The ROMS model can output the variable "Lwave", "Dwave", "Hwave" obtained from the SWAN model running coupled but apparently it is not possible to output the variables "Pwave_top", "Pwave_bot", "Ub_swan" and "Wave_dissip".
If this is by error and not by design, please consider the patch of this message for the roms model (against revision 406).
Wave output
Wave output
DIFF_wrt_his.txt
- (3.16 KiB) Downloaded 1196 times
DIFF_inp_par.txt
- (1.79 KiB) Downloaded 1211 times
DIFF_globaldefs.txt
- (171 Bytes) Downloaded 1098 times
DIFF_def_his.txt
- (3.41 KiB) Downloaded 1157 times
