ROMS kinetic energy and other problems
scenty
#1 Unread post by scenty »
As a new user of ROMS, I ran a model with the entire Pacific domain and single climatological forcing input file. A part of the output file is shown below:
Resolution, Grid 01: 0198x0198x032,  Parallel Nodes:  16,  Tiling: 004x004
      86400  ntimes          Number of timesteps for 3-D equations.
   1200.000  dt              Timestep size (s) for 3-D equations.
         30  ndtfast         Number of timesteps for 2-D equations between
          1  ERstr           Starting ensemble/perturbation run number.
          1  ERend           Ending ensemble/perturbation run number.
          0  nrrec           Number of restart records to read from disk.
          T  LcycleRST       Switch to recycle time-records in restart file.
         72  nRST            Number of timesteps between the writing of data
                               into restart fields.
          1  ninfo           Number of timesteps between print of information
                               to standard output.
          T  ldefout         Switch to create a new output NetCDF file(s).
         72  nHIS            Number of timesteps between the writing fields
                               into history file.
       2160  ndefHIS         Number of timesteps between creation of new
                               history files.
          1  ntsAVG          Starting timestep for the accumulation of output
                               time-averaged data.
         72  nAVG            Number of timesteps between the writing of
       2160  ndefAVG         Number of timesteps between creation of new
                               time-averaged file.
 1.2000E+02  nl_tnu2(01)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 01: temp
 1.2000E+02  nl_tnu2(02)     NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for tracer 02: salt
 6.0000E+02  nl_visc2        NLM Horizontal, harmonic mixing coefficient
                               (m2/s) for momentum.
 1.0000E-06  Akt_bak(01)     Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)     Background vertical mixing coefficient (m2/s)
                               for tracer 02: salt
 1.0000E-05  Akv_bak         Background vertical mixing coefficient (m2/s)
 3.0000E-04  rdrg            Linear bottom drag coefficient (m/s).
 3.0000E-03  rdrg2           Quadratic bottom drag coefficient.
 1.0000E-02  Zob             Bottom roughness (m).
          1  lmd_Jwt         Jerlov water type.
          2  Vtransform      S-coordinate transformation equation.
          1  Vstretching     S-coordinate stretching function.
 2.0000E+00  theta_s         S-coordinate surface control parameter.
 0.0000E+00  theta_b         S-coordinate bottom  control parameter.
      0.200  Tcline          S-coordinate surface/bottom layer width (m) used
   1025.000  rho0            Mean density (kg/m3) for Boussinesq approximation.
      1.000  dstart          Time-stamp assigned to model initialization (days).
20060101.00  time_ref        Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)       Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)       Nudging/relaxation time scale (days)
                               for tracer 02: salt
 0.0000E+00  Znudg           Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg          Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg          Nudging/relaxation time scale (days)
                               for 3D momentum.
 0.0000E+00  obcfac          Factor between passive and active
     10.000  T0              Background potential temperature (C) constant.
     35.000  S0              Background salinity (PSU) constant.
      1.000  gamma2          Slipperiness variable: free-slip (1.0) or
          T  Hout(idFsur)    Write out free-surface.
          T  Hout(idUbar)    Write out 2D U-momentum component.
          T  Hout(idVbar)    Write out 2D V-momentum component.
          T  Hout(idUvel)    Write out 3D U-momentum component.
          T  Hout(idVvel)    Write out 3D V-momentum component.
          T  Hout(idWvel)    Write out W-momentum component.
          T  Hout(idOvel)    Write out omega vertical velocity.
          T  Hout(idTvar)    Write out tracer 01: temp
          T  Aout(idFsur)    Write out averaged free-surface.
          T  Aout(idUbar)    Write out averaged 2D U-momentum component.
          T  Aout(idVbar)    Write out averaged 2D V-momentum component.
          T  Aout(idUvel)    Write out averaged 3D U-momentum component.
          T  Aout(idVvel)    Write out averaged 3D V-momentum component.
          T  Aout(idWvel)    Write out averaged W-momentum component.
          T  Aout(idOvel)    Write out averaged omega vertical velocity.
