model blowing up
mathieudever
model blowing up
#1 Unread post by mathieudever »
First of all, sorry for the lengthy post. I tried to make it as short as possible without disregarding important info.
I know that a lot of posts are about ROMS blowing up, and I also know that the solution is very user-specific. I do not expect someone to solve my problem, but maybe give me clues on how to identify the reason why my model is blowing up at the second timestep.
My setup is a channel (2 closed boundary, one clamped boundary upstream, one radiation boundary downstream), with a clamped 2D flow at both the upstream and downstream boundary. Here is what ROMS prints (I striped off what I think is non relevant, just to make the post less overwhelming)
Resolution, Grid 01: 0050x0200x030,  Parallel Threads:  1,  Tiling: 001x001
      86400  ntimes          Number of timesteps for 3-D equations.
    231.000  dt              Timestep size (s) for 3-D equations.
         36  ndtfast         Number of timesteps for 2-D equations between
          1  ERstr           Starting ensemble/perturbation run number.
          1  ERend           Ending ensemble/perturbation run number.
          0  nrrec           Number of restart records to read from disk.
          T  LcycleRST       Switch to recycle time-records in restart file.
        200  nRST            Number of timesteps between the writing of data
                               into restart fields.
          1  ninfo           Number of timesteps between print of information
                               to standard output.
          T  ldefout         Switch to create a new output NetCDF file(s).
        200  nHIS            Number of timesteps between the writing fields
                               into history file.
          1  ntsAVG          Starting timestep for the accumulation of output
                               time-averaged data.
        200  nAVG            Number of timesteps between the writing of
          1  ntsDIA          Starting timestep for the accumulation of output
        200  nDIA            Number of timesteps between the writing of
 0.0000E+00  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 0.0000E+00  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 0.0000E+00  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 5.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 5.0000E-06  Akv_bak         Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak         Background vertical mixing coefficient (m2/s)
                               for turbulent energy.
 5.0000E-06  Akp_bak         Background vertical mixing coefficient (m2/s)
 3.0000E-04  rdrg            Linear bottom drag coefficient (m/s).
 3.0000E-03  rdrg2           Quadratic bottom drag coefficient.
 2.0000E-02  Zob             Bottom roughness (m).
          2  Vtransform      S-coordinate transformation equation.
          4  Vstretching     S-coordinate stretching function.
 7.0000E+00  theta_s         S-coordinate surface control parameter.
 2.5000E+00  theta_b         S-coordinate bottom  control parameter.
     30.000  Tcline          S-coordinate surface/bottom layer width (m) used
   1025.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
      0.000  dstart          Time-stamp assigned to model initialization (days).
       0.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 0.0000E+00  Znudg           Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg          Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 0.0000E+00  obcfac          Factor between passive and active
          F  VolCons(1)      NLM western  edge boundary volume conservation.
          F  VolCons(2)      NLM southern edge boundary volume conservation.
          F  VolCons(3)      NLM eastern  edge boundary volume conservation.
          F  VolCons(4)      NLM northern edge boundary volume conservation.
      9.000  T0              Background potential temperature (C) constant.
     32.000  S0              Background salinity (PSU) constant.
   1025.000  R0              Background density (kg/m3) used in linear Equation
                               of State.
 1.7000E-04  Tcoef           Thermal expansion coefficient (1/Celsius).
 7.6000E-04  Scoef           Saline contraction coefficient (1/PSU).
     -1.000  gamma2          Slipperiness variable: free-slip (1.0) or
             Output Restart File:  ocean_rst.nc
             Output History File:  ocean_his.nc
            Output Averages File:  ocean_avg.nc
         Output Diagnostics File:  ocean_dia.nc
 Tile partition information for Grid 01:  0050x0200x0030  tiling: 001x001
        0        1       50        1      200   300000
   (interior points only)
        0     0.50    51.50     0.50   201.50  RHO-points
        0     0.00    51.00     0.50   201.50    U-points
        0     0.50    51.50     0.00   201.00    V-points
 Variable               Grid    West Edge   South Edge  East Edge   North Edge
 zeta                     1     Closed      Radiation   Closed      Clamped
 ubar                     1     Closed      Radiation   Closed      Clamped
 vbar                     1     Closed      Radiation   Closed      Clamped
 u                        1     Closed      Radiation   Closed      Clamped
 v                        1     Closed      Radiation   Closed      Clamped
 temp                     1     Closed      Radiation   Closed      Clamped
 salt                     1     Closed      Radiation   Closed      Clamped
 tke                      1     Closed      Radiation   Closed      Clamped
 COASTAL_CURRENT     Coastal Current project
 ANA_FSOBC           Analytical free-surface boundary conditions.
