turbulent kinetic energy
asujrpv
#1 Unread post by asujrpv »
Hello everybody,
I am trying to get the tke and set the flag T for that in the .in file, see below. But the code is not writing this quantity, why could that be?
Hout(idDano) == T ! rho density anomaly
Hout(idMtke) == T ! tke turbulent kinetic energy
Hout(idMtls) == T ! gls turbulent length scale
The outputs are
T Dout(M2rate) Write out 2D momentun acceleration.
T Dout(M3rate) Write out 3D momentun acceleration.
Thanks!
Rafael
Re: turbulent kinetic energy
Which vertical mixing scheme are you using? This variable would only be active in the model for MY25 and/or GLS. You can check the code in wrt_his.F and wrt_his.f90 to see for sure.
