Wave output
mathieu
Wave output
#1 Unread post by mathieu »
The ROMS model can output the variable "Lwave", "Dwave", "Hwave" obtained from the SWAN model running coupled but apparently it is not possible to output the variables "Pwave_top", "Pwave_bot", "Ub_swan" and "Wave_dissip".
If this is by error and not by design, please consider the patch of this message for the roms model (against revision 406).
DIFF_wrt_his.txt
(3.16 KiB) Downloaded 1194 times
DIFF_inp_par.txt
(1.79 KiB) Downloaded 1209 times
DIFF_globaldefs.txt
(171 Bytes) Downloaded 1096 times
DIFF_def_his.txt
(3.41 KiB) Downloaded 1154 times