 ANA_GRID            Analytical grid set-up.
 ANA_INITIAL         Analytical initial conditions.
 ANA_M2OBC           Analytical 2D momentum boundary conditions.
 ANA_M3OBC           Analytical 3D momentum boundary conditions.
 ANA_SMFLUX          Analytical kinematic surface momentum flux.
 ANA_SSFLUX          Analytical kinematic surface salinity flux.
 ANA_STFLUX          Analytical kinematic surface temperature flux.
 ANA_TOBC            Analytical tracers boundary conditions.
 DIAGNOSTICS_TS      Computing and writing tracer diagnostic terms.
 DIAGNOSTICS_UV      Computing and writing momentum diagnostic terms.
 MIX_S_TS            Mixing of tracers along constant S-surfaces.
 MY25_MIXING         Mellor/Yamada Level-2.5 mixing closure.
 !NONLIN_EOS         Linear Equation of State for seawater.
 K_GSCHEME           Third-order upstream advection of TKE fields.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 !STOCH_OPT_WHITE    Stochastic Optimals, red noise processes.
 TS_A4HADVECTION     Fourth-order Akima horizontal advection of tracers.
 TS_A4VADVECTION     Fourth-order Akima vertical advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 UV_LDRAG            Linear bottom stress.
 Process Information:
 Thread #  0 (pid=    7384) is active.
 Vertical S-coordinate System:
ndtfast, nfast =   36  50   nfast/ndtfast =  1.38889
    1.000000000000 1.042155637315 0.521077818658 1.000000000000 1.000000000000
 Power filter parameters, Fgamma, gamma =  0.28400   0.20511
 Minimum X-grid spacing, DXmin =  3.00000000E+00 km
 Maximum X-grid spacing, DXmax =  3.00000000E+00 km
 Minimum Y-grid spacing, DYmin =  3.01500000E-03 km
 Maximum Y-grid spacing, DYmax =  3.01500000E-03 km
 Minimum Z-grid spacing, DZmin =  6.29252209E-01 m
 Maximum Z-grid spacing, DZmax =  2.16989607E+01 m
 Minimum barotropic Courant Number =  4.71348238E+01
 Maximum barotropic Courant Number =  1.05396670E+02
 Maximum Coriolis   Courant Number =  2.31000000E-02
 Maximum grid stiffness ratios:  rx0 =   8.000000E-02 (Beckmann and Haidvogel)
                                 rx1 =   3.029772E+00 (Haney)
 Initial basin volumes: TotVolume =  1.8286630435E+10 m3
                        MinVolume =  5.6915862271E+03 m3
                        MaxVolume =  1.9626709935E+05 m3
                          Max/Min =  3.4483725892E+01
 NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00086400)
      0     0 00:00:00  0.000000E+00  1.095119E+03  1.095119E+03  1.828663E+10
           (00,000,00)  0.000000E+00  0.000000E+00  0.000000E+00  0.000000E+00
      DEF_HIS   - creating history file: ocean_his.nc
      WRT_HIS   - wrote history  fields (Index=1,1) into time record = 0000001
      DEF_AVG   - creating average file: ocean_avg.nc
      DEF_DIAGS - creating diagnostics file: ocean_dia.nc
      1     0 00:03:51           NaN           NaN           NaN           NaN
      WRT_RST   - wrote re-start fields (Index=1,2) into time record = 0000001
 Elapsed CPU time (seconds):
 Thread #  0 CPU:       1.292
 Total:                 1.292
  Allocation and array initialization ..............         0.302  (23.3794 %)
  Ocean state initialization .......................         0.033  ( 2.5643 %)
  Reading of input data ............................         0.000  ( 0.0005 %)
  Processing of input data .........................         0.000  ( 0.0122 %)
  Processing of output time averaged data ..........         0.001  ( 0.0463 %)
  Computation of vertical boundary conditions ......         0.000  ( 0.0087 %)
  Computation of global information integrals ......         0.013  ( 1.0436 %)
  Writing of output data ...........................         0.084  ( 6.5188 %)
  Model 2D kernel ..................................         0.225  (17.3987 %)
  2D/3D coupling, vertical metrics .................         0.014  ( 1.0921 %)
  Omega vertical velocity ..........................         0.007  ( 0.5286 %)
  Equation of state for seawater ...................         0.012  ( 0.9484 %)
  My2.5 vertical mixing parameterization ...........         0.058  ( 4.4564 %)
  3D equations right-side terms ....................         0.084  ( 6.4930 %)