          T  Aout(idTvar)    Write out averaged tracer 01: temp
          T  Aout(idTvar)    Write out averaged tracer 02: salt
             Output Restart File:  /export6/Luwf/Try2/ocean_rst.nc
        Prefix for History Files:  /export6/Luwf/Try2/ocean_his
       Prefix for Averages Files:  /export6/Luwf/Try2/ocean_avg
                 Input Grid File:  /export/home/luwf/Roms_tools/Run/roms_ncfiles/roms_grd.nc
    Input Nonlinear Initial File:  /export/home/luwf/Roms_tools/Run/roms_ncfiles/roms_ini.nc
           Input Forcing File 01:  /export/home/luwf/Roms_tools/Run/roms_ncfiles/roms_frc.nc
             Input Boundary File:  /export/home/luwf/Roms_tools/Run/roms_ncfiles/roms_bry.nc
 Tile partition information for Grid 01:  0198x0198x0032  tiling: 004x004
        0        1       49        1       49    76832
        1       50       99        1       49    78400
        2      100      149        1       49    78400
        3      150      198        1       49    76832
        4        1       49       50       99    78400
        5       50       99       50       99    80000
        6      100      149       50       99    80000
        7      150      198       50       99    78400
        8        1       49      100      149    78400
        9       50       99      100      149    80000
       10      100      149      100      149    80000
       11      150      198      100      149    78400
       12        1       49      150      198    76832
       13       50       99      150      198    78400
       14      100      149      150      198    78400
       15      150      198      150      198    76832
   (interior points only)
        0     0.50    49.50     0.50    49.50  RHO-points
        1    49.50    99.50     0.50    49.50  RHO-points
        2    99.50   149.50     0.50    49.50  RHO-points
        3   149.50   198.50     0.50    49.50  RHO-points
        4     0.50    49.50    49.50    99.50  RHO-points
        5    49.50    99.50    49.50    99.50  RHO-points
        6    99.50   149.50    49.50    99.50  RHO-points
        7   149.50   198.50    49.50    99.50  RHO-points
        8     0.50    49.50    99.50   149.50  RHO-points
        9    49.50    99.50    99.50   149.50  RHO-points
       10    99.50   149.50    99.50   149.50  RHO-points
       11   149.50   198.50    99.50   149.50  RHO-points
       12     0.50    49.50   149.50   198.50  RHO-points
       13    49.50    99.50   149.50   198.50  RHO-points
       14    99.50   149.50   149.50   198.50  RHO-points
       15   149.50   198.50   149.50   198.50  RHO-points
        0     1.00    49.50     0.50    49.50    U-points
        1    49.50    99.50     0.50    49.50    U-points
        2    99.50   149.50     0.50    49.50    U-points
        3   149.50   198.00     0.50    49.50    U-points
        4     1.00    49.50    49.50    99.50    U-points
        5    49.50    99.50    49.50    99.50    U-points
        6    99.50   149.50    49.50    99.50    U-points
        7   149.50   198.00    49.50    99.50    U-points
        8     1.00    49.50    99.50   149.50    U-points
        9    49.50    99.50    99.50   149.50    U-points
       10    99.50   149.50    99.50   149.50    U-points
       11   149.50   198.00    99.50   149.50    U-points
       12     1.00    49.50   149.50   198.50    U-points
       13    49.50    99.50   149.50   198.50    U-points
       14    99.50   149.50   149.50   198.50    U-points
       15   149.50   198.00   149.50   198.50    U-points
        0     0.50    49.50     1.00    49.50    V-points
        1    49.50    99.50     1.00    49.50    V-points
        2    99.50   149.50     1.00    49.50    V-points
        3   149.50   198.50     1.00    49.50    V-points
        4     0.50    49.50    49.50    99.50    V-points
        5    49.50    99.50    49.50    99.50    V-points
        6    99.50   149.50    49.50    99.50    V-points
        7   149.50   198.50    49.50    99.50    V-points
        8     0.50    49.50    99.50   149.50    V-points
        9    49.50    99.50    99.50   149.50    V-points
       10    99.50   149.50    99.50   149.50    V-points
       11   149.50   198.50    99.50   149.50    V-points
       12     0.50    49.50   149.50   198.00    V-points
       13    49.50    99.50   149.50   198.00    V-points
       14    99.50   149.50   149.50   198.00    V-points
       15   149.50   198.50   149.50   198.00    V-points
               HaloSizeI(1) =     124
               HaloSizeJ(1) =     124
                TileSide(1) =      56
                TileSize(1) =    3136
 Tsunami             Tsunami
 AVERAGES            Writing out time-averaged fields.
 DIFF_GRID           Horizontal diffusion coefficient scaled by grid size.
 EASTERN_WALL        Wall boundary at Eastern edge.
 LMD_BKPP            KPP bottom boundary layer mixing.
 LMD_CONVEC          LMD convective mixing due to shear instability.
 LMD_DDMIX           LMD double-diffusive mixing.
 LMD_MIXING          Large/McWilliams/Doney interior mixing.
