DIAGS - creating diagnostics file: ocean_dia.nc
1 0 00:03:51 NaN NaN NaN NaN
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Thread # 0 CPU: 1.292
Total: 1.292
Allocation and array initialization .............. 0.302 (23.3794 %)
Ocean state initialization ....................... 0.033 ( 2.5643 %)
Reading of input data ............................ 0.000 ( 0.0005 %)
Processing of input data ......................... 0.000 ( 0.0122 %)
Processing of output time averaged data .......... 0.001 ( 0.0463 %)
Computation of vertical boundary conditions ...... 0.000 ( 0.0087 %)
Computation of global information integrals ...... 0.013 ( 1.0436 %)
Writing of output data ........................... 0.084 ( 6.5188 %)
Model 2D kernel .................................. 0.225 (17.3987 %)
2D/3D coupling, vertical metrics ................. 0.014 ( 1.0921 %)
Omega vertical velocity .......................... 0.007 ( 0.5286 %)
Equation of state for seawater ................... 0.012 ( 0.9484 %)
My2.5 vertical mixing parameterization ........... 0.058 ( 4.4564 %)
3D equations right-side terms .................... 0.084 ( 6.4930 %)
3D equations predictor step ...................... 0.151 (11.6745 %)
Pressure gradient ................................ 0.026 ( 1.9761 %)
Harmonic mixing of tracers, S-surfaces ........... 0.041 ( 3.1514 %)
Harmonic stress tensor, S-surfaces ............... 0.046 ( 3.5648 %)
Corrector time-step for 3D momentum .............. 0.060 ( 4.6148 %)
Corrector time-step for tracers .................. 0.084 ( 6.5136 %)
Total: 1.240 95.9859
All percentages are with respect to total time = 1.292
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_grid.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_m3obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_tobc.h
- Change the timestep (make it shorter, my original values are dt=432 and ndtfast =72)
- Change my bathymetry to a flat bottom
- Change the different cpp definition
- Check the first record of the history file to check my initial conditions (bathy, temp, salt, u, v, zeta are OK). ubar and vbar are zero, which is not right because I have imposed an incoming flow (vbar) of -1.0 m/s at the upstream (north) boundary and -1.0m/s at the downstream (south) boundary in ANA_M2OBC. Could it come from the fact that I clamped a zero zeta but a non-zero 2D flow at the boundary?
#elif defined COASTAL_CURRENT
IF (LBC(ieast,isUbar,ng)%acquire.and. &
& LBC(ieast,isVbar,ng)%acquire.and. &
& DOMAIN(ng)%Eastern_Edge(tile)) THEN
DO j=JstrR,JendR
BOUNDARY(ng)%ubar_east(j)=0.0_r8
DO j=Jstr,JendR
BOUNDARY(ng)%vbar_east(j)=0.0_r8
IF (LBC(iwest,isUbar,ng)%acquire.and. &
& LBC(iwest,isVbar,ng)%acquire.and. &
& DOMAIN(ng)%Western_Edge(tile)) THEN
DO j=JstrR,JendR
BOUNDARY(ng)%ubar_west(j)=0.0_r8
DO j=Jstr,JendR
BOUNDARY(ng)%vbar_west(j)=0.0_r8
IF (LBC(isouth,isUbar,ng)%acquire.and. &
& LBC(isouth,isVbar,ng)%acquire.and. &
& DOMAIN(ng)%Southern_Edge(tile)) THEN
DO i=Istr,IendR
BOUNDARY(ng)%ubar_south(i)=0.0_r8
DO i=IstrR,IendR
BOUNDARY(ng)%vbar_south(i)=-1.0_r8
IF (LBC(inorth,isUbar,ng)%acquire.and. &
& LBC(inorth,isVbar,ng)%acquire.and. &
& DOMAIN(ng)%Northern_Edge(tile)) THEN
DO i=Istr,IendR
BOUNDARY(ng)%ubar_north(i)=0.0_r8
DO i=IstrR,IendR
BOUNDARY(ng)%vbar_north(i)=-1.0_r8
The other thing I have picked up in what ROMS prints is that my minimum and maximum "barotropic Courant Number" seems to be too big, from what I could understand from other posts. But I have no idea how to correct for this, any suggestions?
Mat.