  3D equations predictor step ......................         0.151  (11.6745 %)
  Pressure gradient ................................         0.026  ( 1.9761 %)
  Harmonic mixing of tracers, S-surfaces ...........         0.041  ( 3.1514 %)
  Harmonic stress tensor, S-surfaces ...............         0.046  ( 3.5648 %)
  Corrector time-step for 3D momentum ..............         0.060  ( 4.6148 %)
  Corrector time-step for tracers ..................         0.084  ( 6.5136 %)
                                              Total:         1.240   95.9859
 All percentages are with respect to total time =            1.292
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_fsobc.h
     ROMS/Functionals/ana_grid.h
     ROMS/Functionals/ana_m2obc.h
     ROMS/Functionals/ana_m3obc.h
     ROMS/Functionals/ana_smflux.h
     ROMS/Functionals/ana_stflux.h
     ROMS/Functionals/ana_tobc.h
It is clearly blowing up because Cu, Cv, Cw become NaNs
I have read as many posts as I could on possible reasons why it is blowing up. Here is the list of things I have tried:
- Change the timestep (make it shorter, my original values are dt=432 and ndtfast =72)
- Change my bathymetry to a flat bottom
- Change the different cpp definition
- Check the first record of the history file to check my initial conditions (bathy, temp, salt, u, v, zeta are OK). ubar and vbar are zero, which is not right because I have imposed an incoming flow (vbar) of -1.0 m/s at the upstream (north) boundary and -1.0m/s at the downstream (south) boundary in ANA_M2OBC. Could it come from the fact that I clamped a zero zeta but a non-zero 2D flow at the boundary?
#elif defined COASTAL_CURRENT
      IF (LBC(ieast,isUbar,ng)%acquire.and.                             &
    &    LBC(ieast,isVbar,ng)%acquire.and.                             &
    &    DOMAIN(ng)%Eastern_Edge(tile)) THEN
        DO j=JstrR,JendR
          BOUNDARY(ng)%ubar_east(j)=0.0_r8
        DO j=Jstr,JendR
          BOUNDARY(ng)%vbar_east(j)=0.0_r8
      IF (LBC(iwest,isUbar,ng)%acquire.and.                             &
    &    LBC(iwest,isVbar,ng)%acquire.and.                             &
    &    DOMAIN(ng)%Western_Edge(tile)) THEN
        DO j=JstrR,JendR
          BOUNDARY(ng)%ubar_west(j)=0.0_r8
        DO j=Jstr,JendR
          BOUNDARY(ng)%vbar_west(j)=0.0_r8
      IF (LBC(isouth,isUbar,ng)%acquire.and.                            &
    &    LBC(isouth,isVbar,ng)%acquire.and.                            &
    &    DOMAIN(ng)%Southern_Edge(tile)) THEN
        DO i=Istr,IendR
          BOUNDARY(ng)%ubar_south(i)=0.0_r8
        DO i=IstrR,IendR
          BOUNDARY(ng)%vbar_south(i)=-1.0_r8
      IF (LBC(inorth,isUbar,ng)%acquire.and.                            &
    &    LBC(inorth,isVbar,ng)%acquire.and.                            &
    &    DOMAIN(ng)%Northern_Edge(tile)) THEN
        DO i=Istr,IendR
          BOUNDARY(ng)%ubar_north(i)=0.0_r8
        DO i=IstrR,IendR
          BOUNDARY(ng)%vbar_north(i)=-1.0_r8
How come it does not pick up the imposed value of vbar?
The other thing I have picked up in what ROMS prints is that my minimum and maximum "barotropic Courant Number" seems to be too big, from what I could understand from other posts. But I have no idea how to correct for this, any suggestions?
Thank you for your help,
Mat.
dcherian
Re: model blowing up
#2 Unread post by dcherian »
To see how the Courant numbers are calculated, see Utility/metrics.F . To reduce it, reduce your time step. Right now you're using dt=432 seconds = 7.2 minutes which seems to be too big. The other way would be to increase ndtfast but your value seems pretty large already. Try dt=60, ndtfast = 30 and see if the model runs then. You can then gradually increase (or decrease if the model still blows up) it to see how large a timestep you can get away with.
This might also be useful: https://en.wikipedia.org/wiki/Courant%E ... _condition
I think ubar and vbar are zero in your initial condition because that's what ANA_INITIAL defaults to. You'll need to fix that in ana_initial.h . You also want the fields you're nudging/clamping to be consistent with each other. So, a non-zero barotropic velocity and zero free surface nudging at the boundary would be problematic.