 LMD_NONLOCAL        LMD convective nonlocal transport.
 LMD_RIMIX           LMD diffusivity due to shear instability.
 LMD_SKPP            KPP surface boundary layer mixing.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 NORTHERN_WALL       Wall boundary at Northern edge.
 QCORRECTION         Surface net heat flux correction.
 RST_SINGLE          Single precision fields in restart NetCDF file.
 SOLAR_SOURCE        Solar Radiation Source Term.
 SOUTH_FSRADIATION   Southern edge, free-surface, radiation condition.
 SOUTH_M2FLATHER     Southern edge, 2D momentum, Flather condition.
 SOUTH_M3CLAMPED     Southern edge, 3D momentum, Clamped condition.
 SOUTH_TCLAMPED      Southern edge, tracers, Clamped condition.
 SOUTH_VOLCONS       Southern edge, enforce mass conservation.
 SPHERICAL           Spherical grid configuration.
 SPONGE              Enhanced horizontal mixing in the sponge areas.
 TS_C4HADVECTION     Fourth-order centered horizontal advection of tracers.
 TS_DIF2             Harmonic mixing of tracers.
 UV_C4ADVECTION      Fourth-order centered differences advection of momentum.
 UV_LOGDRAG          Logarithmic bottom stress.
 VISC_GRID           Horizontal viscosity coefficient scaled by grid size.
 VISC_3DCOEF         Horizontal, time-dependent 3D viscosity coefficient.
 WESTERN_WALL        Wall boundary at Western edge.
After one-year-running, the kinetic energy shows a trend to be less and less.
And the flow field is strange. The Kuroshio is not visible.
So as the tropical region:
Any suggestion or help is appreciated!
donguiyo
Re: ROMS kinetic energy and other problems
#2 Unread post by donguiyo »
I found an old hard drive where I **might** have the original cpp.h file. I will post/send it later tonight. Your cpp.h has some non-standard choices. Are you using tidal forcing?
donguiyo
#3 Unread post by donguiyo »
Below are the CPP options that I used for the 2004 Global Roms, but 1st let me suggest a perhaps easier alternative for your southern boundary. Why not extending your southern bdry to Antarctica and using EW_PERIODIC in the east-west direction for the ACC? that has been sucessfully done in the past with other models. Or with that same configuration you could also define nudging conditions for tracers (Temp and salinity) and momentum (incoming) and radiation conditions for outgoing information including sea level (no nudging for sea level though). Also, see my note below about TS_DIF2 and UV_VIS2.....with all these it should run fine.
#define GLOBAL
** Options for WORLD OCEAN - resolution from 0.4 (Eq.)
** to 0.8 degrees - enhanced in +/- 35 and tropics
/* output options */
#undef DIAGNOSTICS_UV /* define if writing out momentum diagnostics */
#undef DIAGNOSTICS_TS /* define if writing out tracer diagnostics */
#undef AVERAGES
/* advection and coriolis */
#define TS_U3HADVECTION
#define TS_C4VADVECTION
/* pressure gradient */
#define DJ_GRADPS /* Splines density Jacobian (Shchepetkin, 2000) */
/* diffusion and viscosities schemes */ ** TRY TO UNDEF UV_VIS2 and TS_DIF2 and see if your solutions remain finite
#define VISC_GRID /* viscosity coefficient scaled by grid size */
#define DIFF_GRID /* Diffusivity coefficient scaled by grid size */
#define MIX_GEO_TS
#define LMD_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_NONLOCAL
# define LMD_SKPP
/* equation of state - relaxation - salinity - coordinates - etc */ [ ** BELOW DEFINE SPHERICAL **]
#define SOLAR_SOURCE
#define SPHERICAL
#define SPLINES
/* boundary conditions */
#define EW_PERIODIC
#define NORTHERN_WALL /* Northern edge, closed wall condition */
#undef WESTERN_WALL /* Northern edge, closed wall condition */
#undef EASTERN_WALL /* Northern edge, closed wall condition */
#define SOUTHERN_WALL /* Southern edge, closed wall condition */
/* Climats processing and relaxations */
#define QCORRECTION
#define SRELAXATION
#undef TCLIMATOLOGY
/* END OF GLOBAL */
Guillermo.
turuncu
#4 Unread post by turuncu »
I just wonder about the grid that you used for the global simulation. I try to create same kind of grid (periodic in East-West direction) to simulate the small belt around equator but i have some difficulties to setup EW periodic grid. If it is possible could you share your grid with me.
Best regards,
--ufuk
