Hello everybody,
I am trying to get the tke and set the flag T for that in the .in file, see below. But the code is not writing this quantity, why could that be?
Hout(idDano) == T ! rho density anomaly
Hout(idMtke) == T ! tke turbulent kinetic energy
Hout(idMtls) == T ! gls turbulent length scale
The outputs are
T Dout(M2rate) Write out 2D momentun acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentun acceleration.
Thanks!
Rafael
Re: turbulent kinetic energy
Which vertical mixing scheme are you using? This variable would only be active in the model for MY25 and/or GLS. You can check the code in wrt_his.F and wrt_his.f90 to see for sure.
